Question about Lexmark T630 Laser Printer
Lexmark T630 Hangs with Parallel Busy
I have a couple of these printers with Fax machines on them. They will periodically hang with a "parallel busy" message on the display. It cannot send or receive faxes until I print something else from the computer to clear the message.
  • 320 Answers
Try replacing the ethernet cards in these printers these have nvram chips that are known to fail. a failing chip can create stalling. t630 632 634 are the only lexmark lasers that will not boot all the way with out the ethernet card
Posted on Sep 11, 2009
  • norman steach Sep 11, 2009
    try replacing the ethernet cards in these printers these have nvram chips that are known to fail. a failing chip can create stalling. t630 632 634 are the only lexmark lasers that will not boot all the way with out the ethernet card
  • norman steach Dec 29, 2009
    try this go into the parrallel menu use the left arrow till in the display you see this hit select there are 2 setting pcl smart switches make sure both of these are set to on. then scroll to parrallel buffer select it and make sure this setting is on auto there are like 10 different settings for the parrallel buffer stting this to auto will prevent buffer over flow which may be the problem that your having.
3 Suggested Answers
anantakumarj
  • 330 Answers
SOURCE: Connect Kyocera Mita FS-1010 to Macbook (OS X 10.5)
in FS1010 printer usb port avilable u can connect the printer through usb port .
please delet ur printer driver and reconfigure it . use a usb cable to connect the printer it will work.one more u can put ur printer in network
Posted on Sep 24, 2009
benwabnick
  • 2404 Answers
SOURCE: Dell 2330dn - my printer won't print my work.
could mean that the parallel port is bad, the Operating System is corrupt, the printer is faulty.
Try installing you printer onto another computer, if you can install it on another computer and have it work then that means the printer is good.
Try another printer on the computer that is saying the parrallel port is busy, if another printer won't install on that computer then you know at that point its either the OS that is corrupt or the port is definitely bad.
Posted on Dec 01, 2009
The usb slot in the back of the lexmark is broken,
Not Usually. Replacement requires disassembling the printer to get to the circuit board, a soldering station to remove the old, and solder in the new. The reassemble the printer. Factory alignment will no longer be correct, and may be too far out of range for the user alignment procedure to compensate.
If your printer has a parallel port (most don't anymore), then you might be able to use a USB to Parallel adapter instead. You might be better off replacing the printer though, or just keeping it around for dedicated fax / copier.
Jun 22, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Every time I turn on my computer and/or Brother mfc-8220 the led displays "pc busy or fail" message. At the same time it beeps 8 times. it does this twice and then remains quiet until I send a print job to...
First of all you want to make sure you are using the most up to date drivers.
Please make sure you are using these drivers http://welcome.solutions.brother.com/bsc/public/us/ca/en/dlf/dlf/000000/004300/dlf004335.html?reg=us&c=ca&lang=en&prod=mfc8220_us&type2=1&os=92&flang=8&dlid=dlf004335
If this does not help, please try using a different USB cable.
Also make sure you are not using a parallel cable or a parallel to USB converter and you want to make sure you are not conencted to a USB hub.
Thanks,
Pat
May 11, 2010 | Brother MFC-8220 Fax
I want to know how the parallell port is configureg. baudrate. bitrate etc
The parallel port does not use bit or baud rate. These terms apply to not serial ports.
A complete description of the Parallel port operation is not possible in this forum, so I'll just highlight the differences.
First, serial transmits one bit at a time. Parallel means that all 8 bits in a byte are passed at one time. A parallel port can pass data at about 10K bytes (Standard) to greater than 1M characters per second depending on the configuration of the Port.
There are two types of parallel port connections. The Centronics or Standard Parallel Port (This is signal line activated and then is run by timing.)
For example, when the PC has data to send to the printer, it first checks that the parallel port is not busy, by testing the signal on the nBUSY pin.
If the printer is not busy, then the PC lowers the signal on the nSTROBE signal line. The printer sees the signal drop and waits about 500ns and then sets nBUSY to low and transfers the data to the printer. 500ns later, the printer will raise the ACK line and lower the nBusy line.
The high speed version of the port works off of the edges of the signals and does not use the timing delays.
For example, the PC will check the nBUSY line and if it is not busy, then it will lower the nSTROBE line. When the printer sees the nSTROBE line go low, it latches the data off of the parallel port and then raises ACK and lowers nBUSY.
So the difference between the High Speed IEEE1284 and the Standard or Centronics is the timing. Standard uses timing delays and IEEE1284 does not. Also, the IEE1284 protocol allows for communication back from the printer via the parallel data pins. You cannot do this with the Centronics port.
There are several forms of IEE1284 so yo8u have to know which forms are used by your PC. For example, I believe that HP PCs use EPP form and Lexmark uses another form of IEE1284.
Don
Dec 02, 2009 | Brother HL-2040 Laser Printer
Dell 2330dn - my printer won't print my work. It keep reading Parallel busy. What does this mean?
How is this printer connected to your computer? Is it connected by a parallel/centronics cable, or USB, or perhaps not connected physically at all, but via network (it's a network-capable printer)?
Also, you don't specify the operating system.
I would guess, that it was installed on the LPT (parallel) port, instead of a network port, and because in reality nothing is connected to the parallel port it is producing an error (explaining why it's called busy would be long and boring).
Anyway, please either check the setting of the port to which this printer is printing (find that in Printer Properties), or be more specific as to what your current situation is.
Dec 01, 2009 | Office Equipment & Supplies
Client reports display shows BUSY, but never prints. I ran the Demo Page OK. Also, 5-page print tests on USB and parallel without issue. There's no add on memory. Could the Controller Board being failing...
the logic board could cause this if the nvram is messed up. how ever i have found this to be caused by the engine board about 98% of the time. change the engiine board and your problem will go away
Jun 08, 2009 | Lexmark T520 Laser Printer
Can't receive faxes
i just wanted to know can you adjust the incoming phone calls to fax machine
Aug 11, 2008 | Lexmark X8350 All-In-One InkJet Printer
T630 cannot print color
just a wild guess. it may not be capable of printing in color.
check if you indeed have color cartridges installed.
it says B/W - Black and White.
http://www.dooyoo.co.uk/laser-printer/lexmark-t630/
escription: Model ID 0010G0110 / Lexmark T630 - Printer - B/W - laser - Legal, A4, A4 Long - 1200 dpi x 1200 dpi - up to 35.1 ppm - capacity: 350 sheets - parallel, USB
Apr 28, 2008 | Lexmark T642 Laser Printer
Can't send out fax
the number you called does not answer or busy-you may have reached a number not connected to fax or it is connected and not activated in receiving mode-check the number and call again.
if you have a message "out of memory"there is no enough memory available to send your fax.press stop/exit print the faxes stored in the memory to delete them then try again.
Mar 18, 2008 | Brother IntelliFAX 885MC Plain Paper...
I can't fax! BUSY/NO RESPONSE
go into menu
go to fax settings
find send
click auto not manual, please make sure that when you push the hook key you hear a dial tone. always reminder that every fax machine has the capablitiy of either dial or tone. now if everything is set up properly  the problem will be in the tx portion of the board. if you can link up with somebody close to you and try to transmit back and fourth that will let you know if it is their problem or your. it may not be your problem.
Oct 21, 2007 | Brother IntelliFAX 1840C Plain Paper...
Lexmark T630 Laser Printer Logo
479 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
