Question about Refrigerators
Instruction manual for indesit TA5fnf
We don't know how to adjust the tempreture of the fridge (or freezer). We've already had 10 pints of milk go off because it's not cold enough
I phoned a friend with a similar machine
Posted on Nov 18, 2008
Whirlpool fridge model wro34uw leakage help please. I've noticed that most people that have posted have water hooked up and ice/water dispensers - my fridge doesn't have these features, just a...
At the back of the fridge check for a small drain hole that allows the water to flow out to the top of the compressor They do block up from ice and food residue (peas -milk etc) I would have a very serious talk to the rental agency as the fridge repair is the responsibility of the land lord as it came with the property. Ask for a new fridge or a good serviceable fridge. The freezer door gaskets are probably not sealing ( gone hard) allowing air in with the air moisture turning to ice.
Jun 25, 2013 | Refrigerators
Ignis fridge isn't cold enough, and seems unable to maintain a constant temperature. I bought a fridge thermometer to get some accurate data: fridge is typically between 9 - 15 degress c. Generally, a good...
the compressor is acting weird because the fridge might need regasing if the tempreture
uness the fridge controls for the tempreture nside the fridge are buggered and the thermostat
Jul 05, 2008 | Refrigerators
My freezer isnt working correctly ,isnt freezing the food and the fan only kicks in now and again and there is ice at the back of the freezer .can you help
It seems that the efficiency of the fridge has dropped as there is frost forming within the system due to a possible failure in the control circuit or the auto defrost timer.
It can also be related to a failure of the circulation fan or the thermostat.
Shut off fridge for about 6 hours and if it cools then the defrost timer must be checked along with the heaters.
Aug 02, 2011 | Beko TLDA662
Have taken delivery of a GENERAL ELECTRIC,S 442 G E.. Fridge area after 24hrs can not adjust dial to coldest will move dial past coldest no change in tempreture at present 1-10 only 5.. Kind Regards...
tempreture inside freezer should be at 0 inside fridge would be 38 these are both optimum tempretures if you just received delivery there is no sense in you researching how to fix or taking anything apart it is warrantied and if you were to try to fix the unit you would void your warranty best thing to do is call them monday morning Thanks again Rick
p.s if you have any further questions message me back and please remember when our chat has concluded to rank how this opinion has helped
Jan 09, 2011 | GE Refrigerators
Fridge not cold enough to hold milk resulting in the milk becoming sour. Fridge temperature is 10 degrees C how can we make it cooler? We have already set the temperature to the dial 7.
You could do the simple things like clean the dust and stuff around the compressor condenser. Check the condenser motor. Good air flow improves performance and cost nothing to fix. Of course if you are experiencing a defrost problem the air from below gets choke out with ice buildup around the evaporator area. If you have frost on the backside of the freezer section changes is you have a broken defrost heater.
Apr 19, 2010 | Whirlpool GB2SHDXP Bottom Freezer...
Hi, my freezer is super cold, and my refrigerator side is freezing my milk, my water ,what may be the problem? I have already cleaned the coil and the compressor. Thanks
well the coil being clean will just allow the compressor to function properly. You have a cold control problem. Too much air getting into the fridge. adjust the settings. Turn the settings to the fridge side warmer and the freezer side colder... then allow 24 hours to adjust... if still too cold then have a tech come out and service it it probably has mechanical problems
Sep 17, 2009 | Roper Refrigerators
Freezer cold, refrigerator warm
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 10, 2009 | Refrigerators
Refrigerators Logo
99 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
