How do I replace the lamp in my Samsung DLP?
I took the back panel off my tv, but I don't know how to remove the lamp to replace it. Can you help?
  • 3 Answers
Http://guides.fixyourdlp.com/guides.php
There is a list of just about all the makes and models, including Samsung!
Posted on Jan 28, 2009
We replaced the lamp on our Samsung 50" dlp model HL-S5086W tv about 3 weeks ago. Just recently, the tv started turning off by itself and the red standby/temp light and the green lamp light flash for a few...
    1. Ensure that the TV is off. It may be advisable to unplug the TV as well.
    2. 2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
    3. 3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
    4. 4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
  • 5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
  • 6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
  • 7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
  • 8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
  • 9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
  • The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
  • Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
  • If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
  • Make sure your TV is off and cool when performing this procedure.
  • Jul 31, 2010 | Samsung HL-S5086W 50" HDTV
    Samsung tv turns off on its own model hls4266wx
  • Mar 12, 2010 | Samsung HLS4266 TV
    Please Help. I have a 56" DLP Samsung and the lights just flash
    Sounds like the lamp might be burned out. The Lamp should be replaced every couple years. If they are not replaced they will eventually burn out. Replacement is not that difficult and just requires a screwdriver. The lamp is located at the back of the DLP TV on the left side. The lamp can be purchased online from Samsung for about $130 dollars. You might be able to find a aftermarket one for less. Just use your telivision's model number located on the right side of the TV on sticker to cross reference the bulb that is needed or there might be a sticker on the back at the lamp housing that has the lamp part number. And make sure to spend the extra money and get the Lamp with the housing together. You can buy just the lamp for cheaper but that will require you to remove the old lamp from the housing and they are fragile. Much easier installation with the housing/lamp combo.
    Jan 12, 2010 | Samsung DLP HL-P5663W 56" TV
    I have had this Samsung DLP HL-P 4663W for about 3 years now.
  • Sep 17, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
    My 56 inch hi-def projection samsung tv turns off automatically
  • Mar 06, 2009 | Samsung DLP HL-P5663W 56" TV
    Samsung DLP4663W
  • Oct 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
    TV TURNS OFF AFTER 20-30 MIN
    May 28, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
    TV turns off by itselft
    Feb 27, 2008 | Samsung HL-S6186W 61" HDTV
    Televison & Video Logo
    Top Televison & Video Experts
    Marvin
    Marvin
