Sound output problem
My PC's front Sound out put not working where backside output is working
  • 1 more comment
  • dulanlakra Nov 17, 2008
    This is my desktop problem
    My Pc's mother board is ASUS and Runnig in Realteck HD Audio Driver, So please advice me where I can find Audio Chipset Driver and BIOS update immediately please
    Many Many Thank for your suggestion, Now I can hear sound from front output of my system through setting of BIOS and I admitted that YOU ARE GENIUS.
  • 458 Answers
You will need to pull the bottom case bezel apart and check the connection to the speaker panel... it plugs into the motherboard with a 2 wire plug (black and red wires typically)
There's a chance that if the laptop was ever previously disassembled, it might have pinched the speaker wires upon reassembly of the laptop..
Posted on Nov 17, 2008
  • Garry Romaneo
    Garry Romaneo Nov 17, 2008
    WHoops, I was thinking of the Speakers themselves... not the Port...
    Your front audio Port is Connected to the motherboard... So Either The Ports connection shorted out, or you need to update the audio and chipset drivers, Try as well - a BIOS update
My receiver was working yesterday.. today no sound?
When you put it on, what is written on the front indicator, , what does it shows at the front interface? If you see overload or protect or something else? Tell me what is the written word on the screen or interface at the front and we'll see after. Do you also hear the relay sound clicking after putting it on after a couple of seconds? If not, tell me. Might be the output that are dead. Those are generally 3 output sound modules inside. Or only one of them dead. Or if it has no sound everywhere in every input. Tell me more about every little details of different things it does or shows and i will try to help you. Thank's. My name is Serge.
Mar 05, 2015 | Yamaha Audio Players & Recorders
USB ports not working ... front ports are working while back ports not... what may be problem.. as drivers are installed !!
There is a cable between the motherboard and the USB ports which is missing or pulled out.
Oct 10, 2014 | Computers & Internet
How do you install an audio output device?
this depends on what kinda audio output you want to install ..but the general idea is to get the audio signal from the computer from the green out in the back on the sound card (it is a 3.5 jack ) ..and there is the stereo out-put for the computer's sound..It can be amplified in any device that has a stereo input on 3.5 jack ..
if you want something more complicated..the map of the out-put (the scheme) will be shown in the sound manager (of teh driver ) ..when you make the output changes..This is on a color code..and can be 2+1...3+1..4+1..and the surround 5+1..when you choose surround 5+1 from the sound manager ..it is shown all 3 outputs and the role they play ..bass+center ...Front ...and rear ..they are 2by 2 stereo paired on left and right ..
Sep 02, 2010 | HP PAVILION A6230N DESKTOP PC
The Sound of the Monitor is not working.
Check cable connections between the monitor and the sound card/motherboard output, you could unadventedly dislodged it, check the monitor speaker volume control on the monitor menu. If all else fails connect the headphone input directly to the PC case front or back sound output - much better than via the monitor anyway - shorter pathway makes better sound, last but not least: use a better set of speakers - monitor speakers ****
Mar 06, 2010 | Computers & Internet
Connecting PC to the Philips HTS3455
Hum first,,, anytime you have 2 devices with sound running to a cable or ant equipted TV you will get a hum as they are grounded off curcuit. HumEliminator (radio shack). You didn't tell us if your PC had been enabled in control panel for either device. I have had no luck using the rear aduio output on any computer. Front headphone jack on PC does not need enabled and will work better for this. Unless you use a USC codet interface which is better yet for CD quality in sound. Also make sure the Aux inout is enabled on TV as well. Direct Input would be the same. Lastly,,you are 100% positive the backside is input and not actually out put or gaming inputs.
Mar 05, 2010 | Audio Players & Recorders
No sound
Go into your sounds settings Control Panel> Hardware and Sound (on Xp its just sound)> sound> You should have 4 types of speakers available. I have Digital Output Device (HDMI) Speakers Realtek Digital Output Realtek HDMIOutput my default was the HDMI and i changed it to speakers and then my speakers worked.
Hope this helps ^^. Please don't forget to rate, Thanks
Feb 26, 2010 | E-Machines T3504 PC Desktop
Adding speakers to my PC
Yes you can use the headphone output to drive speakers but be careful about the volume levels you use, as this could damage the speakers. You should opt for the Line Out socket from your Dell which should be on the back side of the device.
http://support.euro.dell.com/support/edocs/systems/dmum/techovu.htm
shows the backside schematic and where to find the Line Out socket - this has a balanced output that will drive your speakers correctly.
Jun 28, 2009 | Harman Kardon HK695 Computer Speakers
No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
May 23, 2009 | Kenwood VR615 Receiver
No sound out headphone jack
Are you connect the jack at front panel,if so just try with the backside of C.P.U.,If in this case it works that means you have to connect the front panel wires to your motherboard Pins.
Mar 25, 2009 | Toshiba Tecra A9-S9012X Notebook
No sound output from rear speaker jack
Plugging headphones into the computer will disable sound output from the sound card by design.
Sep 15, 2007 | Acer Aspire L100 PC Desktop
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
