Question about Norcent Technologies LT-2725 27 in. LCD Television
Dead no power
I AM TV TECH AND AM
WORKING ON MODEL LT2722
IT HAS NO POWER
LED DONT LITE UP
I CHECK POWER BOARD , IT
LOOKS OK TO ME CAN YOU HELP
Hi change ic surface mounted u405 on back of signal board
Posted on Dec 26, 2008
Thanks for the response on U405 on back of main board. I changed this to fix the issue as well. Even though the post is old it worked great.
More info on issue was TV was completely dead & wouldn't power on at all (even the standby LED wouldn't light up at all). I verified power supply board was good by measuring the power board & main board connection cable & was getting the right Volts DC needed on the cable pins into the main board.
I used part # MAX810LEUR+T as a compatible part (ordered from Digikey. It's a very small surface mount 3 pin component & was a bit of a pain to solder on.
Posted on Apr 22, 2013
Model DP26649 No pic no sound no warning. Shut off last night and dead today. Will be 2 yrs old in August.
Now the tv it is completely dead no LED power light indication is on at all or the tv power LED light indication blinking too?Check the power source?Tries tv unplug,replug it back about an hour later for the tv do a resetting itself back to the factory setting,tv should be working again.If not the tv power supply board it is dead,that the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jun 17, 2011 | Sanyo DP32746 32 in. LCD Television
Tv light flashed and cut off . turned back on and green light turned red and blinked 6 times pause then 6 blinks etc... tv will not power on. checked lamp seems to be ok. checked power supply board and...
Your power supply board is not yet dead, u know basic electronics' and soldering? You have to open the back cover of the television check for dry soldering on the printed circuit board , if found resolder but if not Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem...
Nov 29, 2010 | Televison & Video
No power, tried a new power cord, still no power
Ur tv have any power lite flashes on the front power LED lite on the screen pannel?Yes,than the power supply board have dead leakage parts capaacitors,they bulges up on it top or puff off on it tops.U know basic electronic,soldering equipments and know soldering?Replaced those dead leakages gas capacitors on the power supply board.Or tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 03, 2010 | LG 50PG20 50 in. Plasma HDTV
TV won't turn on, red light flashes on TV and hear a clicking sound in back of unit is it worth fixing?
Yes,the LED power lite on the front panel stable?Yes,mean the DM power supply board is good.LED power like blinking,mean the DM power supply board is dead.DM power supply is good,still making that clicking sound,when turn on.Mean ur Blast board is dead,that the board that help to light up the projection lamp.
Jun 24, 2010 | Hitachi 43UWX10B 43" Rear Projection...
I HAVE A 37" LG TELEVISION AND THE SCREEN AND SOUND JUST WENT OUT THE POWER BUTTON IS ON BUT NOTHING. IS THIS WORTH FIXING OR SHOULD I JUST TRASH IT...THE NUMBER ON THE BACK IS 37LC2D... CAN ANY ONE HELP...
The power LED lite indicator is solid green,but no pic.?This tv is very fixable,take it to the shop,they will order a refurbish circuit board call a T-con board from some wesites source and repalaced it for u.This should cost u half the price of a new tv.If ur power LED lite indicator is blinking and no pic.,they will replaced defective leakages capacitors in the power supply board,or replaced the power board all together.
Apr 28, 2010 | LG 42LC2D 42 in. LCD HDTV
I have a sharp 37" lcd tv,model # lc37sb24u. no pix or sound, power lite comes on about 10 seconds then power and opc lites alternate on and off. thanks RON
This problems very common in Sharp LCD tvs.The Tuner signal board have problems,every times the power LED,OPC LED lites up,just push the power button on again,wait see if the LCD backlight lite up and works,not the Power lite and the OPC lite LEDS flashes again.You,just have to push the power button again,sometimes u have to push the power button at least 6 or 7 times to get the Power LED stable,and then LCD backlight,come on than the tv work.Not sure,but if the Power and OPC lites keep flashing,after u pushes the power button at lest 10 or 12 times,and the LCD backlight dosen't come on and the tv don't work.I think,it time to change the Tuner board is completely dead.I have a Sharp LCD tv, I do this everytimes pushing the power button at least 3 or 4 than the power LED stable,and the LCD backlight come on than the tv work.Not a plaw in the power supply like those capacitors in many LCD models tvs,but some included Sharp Tvs is the Tuner signal board is not very good in design,use the tv awhile the Tuner signal board have problems recieving the power to it Tuner board components.
Apr 15, 2010 | Sharp LC37SB24U 37 in. LCD TV
42PFL5432D/37 WONT COME ON DEAD/NO POWER LED DISPLAY/2 YEARS OLD
An issue i came across with this particular model tv was there were two (2) 3300 micro-farad 25v caps on the power board that have gone bad, preventing the tv from starting up. I replace those two capacitors and it started right up! I suggest having a tech do it, unless u have experience with electronics. I cannot be held responsible for any damage done to your tv, warranties voided, or shocks you may receive. but that should get it to start back up.
Dec 17, 2009 | Philips 42PF9631D 42 in. Plasma Television
Roland JC-55 amp stopped working
Sounds like a transformer problem or something else in the power section..maybe even a transistor....since the LED status light would be direct from DC power. Take it to a trusted audio electronic tech and get it looked at. Keep in mind that these amps are about $150-$200 used on Ebay so don't spend too much getting it fixed if it is indeed a transformer. I'd definatley get it looked at. I have a JC-77 and it rocks for clean!
Mar 23, 2009 | Music
Vizi L37 - won't turn on
ok I'm just going to copy paste here being as this might work for you guys, I tried it my self but had no luck but my issue has slightly different behavior(led goes green for a second before dieing). any event here is what I found:
source
All,
Check this out:
kNOBLE
VIZIO
L32
LCD
DEAD WITH AN AMBER LIGHT
Do Not Order A New Board For This Vizio Model. You Can Fix This Problem For Pennys. Problem: Will Not Power Up Amber Led Only. Hint: No Reset To Operate Micro (Brain Dead) I'Ve Seen (3) Various Fixs Below, One Uses A Diode, Other Uses A 10k Resistor, Try Either. All 3 Will Work, Diode Works Best For Me This Same Reset Ic Goes Bad On Other Visio Lcd & Plasma Tv'S. #1) You Remove Smd U26 On The Video Processing Board And (Add) Put A 10k Resistor Across Pins 2&3. U26 Is Near The The Tact Switch. #2) Remove U26 And Solder A 10k Tru 100k Resistor Across Pin 2&3. Start With A 10 K First. #3) Remove Reset Ic Near Tac Switch Replace With 1n4148 Diode (Nte519). Vizio Tech Support: (Valid - I Tried It) 1-888-849-4623 Opt 4 Technical Support: 888-849-4623 Try Extension 1669 (David). Hugo Carrera Parts Department 877-668-8462 Ext 1814 Vizio Inc. 320a Kalmus Drive Costa Mesa, Ca 92626 E-Mail:Hugo.Carrera@Vinc.Com
Aug 13, 2007 | Vizio L37 Television
Norcent Technologies LT-2725 27 in. LCD Television Logo
297 people viewed this question
Top Norcent Technologies Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
