Question about LG Studioworks 552V 15" CRT Monitor
Lg 5552 v set is dead
The set is dead power supply ok i found hor. output transistor dead short,i had tried replacing horizontal output transistor for several times, after replacing it as soon as i switch on the set it again gets dead short in fraction of time i dont get a time for voltage measurement also, i checked the tube along with yoke with other set it is functioning well pl help me
Try to resolder all points in fbt including fly back trans itself area also resolder the crt pcb area i had the same problem the reason was cold soders also put a good 2sc5297 for hor out.
Posted on Dec 24, 2006
No picture
I disagree with given info, this tv has no horizontal output transistor because it is dlp tv.
3 red light blink means lamp cover is not placed back properly after lamp replacement/ lamp checking. Make sure lamp cover is fixed back in its place securely and tight.
Jul 16, 2009 | Sony Grand WEGA KF42WE610 42" Rear...
Dead set!
First, locate the horizontal output transistor. This is found very close to, or next to, the horizontal output transformer (also known as the flyback). The flyback should be on an aluminum heat sink, or on the side of the metal chassis. Disconnect or unsolder two of the three legs of the transistor. Measure it with your meter, or plug in the set with the light bulb attached across the fuse.
If the transistor is shorted, or the light bulb doesn’t glow bright anymore, replace the transistor and plug back in. If the light bulb glows bright again, you must replace both the flyback and horizontal output transistor simultaneously. In some cases this will fix the set, but sometimes there are multiple problems with a set.
Go to where the flyback is, and start measuring the diodes and capacitors on the flyback itself. If you don't find any shorts there, it could be a shorted vertical output IC, a shorted sound IC, a shorted disc capacitor in the Hi Voltage/sweep circuit, or in rare cases, a shorted capacitor or tuner.Feel free to ask and post whatever the result of your troubleshooting..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Jul 30, 2008 | Televison & Video
Dead set lg studio works v452 monitor
lg g505 this moniter 5 or 10 mnt woking then hot transister is damaged why this problem ?
Jan 26, 2008 | LG Studioworks 45 14" CRT Monitor
JVCAV-N2043TV,Horiontal Output Transistor burns out everytime if fix a new one
Hi There,
The Hor Output transistor is connected to the Line Output Transformer. This transfromer provides a lot of voltages around your TV set but includes the very high voltage to the Picture tube...
These transformers are specially tuned to resonate at a certain frequency,
The Hor output transistor needs to match this frequency....so if the wiring inside the transformer is shorted by "just a bit" the picture will be visible but the transistor is struggling to match the transformer impedance,from the mismatched tuning...so the transistor draws more current from the power supply.. runs hot then burns out...
Usually manufacturers provide a Trip circuit that detects that an overload on the power supply is occuring and cuts the power to the Line output stage ...this is usually detected by a clicking sound within the power supply its called hiccuping.
If some one has altered the correct setting on the power trip circuit then the next thing that happens is the Transistor goes Blooooey like in your case.....
So to save you a lot of money replacing the output transistor
please replace the output transfromer as well next time...
But please... please... re-check the power supply trip circuit to save you a lot more expense in the future....
Best Regards From YUBEUT
Oct 10, 2007 | JVC AV-27230 27" TV
Tv trouble shooting
whenever any fusible resistance fails means there is a short ckt in tv. failure is mainly due to main filter cap or rectifire diode os switching ckt failure(here as you cleared str.) remember while servicing power supply isolate hor. section for safety purpose.& connect it only after power supply output is ok &after checking parts in hor. ouyput section. if this seems to be ok then go for hor.output ckt failure like hor output,flyback transformer & cap& diodes connected with it.
Oct 02, 2007 | Televison & Video
Snoy model KV-21GMR1
check secondary voltage first and look for short.if you replace the regulator strs6707 you replace also c623 220uf/16volts
Sep 24, 2007 | Emerson TC0918 Television
LG colour TV RI32CZ10RX problem with picture
My LG tv has suddenly got a problem with the picture. Whilst watching the tv with no problems at all, the picture was suddenly reduced to a thin vertical line down the centre of the screen and an awful smell seemed to come from the tv There is a short ckt in your tv in horl. section. 1 isolate power from horizontal section. 2 check for normal output from power supply. 3 check parts in horl output section a hor.output transistor b diode & cap in h/output trnsformerckt. c check for print. d if all are ok check for eht transformer. e if every thing becomes then reconnect hor output section supply. f put on the set.
Sep 23, 2007 | Televison & Video
No raster no audio,Zenith SJ 2065S5
as horizontal transistor gets very hot so no eht so no raster &no sound due to nosupply to vif & tuner. as hor output is getting hot please isolate supply to hor. section & check power supply output is ok as due to high voltage h/outout may get hot & demaged. if supply is ok check for leaky or short parts in hor output. 1 hor. output transistor itself if it is replaced that may not be of proper matching. 2 diode& cap.in eht section. 3 clean print near eht. 4 moisture near yoke due to rain in rainy season only. so keep it hot for few hours. 5 at last if all are ok eht or fly back transformer. re connect power to hor output after rectification
Sep 18, 2007 | Televison & Video
Toshiba CF3566A
follow the diagram, the base of the hor out should go to the secondary of the hor drive transformer, and going to the primary circuitry you should find a transistor, a small transistor, look for its collector and you should find a filter capacitor, may not be the same value but it is the filter capacitor.
May 20, 2007 | Sony HMD A220 17" CRT Monitor
Horizontal output transistor keeps failing
The horizontal output transitor is always connected to the primary winding of the flyback transformer (via collector) and also to the horizontal deflection coil via an electrolytic capacitor. The most likely suspect for damaging the transistor is the fylback transformer. In some countries there are electronic stores that test flyback transformer by winding a few turns on the ferrite core and applying a test voltage. This test will only test the secondary. The primary winding is difficult to test for turn to turn short because the resistance is quite low and you do not know the 'good' resistance.
May 15, 2007 | ViewSonic E70f 17" CRT Monitor
LG Studioworks 552V 15" CRT Monitor Logo
104 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
