Question about Canon PIXMA MP830 All-In-One InkJet Printer
Please help Hi there Jonnie, I have the exact same problem witht the Canon MP830, where I get the 6A00 error on the LCD. I followed your instructions, moved the printer head to the left (it was fairly stuck but it did move and now it slides softly left and right). I then used cotton tips and windex to clean the purge unit area and as you mentioned, it had a fair bit of ink. Now, when I turn it on, i still get the same error but the print head does not move back to its original position. I turned it off again and moved it all the way to the right, turn it on again and the same error occurred. I am running out of options, I see some sort of clear plastic flaps coming from the bottom of the purge, not sure if its meant to be there. I was hoping you could provide me with further help, may be giving me more detailed instructions or help on opening it near the purge unit (i can see a screw under the unit, right in the direction of the purge are). I am a bit worried I may have caused further damage by moving it to the right, is it meant to click? I had to apply a bit of force, not too much though and it doesn't seem anything has broken off, but the head now seems to move left and right fairly easily, however when i turn it on, it stays where ever i have left it - it won't move to the right and continues giving me the same 6A00 error. Your help would be appreciated. Please help me if you can. Cheers, Mike
  • 1 more comment
  • kutedj Nov 17, 2008
    Sorry for annoying you again Jonnie, where it says "I am a bit worried I may have caused further damage by movit it to the right", it should say "moving it to the left". The head was stuck on the right side all the time during the display of the 6A00 error, I had to move it to the left in order to reach the purge unit - this is where I had to apply a bit of force as it was stuck. Hope this clarifies.
    Thank you once again.
    Mike
  • kutedj Nov 19, 2008
    Hello again,
    I have managed to fix the problem. All good now.
    Cheers,
    Mike
  • kutedj Nov 22, 2008
    Thanks for the extra information :)
    All the best.
  • 1,031 Answers
The problem apparently is related to the purge unit located at the far right side on where the printhead moves back and forth.
there appears to be three common problems that causes the error, which is related to a paper jam error. 1) If its a new printer or even an older one, there are two sponges that collect ink and two plastic wipers located in purge unit may be loose or missing. Check to see if its it there. If not, it may actually be stuck somewhere.
2) there may some paper stuck somewhere around the printhead and or the purge unit or
3) there is a build up of gooey ink on the purge unit.
, I turned off the printer & unplugged it, move the printhead to the left and used long Qtips with Windex to clean up the ink around the purge unit including a little white plastic spring-loaded lever. also dampen the sponges with Windex. If you do this be careful not to dislodge the sponge or wipers. If you do, you can alway stick the pieces back in. After cleaning it, and checking the sponges and wipers are seated correctly, plug the unit back in and hopefully it will work fine. hope this helps.dont forget to rate as fixyaa
Posted on Nov 21, 2008
Error 99 ?
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Apr 14, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Camera will come on but the lcd wont when i try to take a pic it flashes a busy signal in the veiwfinder
I hope that helps.
Jan 24, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Canon busy signal busy signal after take a picture
I hope that helps.
Dec 26, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Camera is locked with continous busy error, will not download or take pictures
I hope that helps.
Oct 26, 2009 | Canon EOS Rebel XS 35mm SLR Camera
Error busy canon eos 1000
I can help you fix the BUSY Error or Error 99 of your Canon EOS 1000D.
Installation of this Canon EOS 1000D firmware version 1.06 update will solve these problems:
I hope that helps.
Sep 20, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Constant "busy" error and no display screen even if you push "menu"
I hope that helps.
Aug 12, 2009 | Canon EOS Rebel XS 35mm SLR Camera
Error 99 comes on after I have taken a few pictures. I have tried cleaning with eraser as people have done and it still comes up with message.
I hope that helps.
Jul 14, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Same
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
I hope that helps.
Jul 11, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon Rebel XS says it's busy
I hope that helps.
May 29, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
The only problem with SD card download stuff is that the LCD screen has to be working. If that is part of the problem, how can the instructions be followed?
Mar 22, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
98 people viewed this question
old marine
old marine
