I need to change the settings for the touchpad/touchmouse on my new advent 6311, I have looked in control panel, hardware devices, and everywhere I can think to find the settings program but nothing is apparent. Can anyone advise as to where I will find the settings? Thanks millions if you can!
  • Anonymous Nov 25, 2008
    I have the same problem. No touchpad is shown in device manager; just the mouse. Do I need a Synaptics driver?
  • Lalit Varadpande
    Lalit Varadpande May 11, 2010
    is the software installed?have u looked at the mouse properties and the system tay icon?
  • 903 Answers
Try going to control panel>system>device manager>pointing devices and right click on touchpad etc..and go to properties
I hope this helps
Posted on Nov 17, 2008
Cursor does not move when running my finger over the touch pad. Thank You Bill
1. Adjust the touchpad sensitivity from the control panel. Perhaps lessening the sensitivity will solve the problem. In Windows OS go to your control panel, and select hardware and sound. Then click "mouse," and when the new window pops up select the settings tab. From there you can adjust the sensitivity. If your mouse came with its own software you may be able to adjust the settings from the system panel. Hover your mouse over the icons near the system clock, and look for an icon that is titled touchpad, or mouse. You can click this icon and adjust settings.
2. Clean the touchpad with rubbing alcohol in case there is a grease buildup on the touchpad. This is the most common cause for touchpad failure.
3. Remove the touchpad drivers from device manager and reinstall. Sometimes there can be driver errors that are preventing the touchpad from working. Device manager can be accessed via control panel in Windows systems.
4. Replace the touchpad if none of these steps work. Prices can range from $15 to $50 plus labor rates. It is best to let a computer professional change this since major disassembly is required to remove and replace the touchpad, and many fragile components will be exposed during this process.
Hope this help. Goodluck!
Mar 28, 2011 | Computers & Internet
HOW TO UNLOCK THE TOUCH PAD?
1. click start > Control Panel > Mouse (with Vista/Win 7 change control panel from category to icons)
2. in Mouse Properties window click Device Settings tab
3. click Enable button for the Synaptics TouchPad
If the TouchPad already enabled and you can't get any reponse from it, then problem due to hardware which requires service by a qualified technician as self-service of the hardware can void your warranty.
Mar 18, 2011 | Dell Inspiron 1525 Notebook
How to enable touchpad I disabled by mistake and
Step 1: Click on Start and then click on control panel.
Step 2: Hardware and Sound......Devices and Printers....Mouse.....Mouse Properties.....Device Settings.....Touchpad.......Enable........(Windows 7).
In Windows XP
Dec 18, 2010 | Dell Inspiron 1545 Notebook
My touchpad clicking capibility is not working
Follow these steps to change the mouse settings.
From the Start menu, click Control Panel. With Control Panel in Category View, click Printers and Other Hardware.
In the Printers and Other Hardware window, click the Mouse icon.
In the Mouse Properties dialog box, click one of the tabs at the top, and then select the mouse settings you want to change.
To save the changes, click OK.
This is the solution that I found on the Gateway help site and if fixed my issue.
Follow these steps to change the touchpoint or touchpad settings.
In the Mouse Properties dialog box, click the Device Settings tab, and then click Settings.
To modify a touchpad setting, click the + in front of the setting you want to change, and then select the setting you want to use.
Jul 14, 2010 | HP Computers & Internet
How do i turn off the touchpad on my laptop
There should be an icon in the control panel to allow you to change the settings on the touchpad. One of the settings should allow you to turn it off.
Feb 01, 2010 | ASUS 90-A4C1K1000 Keyboard
How do I disable touchpad when mouse is used DELL 1525 vista home
Follow these steps to change the touchpad settings on your laptop:
1. From the Start menu, click Control Panel. With Control Panel in Category View, click Printers and Other Hardware.
2. In the Printers and Other Hardware window, click the Mouse icon.
3. In the Mouse Properties dialog box, click the Device Settings tab, and then click Settings.
4. There is a setting calleed "Disable Touch Pad when USB Pointing Device is present"
Jan 28, 2010 | Dell F3534 Touchpad
I have been having a problem with the cursor jumping. I would like to turn off the touchpad but cannot find that application. HELP!
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Oct 11, 2009 | Dell Inspiron 1420 Notebook
Disable track pad when using wireless mouse?
Go to your control Panel and right click on the "mouse" selection', then go to "Device Select" . Then click on the "Disable".
May 11, 2009 | Computers & Internet
Disable track pad when using the mouse on advent 6311
Do you want to disable the onboard touchpad while you use an external mouse?
To do this there should be a key sequence on the laptop like Fn+ F8 (or another key) it has a mouse symbol on it.
May 11, 2009 | Acer Aspire 3680 Laptop
My toshiba laptop is brand new and the touchpad is not working, the cursor doesnt move at all unless I put a mouse...
Go to the control panel,
  1. you may need to change the control panel to classic view in the left pane, if the icon's are not present.
  2. click on the mouse icon
  3. in the mouse propertie's box go to device setting's
  4. in the device window highlight the touchpad
  5. check to see if it's enabled
  6. if it's enabled and still not working click on setting's
  7. go through all the mouse setting's to make sure there configured properly
  8. if the touchpad still does'nt work go to hardware in the mouse propertie's box
  9. highlight the touchpad in the device name window then click propertie's
  10. check to see if it say's, this device is working properly
  11. if you still have problem's with the touchpad use the troubleshoot tab to resolve the problem or you can try updating the driver.
Apr 17, 2009 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
