Frequently (not always) when I power up my external HD or plug in a usb memory stick, windows explorer fails to detect it. If I restart the computer with the HD already turned on or USB stick plugged in, then explorer will see it. On occasions when it does detect the drive without a reboot it still takes a long time - 30 seconds or more. I am using XP with SP3. I have two external HD's and two USB memory sticks all of different brands and it happens with all of them.
Comments:
Nov 21, 2008
- The problem is very intermittent - that is, everthing is ok for a few days then it starts again. Right now it is working OK. I did check for a BIOS update but there dosen't seem to be a newer version than the one I have. Not sure how to "scan for virus in safe mode". One other related issue is that when I plug in a drive i (almost?) always get a message saying that the device would run faster on a high speed usb 2.0 port.
-   i am have problems with the 3d Rage Pro Agp, and the Video Controller it siad with VGA compatibility....and also the PCMCIA controller please help me out from this promblems......when ever i put a flash drive it recognises it but i would not see it in the my Computer...Please help-   shopzy
Nov 18, 2008
-   I tried your suggestion but the disk does not show up in the list in the disk management pane.-   Guest
Nov 18, 2008
-   The disk does not show up in the disk management area of the administrative tools.-   Guest
When the drive is not recognized, try going to start->control panel->administrative tools->computer management->disk management and see if the drive is recognized by it, if so try assigning a drive letter then exploring it
Comments:
Nov 18, 2008
- You might have motherboard problems. Check if wiggling the cables fixes the problem, and change the ports your plugging it into. Try updating the bios from support.dell.com. Try scanning for viruses in safemode. If none of that works, your usb controller might be going bad.
Nov 21, 2008
- you should try getting a usb 2.0 card, they're cheap, you could get one off ebay for next to nothing. get a pci card if your using a desktop, or a pcmcia usb card for a laptop. this will bypass your usb controller as well so it should solve the problem.
