Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Ice maker leaking
My icemaker leaks water that forms a large icicle in the icecube tray. whats the problem causing this? i have to remove the ice formation at least once a day. Ive tried changing the filter. Nothing has worked.
  • 3 more comments
  • Cricket5 Mar 23, 2008
    my ice maker leaks and now it no longer makes ice
  • oscar b May 19, 2008
    I believe too much water is coming into the ice maker, resulting in overflow of some water into the ice cube container and resultant melted mass of ice in the right side of the container. Is there an adjustment for the amount of water flowing into the ice maker at each cycle?
  • Anonymous Jul 10, 2008
    how about a solution?
  • Anonymous Feb 01, 2009
    I have the same problem. Too much water is coming into my ice tray. This ends up as a big chunk of ice in the catcher.
    How do I turn the water down
  • Anonymous May 24, 2009
    I have the same problem ... has anyone been able to fix it without having to call and/or pay for a repair?
    Problem Solver:
  • 10 Answers
Sometimes the frozen chunk of ice in the back of your ice tub is caused by the tub being overfilled. The ice cubes pile up so high that they come in contact with the defrost heating element in the bottom of the ice maker. This melts the already formed cubes and form a blob of ice in the rear of the tub.
If the "icicle" is forming even when the tub is relatively empty, then it is probably a leaking solenoid valve. This is an electric water valve that opens and closes according to demand. Like any valve, it has seats that eventually leak, especially in areas with hard water. This will need to be replaced. Water filters go a long way in increases the usefaul life span of the valve and will also improve the ice quality.
Posted on Jul 24, 2009
  • 42 Answers
Too Much Water! The ice maker normally takes about 8 oz of water for a fill; try this test. Measure exactly how much water is dispensed from the water dispenser; it should be equal to 1 oz per second. This water is fed from the same supply line as the ice maker. If you are getting more than 1 oz per second (test it for 8 seconds, of course), try adjusting the metering valve, if you have one, where the 1/4" line taps into the house supply. A new filter could also adjust the flow back to normal.
Posted on Jun 09, 2008
  • Jerry Mace
    Jerry Mace Jul 15, 2009
    Follow-up: Now that the water flow is corrected, if you still have water dribbling into the icemaker and causing the iceberg, the water inlet valve will need to be replaced. Some models have a single, a double, or (like mine) a triple valve. Order the right part by checking the number on it FIRST, yes, pull the fridge out and MAYBE get a little dusty, but get the right part number - - mine was $42.
  • 237 Answers
If the water is still dripping slowly after a normal "water fill" cycle, the Ice maker water solenoid valve is likely leaking by.
Posted on Dec 04, 2006
The timer that controls when and how much water fills the tray is bad. i have replaced the entire tray unit that includes a timer on a Maytag (2 different refrigerators) problem solved
Posted on Nov 30, 2010
I'm going to check and see if this works for my Frigidaire FRS20ZRG. Thanks...
Delsey42
Posted on Jun 04, 2008
4 Suggested Answers
SOURCE:
  • 1314 Answers
SOURCE: ice maker leaking water
replace the icemaker fill switch in the icemaker its self its a micro switch behind the gold panel on the front of the icemaker
Posted on May 13, 2008
tech master
  • 120 Answers
SOURCE: Kenmore Coldspot Side by Side Model #57562791
hi debie normaly the life of these ice maker range from 3 to 4 years then the wtr hardness eats them up and the mold start leaking wtr but if is a fairly new model the you have a faulty wtr vale that is not closing sending wtr all the time to the ice maker repl the ice maker is you see is peeling of the texture inside if it is ok repl the valve
Posted on Oct 17, 2008
  • 744 Answers
SOURCE: Icemaker leaking causing icicles
Is it overfilling with water? If so, it may be an problem with the fill valve leaking slightly. I say slightly because if it were a large leak, the freezer would have frozen puddles in it. Also check the water chute to be sure the water is all going into the freeze tray. Sometimes they can work loose.
If the seam is leaking, there could be a crack in the housing - not sure that's repairable - sometimes epoxy will work (5 minute, 2 part) but it can be difficult for glue to hold on the type of plastic used in an ise maker housing.
Posted on Mar 27, 2009
Ice maker overfills the ice tray, ejecting large block of ice instead of individual cubes.
What is your model number? Sounds like you may need a new icemaker. Sometimes when the icemaker motor goes bad it causes the icemaker to keep filling even though it hasn't kicked out the ice in there. Also, are you sure there isn't 2 valves on the refrigerator?
Nov 15, 2015 | Refrigerators
Icicle are forming around icemaker port inside of
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Sep 17, 2009 | Kenmore 53542 / 53544 Side by Side...
Icicle are forming around icemaker port inside of freezer compartment drips seem to come from around inmaker feed water area.
Sep 17, 2009 | Kenmore 53642 / 53644 Side by Side...
It's my mother's Side by side Kenmore (4 yrs old). Iciles appear to form UNDER the icemaker unit. Filter has been changed and temp adjusted. What could be the problem?
it is possible that the tray itself has a crack in it. The icicles tend to make me beleive that you have a cracked tray because ice accumulates in the form of a cicle by consistantly dripping, running downward and over time the freezing occures . You might take food coloring and mix with water. Pour this mixture into yhe icemaker tray with the unit off and let it sit. If the tray is leaking the food coloring will let you know, if no leaks then it has too much water being allowed into the unit or too much water pressure. Good Luck
Dave
Jul 17, 2009 | Freezers
Mar 27, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water leaking underneath icemaker, dripping into ice tray
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the first one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Feb 20, 2009 | Amana DRS2462B Side by Side Refrigerator
Water runing down back side of icemaker and forming icicle.
If it is running down the back of the icmeaker then you need to make sure the inlet tube is properly installed into the fill cup on the icemaker. If the tube is in the right place then your icemaker fill level needs to be adjusted.
Dec 07, 2008 | Refrigerators
Ice maker leaking
what is the model number of this fridge?
HTML clipboard_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
May 19, 2008 | Sub-Zero 632 / S
Ice maker leaking
what brand refrigerator?
Nov 27, 2007 | Refrigerators
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
5,847 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Paul Carew
Lawrence Oravetz
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
