Question about Sylvania SRD3900 DVD Player/VCR
Disc stuck in player.
Put in video which started out ok then stopped and showed nothing except something that looked like a test pattern. Cannot remove the disc. HELP!
  • peggyferguso Nov 17, 2008
    PROBLEM SOLVED.................turned vcr player upside down and managed to remove the disc.
Turned vcr player upside down and with a little maneuvering the disc came out.
Posted on Nov 18, 2008
Denon DN-C635 CD Player problem.
In working with consumer electronics a lot of years, the pickup, mechanism or CD section is not always at fault but people that
are trying to work on their own equipment make assumptions that may not be correct. If you put in a new CD player then the other issues as with all wave soldered equipment can be bad solder joints and even bad solder at joints where the connectors are as these get a lot of activity in a repair. Look at the PCB well. I have fixed a lot of equipment by resoldering bad or broken joints. Check around power transistors and those larger drive transistors for these broken joints.
Mar 22, 2013 | Denon DN-C635 CD Player
I load the disc in my player, and I get audio, but I get no picture. What am I doing wrong?
Hello sir in which player are u trying to play it ??? Whats the video format ???
Mar 13, 2008 | Televison & Video
A DVD got stuck in my DVD-E810-Pianocraft player of Yamaha. As I tried to get it out, it dropped inside the box, and now stays there. Did anyone else have the same problem? Is it safe take off the screws...
Hello Dmitry,
Lift the player out of the box as careful as possible and set it on a flat surface near your television so you can plug it in and test it after you have removed the disc. Go ahead and remove the screws and carefully remove the cover and take the disc out. In some cases you may have to apply a steady gentle pressure on the dvd tray to gently push it out if you can not get the disc out easily.
Once you have the dvd out of the machine you are going to want to plug it up to the tv and into a power source and systematically test the system components to make sure they are in working order.
Start with the power button to see if it is working and watch the screen to see if the video signal is being transferred to the tv (usually when you plug a dvd up and turn it on, it will say something about dvd on the screen).
Next push the dvd open and close button and make sure the tray is working properly. You will be able to see the tray slide in and out with the cover off. Make sure the little gears are not broken, belts are on, etc. If any part is not functioning properly or hanging up, stop and unplug it because you will most likely need it repaired and other components may be damaged. If everything works properly keep going.
Next put the dvd in and see if the disc spins and the laser is hitting the bottom side of the disc. Do not look directly into the laser. If the disc is spinning and the laser is working then the movie should be showing on the tv screen.
If everything is working, check the other buttons start, stop, pause, etc and check to see if the remote is functioning if it came with one.
If everything is working properly, replace the cover and continue to set your dvd player up where you want it. If something is broken, you will have to make a choice have it repaired or buy a new one. Depending on the price you paid for the device it may be cheaper to buy a new player.
I hope this helps you solve the issue. You can check my profile, go to my tips, where you can find some helpful tutorials and tips.
If you would not mind, rate my help. I would greatly appreciate it. Thank You
Feb 07, 2010 | Yamaha Televison & Video
T20 low battery and no recharging
this is problem with your hardware.......
Jun 20, 2009 | iRiver T20 MP3 Player
2005 ford expediton 6 disc cd changer
06 expedition 6 cd player and having the same issues,,, Disconnect battery and all 6 cd are stuck inside. "Error cd" shows when pushing eject. Looked everywhere and nothing shows how to fix it. I dont want to buy another radio/cd player for something that ford should know and how to fix?
Nov 14, 2008 | 2005 Ford Expedition
Can't read disc
Possibly a bad, or more likely, a damaged disc.
It's not uncommon, especially with often abused rental copies.
Tell Blockbuster - they should give you a credit on the rental.
Jan 12, 2008 | Sony DVP-NS700P DVD Player
Dv-c503 pioneer dvd player
the magic eye on the door opener in been obtruated by something .. like a small object stuck on a cd or someone might just open the door and let something in it .. stuck on the slidetrack ..and interfer with the sensor .. maybe kids???
Dec 30, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Wharfedale mp3 player
do you know how to take disc write protection off
Sep 30, 2007 | iLO MP3 Player
CD player is locked
Hell Yes!!!  Thanks my friend - I haven't been able to use this thing for about 6 months.... You da man!
Feb 07, 2007 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
Sylvania SRD3900 DVD Player/VCR Logo
100 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
