Question about Plumbing
Leaking shower faucet
Danze three handle - very cheap quality plastic parts wear out in mere days and have been replaced - and replaced again.
Never seen such poor quality design.
Is there a better replacement part?
Or do I need to replace with another brand?
    Genius:
  • 1,605 Answers
If you are replacing the plastic parts more than twice a year, that is too much already.
replace with a better brand.Price Flish, American STD, etc..............
Posted on Nov 18, 2008
We were trying to stop a leak in a danze songle handle shower faucet now the hot water won't turn off whar do we do?
you need a new cartridge if its fairly new. if its an older faucet it will have to be replaced, usually the hot water side warps the fixture and it leaks there nothing you can do about it except to replace it.
Aug 28, 2017 | Danze Home
How do I repair a Danze single handle tub and shower faucet which leaks benind wall when water is on but does not leak when is off?
this is caused because its not in the value...its either in the shower head seal or pipe or the tub spout...you have to turn it on and some how watch and see where it is coming from....sometimes you can pull back escushion from shower arm and look with flashlight when it is running and if you see leak where arm is screwed into pipe...unscrew and reseal with teflon tape and tighten...if not you will have to cut wall behind system and watch for area of leak...good luck
May 02, 2012 | Danze & Single Handle Tub And Shower...
Danze opulence diverter handle does not work
you have to replace diverter....if its in the tub spout unscrew and go to lowes or plumbing supply and match up style and replace...use pipe dope and screw back on tight...good luck
May 01, 2012 | Danze & Single Handle Tub And Shower...
Need an instruction sheet for cartridge replacement for Danze Sheridan tub and shower faucet
This link will get you to the Danze illustrated parts list for the Sheridan single control tub and shower valve.
http://www.danze.com/products/pdfs/D510055_ip.pdf
Aug 08, 2010 | Danze Sheridan Tub & Shower Faucet
How do you tighten or remove handle on a danze shower faucet
Not to familar with faucet itself, but on most shower faucet's, there is a screw that holds it on. Most of the time there is a plastic face plate on the front of the handles, you pop that off and the screw is beneath, as you loosen you have to hold the handle in place, otherwise as you loosen the screw it will turn the water on.
Other fauet handles will have a set screw , usually on the bottom side of the handle body,( the part of the handle closest to the shower wall, either a small flat head or allen wrech should be all you need. good luck.
Jul 02, 2010 | Danze & Single Handle Tub And Shower...
I re-installed all new parts in my 3 handle shower including new seats inside the pipe and I still get a leak out of the spout when handles are turned to off position. Is there a special way to do this?
Depending on age of faucet it may be wore in valve itself they make seat tool to use in valve to let washer seat like it should.
Brass in vavle will wear after years and won't let new washers seat to stop leak it's something you can check out.
May 03, 2010 | Price Pfister Windsor 01-318 Three Handle...
How do you fix a dripping shower faucet? It is not leaking from the hot or cold handles, but the spout itself.
if it is an old fashioned valve then there are cone washers in the valves that control on and off
they are fairly easy and cheap to replace
Jan 11, 2010 | Danze D316440RBT Fairmont Two Handle Wall...
Water leaking from tap when turned off
In order to remove the Danze handle from this particular model grasp the handle of the valve and then the body of the valve and turn the body counter clockwise in order to remove.
Hope this helps.
If you don't have a supply house near you that carries parts for the Danze products you can go to danze.com and order them there.
sanray
Jan 02, 2009 | Danze D500058BNT Parma Shower Trim Kit w/...
Plumbing Logo
198 people viewed this question
Top Plumbing Experts
Tom Chichester
Paul Carew
Are you a Plumbing Expert? Answer questions, earn points and help others
