Question about Minolta Freedom Zoom 140EX 35mm Point and Shoot Camera
NO FLASH AS WELL AS THE INDICATOR PANEL FLASHING
All indicators in the data panel blink and batteries must be removed to stop. This will happen again every few pictures. Also the flash will not work in any mode. No other indication of weak batteries.
  • Anonymous Dec 16, 2007
    I have the same problem however the flash works.
4 Suggested Answers
poolseman
  • 206 Answers
SOURCE: Flash not working
It is either the small flash tube or trigger coil that need replacing . If you decide to do the job yourself, make sure you discharge the main capacitor before you start working on the camera ( when charged holds +- 300 v)
Posted on Aug 28, 2007
  • 619 Answers
SOURCE: bat indicator blink´s
Hi , clean the battery terminal having acid rust to contact will positive and nigative terminal.Open the lense to release the shutter miror might open , check the camera option select in auto or manual not in lower speed can cause stuck.open the film compartment and load film .
Posted on Feb 28, 2008
tbreeze47
  • 3083 Answers
SOURCE: Purchased a used Minolta Supreme
It sounds like the camera isn't detecting the film, but it could be a more serious problem with the hardware...whatever it is, fixing it usually involves swapping out the "brains" of the unit, if it isn't simply the film sensor mech. Even that can require extensive repair..
If it was advertised in good working order, I would return it, since it probably isn't. Communicate with the previous owner to see what can be resolved.
Good luck, and hope this helps.
Posted on May 30, 2011
Yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Panasonic plasma TV TH-42PWD7 blacks out..
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 20, 2014 | Panasonic TH-42PWD7 42 in. EDTV-Ready...
DID NOT TURN ON, HAS B+,RED INDICATOR LED BLINKING WHEN PRESSING ANY OF THE TACT SWITCH
Jan 09, 2014 | Philips Televison & Video
Dash lights keep flickering after key is removed
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 31, 2013 | Televison & Video
Rca flat scrern flashing on and off
Dec 28, 2013 | Televison & Video
2 SEPARATE FLASHING LIGHT INDICATORS FLASHING. I HAVE ABSOLUTELY NO PAPER JAM.
"All lights blinking and printer not responding" is indicative of serious ink cartridge issue. Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
The Solution is to try an older/another cartridge (doesn't matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning. This electronic panel is front part of the cartridge with copper "dots".
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge's electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Mar 15, 2011 | Office Equipment & Supplies
My wii remotes wont pick up signal blue lights flash then just go back out again
Hi, check the batter level and then try re-synching the remote's.
Here's instructions for both:
f4bc8924da.gif A fresh set of alkaline batteries should last, depending on amount and type of use, up to 35 hours. This can vary greatly based on certain factors, such as Wii Remote Speaker Volume, Rumble, battery quality and age, and type of game being played.
Important Note: If you are using rechargeable batteries, the only type of battery recommended are Nickel Metal Hydride batteries. When it comes to using rechargeable batteries, you must follow manufacturer guidelines for safety and proper usage. Failure to do so could cause damage to the Wii Remote and void the warranty.
There are two ways to check the Wii Remote's battery levels:
  • Remove the battery cover and press the Red "Sync" button. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength, with one light flashing indicating the lowest level.
    or
  • Use the HOME Menu to check battery level of each Wii Remote:
    1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
    2. Select the Wii Remote Settings option from the Home Menu.
    3. The battery level of all synced Wii Remotes is displayed along the bottom. Four bars indicates a full charge, with one being the lowest charge.
55851daefd.gif Note: Make sure you have placed batteries in the Wii Remote.
  1. Press the Power button on the Wii console to turn it on.
  2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and press the SYNC button just below the batteries. The Player LED will blink.
  3. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
This procedure must be followed for each additional Wii Remote added to your system.
I hope this helps
Mike
Jul 30, 2009 | Nintendo Video Game Consoles & Games
Battery indicator?
Hi there.
Sounds like the battery could be faulty.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective.
Good luck
Jun 01, 2009 | Dell Latitude D600 Notebook
When new batteries have been put in both controllers of the wii, indicator lights supposed to indecate power level of batteries instead of which all blue lights flash then stop and nothing happens, no...
If all the lights are coming on then going off again the controller needs to be synched with the wii. Once it is synchronized after all the indicator lights flash one should stay on indicating which player you are (1 -4)
To synch a controller to the wii:
Make sure the wii is in
Open the battery cover on the wiimote
Open the front panel of the wii
Press the synch button on the console
Press the red synch button on the wii mote
Should work for you.
Jul 04, 2008 | Nintendo Video Game Consoles & Games
Minolta Freedom Zoom 140EX 35mm Point and Shoot Camera Logo
62 people viewed this question
Top Minolta Cameras Experts
 Larry
Larry
Harrie
ray gallant
Are you a Minolta Camera Expert? Answer questions, earn points and help others
