Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Won't fill with water
The washer will not fill with water, i turn on and it goes right to agitation...
  • Anonymous Mar 16, 2014
    the washer will not fill with water, just goes straight into agitation when turned on.
    President:
  • 878 Answers
First eliminate the pressure switch. Remove the two screws in back of the consol and flip it up. On the left you will see the pressure switch with a 1/4 inch rubber tubing going to it. Pull the tubing off the switch and see if the washer starts filling. Blow through the hose to see if it is clear. Don't leave the hose off because the washer will over fill. Catriver..post back.
Posted on Dec 03, 2006
  • malinto_04 Jul 29, 2011
    but what if this dose not solve the problem
SOURCE:
Frigidaire washer goes straight to agitation and won't fill with water.
IN UNIT THERE IS A SENSOR OF PRESURE WICH HAVE A TUBE FROM WATER CUVA , and when fill water presure high from tub activate membrana and cicle startit ;may there a problem and also at ev . of in water, chec connection and clean dirt but with main out
Nov 04, 2012 | Frigidaire Washing Machines
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washer won't fill
Hi pollystepp.
Without knowing the make and model, a basic answer to this problem is that the fill switch has gone bad. If your machine proceeds to agitate and spin without water, the washing machine 'thinks' it has water in it and this happens when the fill switch is stuck open. Rarely, the tube that goes from the tub to the switch may be clogged which may cause the switch to remain open.
Good luck from Detroit, MI.
Oct 20, 2011 | Washing Machines
Kenmore washer 90 series continue to fill w/water. Load size won't stop the fill... had to shut off water source. won't get to agitate phase... just want to stay at fill stage... can drain, spin,...
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
Aug 20, 2011 | Washing Machines
GE Spacemaker Washer/Dryer. Model # DDPI380GAMWH. Water won't stop filling. It continues to fill during all cycles. Fills during agitation. Agitates inproperly. It agitates in short pulses as water...
Thanks for choosing FixYa and welcome. This sounds like a problem with the water level switch in the washer. It controls the amount of water entering the tub. It is probably defective. You may want tomake sure the switch is getting power first by testing the wires with a voltage meter.
Jun 18, 2011 | Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Washer functions but doesn't fill with water, with
if it agitates without water then the fill pressure switch is stuck , this will lead the unit to beleive its full already.
replace the water level/fill switch for the fix.
Phil
Jun 10, 2009 | Washing Machines
My machine will not fill with water.
It sounds like the switch that controls the water level is stuck ,thereby telling the controller that it is already full of water, causing it to start agitating right away.
Give the top of the console panel a good tap, this may release the switch if it is stuck.
If this does not work, then possibly the pressure hose is blocked that controls the switch.
Plz rate my solution.
Thanks.
Jan 02, 2009 | GE WBSR3140DW Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
52 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
