Question about Xara3D 5
Loaded zara 3d from disc
I was told xara had loaded successfully but every time I click on the icon to open it the following message comes up:
FAILED TO LOAD LANGUAGE MODULE
Help!
Cheers Jan
ps. I need to use it like now!!!
  • jday860 Nov 18, 2008
    still haven't resolved this, does that mean if I don't pay you I don't get an answer?
    Jan
2 Suggested Answers
AndrexT
  • 16710 Answers
SOURCE: Could you please supply Xara 3D Maker 7 Serial key?
No, because that is ******* and termed Piracy.
Respectable websites do not help counterfeit software.
How would you like it is you spent time and effort employing software designers, got packaging and advertising paid for, and then someone came and gave it all away for nothing?
Posted on Jan 07, 2017
I want xara 3d 7 serial key
Spend the $40 and buy it. They will give you a serial key for free when you purchase the software
Jul 20, 2017 | Xara Computers & Internet
Loading nova photo explosion version 3
to quote the website:
We have found that this is often due to other programs running in the background during the time of installation. We recommend that you try the following:
  1. Click the Start button.
  2. Click the Run option.
  3. On the Run window, type in "msconfig" without the quotes in the Open field.
  4. Click the OK button. This will open the System Configuration window.
  5. Click the Diagnostic Startup option on the General tab.
  6. Click the OK button.
  7. A window will open with a message indicating that it will need to restart. Click the Restart button.
Once the computer finishes restarting, make sure that you disable both your virus scanning software and firewall software, if you have either installed. Then, start the installation over.
Once the installation is completed, perform the following to return your system to its previous state:
  1. Repeat steps 1-4 from above.
  2. Click the Normal Startup option on the General tab.
  3. Click the OK button.
  4. A window will open with a message indicating that it will need to restart. Click the Restart button.
and here
is a vista update
Dec 15, 2007 | Nova Development Photo Explosion Deluxe...
Jan 07, 2017 | Xara Computers & Internet
I had reason to uninstall lightroom 9 from my computor. I am now trying to reinstal it but the disc will not run Help
Hi Maureen, If you are not referring to your optical disc drive failing to work, then you can do this. Put the disc into your drive and wait a couple minutes. If a window comes up asking if you would like to install the program follow the installers directions. If a window does not come up go to 'Computer' and there you will see drive Icons. the icon labeled CD Drive or DVD RW Drive is where your disk is. It's the Icon with a disc. Right click the icon and at the top of the menu click 'Open' or 'explore' This will open the disc and allow you see the contents of the disc. You can now manually install by double clicking the installer. Good Luck
Feb 12, 2014 | Computers & Internet
Xara 3d maker
Your copy is pirated and Fixya doesn't support software piracy!
The Tinker
Nov 30, 2013 | Xara 3D Maker 7
Xara 3d maker 7rar requires password to extract
Programme can not be unrar due to the lack of rar passord
Nov 30, 2013 | Magix Xara 3D Maker 7 for Windows 1-User...
I load a dvd in the sylvania sdvd 9009 player and it says no disc after loading
If the DVD loads, there should be something on the display that indicates it is being read (maybe a spinning disc icon). If it tries to read, then displays the "no disc" icon it means either that particular DVD can't be read or the drive has failed. If you try another DVD and get the same result, you can be pretty sure the drive has failed
Dec 16, 2012 | Televison & Video
Pioneer DVD 717 - Not Loading Discs Whenever I load a disc, the player spins the disc for a moment before slowing down. to a stop. It repeats this around four times in succession before it then opens...
Hi msaslloyd ,
This could be because of a damaged lens , where the dvd player tries to recognize the disc but is unable to do so and then either sends the disc back i.e. the tray opens up or the message no disc loaded is displayed.
I suggest you to :-
  1. Clean the lens with a lens cleaner available in the market and load any disc in the player to check if it's working fine.
  2. Get the lens replaced from the market and the problem should be solved.
Hope this helps ..:)
May 10, 2011 | Pioneer DV-717 DVD Player
How do i install the netopia 3d reach?
you can install it via disc which is provided to you........insert that disc there u willl find the option or icon by name setup......click on it and follow the instructions.....your software will be installed........
or you can directly install it from internet....
Aug 11, 2009 | Computers & Internet
"Failed to connect to player, Operation timed out"
I would recommend wiping and rebooting your player:
Windows only.... Please post if you are not using windows...
Open My Computer with your Rio plugged in.
Right click on your Rio player and click on format.
Leave the default values - if it asks you something then use your initiative.
Then click on format.
Then when it has finished formatting go to your firmware (can be downloaded from: http://www.digitalnetworksna.com/support/rio/product.asp?prodID=112).
Follow the instructions and then it should load the firmware onto your player.
When it has done then your player should (in theory!) work properly.
Hope this helps
Mowcius
Feb 17, 2008 | Rio Nitrus MP3 Player
Computers & Internet Logo
69 people viewed this question
Top Xara Computers & Internet Experts
Mark
Level 1 Expert
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Xara Computer and Internet Expert? Answer questions, earn points and help others
