Question about JVC Cybercam GR-D93 Mini DV Digital Camcorder
Divice not found
While i am conection to my pc it is showing an error named
"Divice not conected"
can you solve this problem
  • 1 more comment
  • lisu Nov 17, 2008
    Can you send its driver software for GR-D93AS JVC camcorder
  • Anonymous Feb 12, 2009
    sdasdaf
  • ewgroenendij Feb 25, 2009
    Can you send its driver software for GR-D93E
I want teken informeshen I didn't  tek  teh  hadd
what  I may  do?????????
pilesez help me
Posted on Apr 14, 2010
Usb not working any usb divice conect see msg usb divice not reconigd
Enable the USB function/ Also check if the drivers are installed in the device manager.
Jan 16, 2014 | Asrock G41MVS3 Motherboard
Error 106 (net::ERR_INTERNET_DISCONNECTED): The Internet connection has been lost.
i'm not sure what the actual problem is, of course it's going to say the connection to the internet is lost if you disable the wireless adapter. what exactly is the problem?
Feb 26, 2012 | Computers & Internet
I lost my eternet connection from the tower bought an eternet adapter will not work can i replace the ethernt port in the computer.or what can i do I was told my hard drive was gone can i fie this problem
The ethernet conection it one thing and the hard drive it's other. If you lost you ethernet conection go to My computer properties an on divice manager check on network adapters. If you have a question mark, replace the ethernet adapter.
If you have problem with the hard drive ypur computer dont start still on a black screen whith a messege.
Oct 30, 2010 | E-Machines eMachines Desktop PC
Hi my name is claudia i had a wd5000h1u 00 western digital my book went i conect the divice to the computer the computer do not read the device and i can not see the information that i already save.
Try connecting the MyBook to a DIFFERENT computer.
If it still fails to show your files, then the MyBook is damaged.
Take the MyBook to a qualified computer technician for proper trouble-shooting. It _may_ be possible to "rescue" the files that you stored on it.
Sep 19, 2010 | Computers & Internet
My mobile nokia 6500 my mobile conect to pc and
try to reinstall pc suite before installing first remove the installed suite check for ur data cable verify ur usb ports
Jul 13, 2010 | Nokia 6500 Slide Cellular Phone
CANON IR 400 COPIER - ERROR - E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Sep 11, 2008 | Canon imageRUNNER 400S Copier
Extra computer connection
conect in your lan cross conection  pc to laptop .then go to network properties then go to network setup wizard & share internet conection note pc name or laptop name both two other name.
Feb 05, 2008 | Computers & Internet
Installing Hard Drive on Dell 8300
I am assuming that you are installing the Western Digital WD2500SB as a second Hard Disk in your Dell 8300. If it is connected along the same flat IDE cable as you old/original HD (Primary Master), you need to move the jumper in the WD for it to be as the Primary Slave. Instructions and illustrations are normally printed on the sticker atop the HD. If you are connecting it to the 2nd (Secondary) IDE, pls verify that it is not in conflict to any other device attached to it such as your CD/DVD. At any time, only 1 can be a master and the second device be the slave.
To verify that indeed your wiring/jumper and settings are correct, you can go to BIOS/CMOS setup immediately after powerup and determine if your PC has auto detected the new HD as well as the old/original HD & CD/DVD.
If for wahtever reason, the PC will not auto detect the new (Western Digital WD2500SB) HD and since it is new then, it should still be covered by the warranty and you can ask for a replacement.
If on the other handyou would want it to the the primary master and you would like to run your PC's OS on that new HD, you would need a CD installer/recovery to re-install the operating system.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 01, 2008 | Computers & Internet
Network
hii you conect net server pc . all pc conect in switch ..then your name all pc diffence .. and net conect server pc then go net conection dailbox properties ..networking ....enabil network conection then so server pc auto ip address....apply ok  done
Jan 08, 2008 | Computers & Internet
JVC Cybercam GR-D93 Mini DV Digital Camcorder Logo
280 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
