Question about GE Profile Spectra JGBP90 Gas Kitchen Range
No instruction manual, bought used GE XL44
Where can I get an instruction manual for my stove?
  • jodyglass Feb 09, 2010
    The oven portion is not lit. How do you light the pilot light? I have a GE XL 44
    President:
  • 1,901 Answers
Here you go:
GE XL44 Manual
After opening it, save it to your computer for future use.
Posted on Nov 17, 2008
  • taliasue Jan 14, 2011
    It says this item is no longer available. This stove came with my house. I need to know if I can leave the racks in the oven when I am self-cleaning it?
  • dmwelder28 Feb 03, 2011
    no, it says to take out,ive also heard you are better off cleaning it your self.the oven can get so hot that it burns the wires and can also shatter the glass. hope it helps. ive used mine before i heard this and was not impressed with the results anyways.
SOURCE:
GE XL44 Gas Stove and Oven. Everything works normal except the oven which stopped working suddenly (no flame). Couldn't find the manual to check troubleshooting guide.
The oven uses a silicone carbide ignitor which requires 3.6 amps or better to open the gas safety valve.
If you don't see any glow from it then it is either blown or the gas valve has gone bad. If it is glowing but not real bright it probably is weak.
How it works: Silicone Carbide Ignition
XL44 gas stove manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 25, 2011 | GE Ovens
GE XL44 oven won't turn off. Knob off and pin is loose
My GE XL44 oven would not shut off and it turned out to be a worn out thermostat for the oven. I have written up a step-by-step tutorial on how to replace the thermostat on my blog: John Fixes Stuff GE XL44 Oven Will Not Turn Off How To Replace Oven...
Jan 17, 2010 | GE Kitchen Ranges
I have a GE xl44 gas oven/stove. I cleaned the
Change the Temp sencor for the self cleaning
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_541ceb86d69e7743
Dec 05, 2009 | GE Kitchen Ranges
Need replacement drip pans for ge xl44 gas stove
u can find the parts only in the service center of GE appliance center.but if ur unit is more than 10 years,im sure no parts available.
Jun 30, 2009 | GE Profile JGP636 Gas Cooktop
Our GE spectra profile xl44 has the tan grates and when they get
Think about putting them in the oven and select "clean" and see if the oven will clean them as it cleans itself.
Nov 03, 2017 | GE Kitchen Ranges
GE XL44 gas range, oven dial doesn't have "lite"?
Set the oven for the desired temperature. It will cycle on and off at that temperature.
It will lite automatically.
Feb 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Feb 19, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
10,264 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
