Computers & Internet Logo
Posted on May 10, 2017
Notes sustain forever on reason 4! cant turn it off!
I have an edirol pcr 800 set up playing through my macbook with reason 4. whatever notes i play sustain forever and will not stop. i thought it was a controller issue but the edirol works fine with all my other soft synths like massive and absynth.
the issue does not arise when i press the keys on the bottom of the page beside the arrange window, only when i use the edirol so im guessing the problem is with the connection between the edirol and reason.
anything obvious im not doing?
thanks,
David
2 Related Answers
Anonymous
  • 32 Answers
  • Posted on Dec 28, 2008
SOURCE: NO SOUND on Reason 3.0!!
click on file, preferences, make sure your sound card is enabled as output
Anonymous
  • 3 Answers
  • Posted on Jan 20, 2009
SOURCE: notes don't stop even after I release the key
The keyboard  is not sending a note off instruction after the key is released. Try checking midi preferences in reason.If your using a Mac check that the edirol is present by launching Audio MIDI Setup utility located in the utilities folder. You can download the latest Mac driver from Roland below: EDIROL PCR-300 32-key MIDI Keyboard Controller :: Download
I have an Alesis io2 audio-interface and a macbook pro. I'm using garageband software. I plug the interface into the macbook before I load garageband. (So standard protocol.) My problem is that when I...
sorry about your problem, i have the same issue. i think i solved i'm by using my midisport 2x2. Alesis fucked up on the midi with this unit. use an other midi sort, and that may fix the problem.
3answers
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
I need new rubber contact strips for my pcr-30
These are notoriously unreliable - the contact pads age whether they are played or not.
Roland/Edirol should be able to supply a set of replacements if you can track down a service agent.
In my experience ( in the UK ) their service sucks.
They have an ex-employee who does the warranty repairs from shed at home and that's it!
They won't deal direct with the public and their sales chain can't be bothered to order parts.
Good luck.
Edirol pcr 50 dont know how to work
Dont forget that the PCR50 is a Midi controller and as such has no "sound" of its own. You must have Midi compatible player or composer type software (like Reason, Cakewalk, Sonic, etc) to link up to the PCR50 to get any sound.
Notes don't stop even after I release the key
Edirol PCR-50 for mac OS X v10.5
Yes it is. I have one and have used it on mac OSX from 10.2 to 10.5.
2answers
Edirol UA 4FX _Short Audio Signal dropout
try runing a cleaner ccleaner and ace utituies ok that stop those hickups give a atry make pc run alsot faster
Top Propellerhead Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Propellerhead Computer and Internet Expert? Answer questions, earn points and help others
