Question about Frigidaire FMV156DC Microwave Oven
Why my microwave want heat or defrost?
Microwave want heat or defrost
  • Frigidaire Master
  • 19,396 Answers
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Posted on Apr 28, 2009
2 slices of bread wrapped in paper towel microwave set on defrost set 35 seconds caught fire
Microwaves work by friction. They blast water molecules in the food so they move fast, just like rubbing your hands together makes them hot. Some types of microwave in defrost mode actually apply FULL POWER for a short period of time so to make the product warm to the touch. This heat then penetrates down to the core of the food, ensuring full defrost. In your case the heat was sufficient enough to heat the dry paper towel to set it on fire.
Bread is better defrosted on the low power setting as sliced bread is very thin. Items should only be defrosted on the defrost setting that are thick and need to be completely defrosted on the inside. Remember microwaves only penetrate the surface of food, making that hot. Thermal conduction does the rest.
You should never use paper towels in a microwave unless the instructions for doing the food say so. You wouldn't put a paper towel in a gas or electric oven, so don't put them in a microwave.
Feb 18, 2016 | In Microwave Ovens
What buttons do i push to defrost hamburg
Check this out...
HEAT MAP Microwave- a NEW invention: http://youtu.be/ptkzzNaZb7U
Feb 20, 2015 | Sharp R-510HW Microwave Oven
Hi sharp microwave R-33ST 900w was used to defrost now won't heat anything up how do I change settings back?
It should default to the highest power setting.
If not, you can reset it by unplugging the power for a minute or two, plugging it back in, and setting the clock.
Otherwise, refer to your owner's manual.
Apr 15, 2013 | Microwave Ovens
Tapan microwave works does not heat or defrost
There is a switch on the door, If it is not closed completely, the microwave generator will not turn on. If this switch is bad the generator will not work, but the lamp and fan will turn on.
murf427
Aug 03, 2012 | Microwave Ovens
How do you defrost on the microwave
What is need to set the program, select defrost function then select the weight of the food to be defrosted and push the value of the weight. Now select the heat value and press start as the processor will then decide the time to defrost.
This is a simple program setting or else you can choose a preset heating defroster program.
Aug 19, 2011 | Microwave Ovens
My brand new Sunbeam microwave model SGG5701 will not heat. it appears to be working but wont heat food or defrost
Can not find a fuse for a Sunbeam microwave model SGG5701. Where can I find one? My microwave went out after only 3 months of having it.
Aug 15, 2010 | Sunbeam SBM1000 Microwave Oven
Not heating or defrosting although light works, timer etc works
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fjfh
May 11, 2010 | Neff H5470 Microwave Oven
Sharp microwave oven R-580D will not heat or defrost
heatman101
hljk
Mar 12, 2010 | Sharp R-1480 Microwave Oven
It runs but does not heat. last nite used the speed defrost now it won't heat for anything made a noise while on speed defrost
sounds like the magnetron may be gone on it. this creates the heat. if the unit is older, it's not worth repairing, but if newer, check you manual for the warranty. some mags have 3-5 years warranty.
Nov 13, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
HOW TO WEIGH THINGS IN MICROWAVE
the microwave does not weigh things. you need to know the weight for things like auto defrost.
1 pound ground beef... enter auto defrost ..10
will read 1.0 ... 1 1/2 pounds... enter 15 ..reads 1.5.... 1/2 pound enter 5...reads 0.5 . unit beeps half way through heating program.. open door.. turn meat over close door. will continue to defrost
Jul 02, 2009 | Microwave Ovens
Frigidaire FMV156DC Microwave Oven Logo
107 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
