Question about Gateway 450ROG Notebook
Laptop overheating When working on my laptop, it gets so hot. it's usually on my lap. Any suggestions?
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    Thank you LaptopExpert. I was going to tell the poster the same thing. Glad you caught it.
    y2kharmony, you owe the laptop expert a "Fixya"!
  • 1,498 Answers
Concur Wayne.
LaptopExpert is exactly right in his diagnosis and all aspects of his solution.
Well done people
Posted on Nov 18, 2008
    Problem Solver:
  • 6 Answers
Dust, Hair, Paper, Feathers, CRUD and other problems.
Laptops must NOT be used on your Lap, bed, carpet, or any other surface that cuts off the cooling air supply.
Remedy: Using canned-compressed-air, blow out all the crud.
If possible, use a toothpick to hold the fan from over-spinning.
If the air intake is covered by a "screen", poke holes, cut it out, or otherwise remove it. Check BIOS for fan-control options.
Posted on Sep 02, 2011
    Problem Solver:
  • 8 Answers
The Gateway 450 series is notorious for overheating. The P4 series does get a good bit hotter than the Centrino series but still that is a mute point over time. This high amount of heating also leads to GPU failures which is fairly common in this series, especially in the 450's with the M9 ATI onboard although still extremely common is failures with the M7 ATI GPU's. I do agree that you need to blow out the vents on the back of the laptop. I would not try pulling the keyboard and blowing it out from that direction unless you are comfortable taking one apart. What I would suggest is going online, Newegg is awesome price wise, and checking out a coolpad by Zalman , the ZM-1000 or ZM-2000 series are great. I dont mean to scare you but this will help with the heating and will hopefully prevent GPU failure on this system.
Posted on Jan 10, 2009
  • 458 Answers
Noooo Ram Has Nothing to do with it!!!!!!!!!!!!!!!!!!!!!!
You Need To Have The Laptop Disassembled....
It Needs To Be Cleaned out Of Dust and Debris!!
THis Means Pulling the case apart and cleaning the Fan(s), the Fan Blades, THe Heatsink Fins also Need To Be Cleaned, Use A Toothbrush to clean the Fins of the heatsink...
And A Good Idea, since you're already in there is to apply Silver Thermal Compound to your CPU and GPU....
Again... Adding Ram will do Nothing For Your Overheating Issue... Cleaning It will....
Posted on Nov 17, 2008
  • 685 Answers
You need more ram this will help you
My sony lap top gets hot the fand ned to be spid up
You won't be able to do it unless it's some really expensive high end laptop. I'd suggest buying a laptop cooling pad or at least putting something under between laptop and table/your lap/bed/wahetever to make some space for an airflow.
Jan 13, 2013 | Computers & Internet
L455D-S5976 fan
Your laptop is getting too hot therefore you need to place in on a wooden surface like a table instead of your lap to prevent it from getting overheated.
Jun 06, 2012 | Toshiba Satellite L455D-S5976 Notebook
My processor is getting hot. What will be the solution.
Turn it off ... it will not get hot.
Typically, normal temperature is over 100 degrees. There have been reports of fires starting as the result of a overheated PC. I am not making the claim, I have not had this experience.
Heat is the enemy of delicate computer parts. They call them Lap Tops but you should never use one on your lap. Always place your lap top on a hard surface to insure the vents are not blocked and the internal fan can try to do its job. If you are concerned about the heat, you can get a 'cool pad' to use under your lap top. A cool pad has a fan which blows onto your lap top to keep it cool. The cool pad gets its power from a USB in your laptop. This cool pad should not be used for long periods of time on battery power for obvious reasons.
Thanks for your question at FixYa.com
Jan 30, 2011 | Computers & Internet
Will not boot but keya lite up... very hot burned my daughter.. ?
Sounds like the uProcessor overheated due to being used on someones lap?
I suggest you require the services of a Computer Tech. To solve your problem.
Jan 05, 2011 | Computers & Internet
Why does my lap top hp screen goes black seems like it is getting hot.
i think it's overheating, check the fan of your laptop if it's working it might be dirty...
Sep 03, 2010 | Computers & Internet
Why is my laptop overheating?
You can try a Targus Lap cooler to circulate the air a little better. The fan may be working but just not as efficiently as it used to. You probably have noticed that it works longer and better in cooler rooms as well. A lap cooler will help with the cooling issue.
Jul 22, 2010 | Dell Inspiron B130 Notebook
Just got the lap top back today and now i have blisters agian. I realy am not looking foward to hireing a attorney,the bbb,and any one else that will listen. If i end up with scars on my legs i will who is...
i do not work with asus but i have dealt with them numerous times and they have the best customer support i have ever dealt with. and they speak english. i would send the laptop back and have them look at it again. laptops do get very hot, they generate a lot of heat. i would suggest a laptop tray so you dont have to put it on your lap. whenever a laptop is not properly ventilated it can cause a lot of problems. including on getting extremely hot. i dont suggest you put any laptop on your bare skin.
Jul 14, 2010 | ASUS Computers & Internet
Overheating for sony vaio vgn-bx546b
Make sure that the laptop is on a hard surface. If it is on a bed or on your lap, it will get hot because the fans are being blocked up and the hot air can not escape. I hope I helped.
Jamiell
Apr 16, 2010 | Sony VAIO VGN-BX546B PC Notebook
L20 laptop overheats - disk makes beep and clicking noises
When any electronic device gets hot/overheats you will notice performance issues. Is the fan turning on/running? There should be a fan (most on the bottom of laptop some on side) that turns on when the unit get above a certain temp. Make sure thats comin on when it starts to get pretty warm/hot, also make sure you have adequate ventallation (laptops naturally get very hot no matter what). Make sure the bottom legs raise the laptop off of your table (should not sit completely flat on the table and should sit up just a little to allow air to flow underneath) or lap so air can circulate from the vents. If no fan then I would suggest replacing the fan (about $20). and see if that solves your issue.
Aug 10, 2009 | Computers & Internet
I noy surethis lap top is running the correct bios, and battery gets hot
does this only start to happen after the laptop has ben on for a while.
While more information is need, from initial thoughts the laptop could be overheating.
Jun 20, 2008 | HP Pavilion dv1000 Notebook
Gateway 450ROG Notebook Logo
332 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
