Question about Compaq FP 5017 15" Flat Panel LCD Monitor
Compaq FP 5315 Monitor Disassembly
How do I remove the back on this monitor? Anyone have a solution? Need to check the fuse!
    Problem Solver:
This is how I did it.
1- Remove the four screws in the back of the monitor. Two are in the bottom corners and two more near the bottom center ( these hold the stand in place).
2- Remove the stand.
3-The case back is held on by the four screws and a number of plastic pressure clips. After removing the screws: using a fairly wide flat bladed screw driver; insert the blade in either of the two slots on the bottom edge of the case and twist with medium force. This begins the seperation of the back from the rest of the monitor. As the crack widens, begin moving the blade of the screw driver along the widening crack (around the case edge) and twisting gently. This releases each pressure clip in turn. Separate the case back from the rest of the monitor.
I did this this way with my monitor. It works.
Good luck.
Bill
Posted on Oct 22, 2009
For FP 5315 a very nice monitor by the way yeah U should be able to located screws in the back But I suggest that you remove the stand frist. it also has that label in the middle. You gonna have to remove it (not sure if a must but there are some screws there too) WARNING: be sure not to mess around it anything that dosen't need to be move. Once open there will be a strip of wire connecting the screen with the board gentel remove it now u will see two boards the on the left in the main controling board. The one in the right controls the power. you should be able to locate the fuse in the right one right next to the green power cable. hope it helps. and as alwasy use common sense and please remember to disconnect the power cable. I have felt what happens..........so yeah
Posted on Jun 09, 2007
Compaq FP-5315 won't turn on goes to sleep every time
More likely to have bad caps with bulging top in the power supply, that is the first place to look for the monitor this old, see example of failed monitos due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you se sowe help you more.
Mar 04, 2010 | HP Compaq FP5315 15" LCD Monitor
When connected, my Compaq FP 5315 monitor flashes on and off continuously, half a second on, half second off. I cannot tell if this a software or hardware problem. Prior to this problem, the monitor was...
carrt33, If unit performs same way when connected to fully booted known good pc with WIN-desktop as displayed output, I would then suspect a problem with the units SMPS/CCFL inverter power supply failing to sustain running voltage to the "cold-cathode-fluorescent-lamps" that provide white light so you can see all the pretty colors on the lcd panel. Read my FIXYA profile for more info and possible options you might have. Remember this! Your CCFL back-lit lcd monitor is no different than any other brand in it basic design and operation! 12fixlouie
Feb 23, 2010 | Compaq Computers & Internet
Does it do the same with other PC? If it does, then you need to open it up and start looking for bad caps with bulgign/leaking top first, post back what you see so we can guide you further: see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 23, 2010 | HP Compaq FP5315 15" LCD Monitor
My monitor, once i start my computer then monitor start to flick and became black screen, what is the problem please let me konw any thing i can do for my monitor. modle no- compaq fp 5315
its a risky for you to open the monitor and repair its power supply, coz its your monitor's power supply prob..
please contact with warranty providers.
good luck
shafky
Jun 19, 2009 | HP Compaq FP5315 15" LCD Monitor
Re-placing the VGA cord
You will have it on the manufacturers web site
May 07, 2009 | HP Compaq FP5315 15" LCD Monitor
Warcraft 3
Have you updated your graphics cards recently?
Dec 25, 2008 | HP Compaq FP5315 15" LCD Monitor
Microphone
there is NO microphone on the fp5315 monitor. I have two of these monitors myself .
Aug 03, 2008 | HP Compaq FP5315 15" LCD Monitor
Compaq FP 5315 monitor-Replacement of Power board
There are also 5 or 6 bad Capacitors on on top but as far as i know the only way to fix these power boards is to replace the componets themselves as you can not buy a power board.
Jan 26, 2008 | HP Compaq FP5315 15" LCD Monitor
Monitor blinks
your monitor haveing power supply problume it is not swtiching properly
ashok
Jan 21, 2008 | HP Compaq FP5315 15" LCD Monitor
Lcd monitor failure
your monitor need to be service so take it to service center if you are in mumbai you can call for service
Ashok
9322133048
Nov 11, 2007 | HP Compaq FP5315 15" LCD Monitor
Compaq FP 5017 15" Flat Panel LCD Monitor Logo
657 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
