Question about Canon PIXMA MP600 all-In-One InkJet Printer
Canon PIXMA MP600 Error code 300
When I try to print a file it says error 300. but i can print test pages and ink levels
  • 2 more comments
  • ruhan Nov 17, 2008
    Already tried it and it doesnt help any!  Why would i be able to print test pages but not any documents. even when i scan documents they still get imported to my mac.
  • francisderis Dec 24, 2008
    erreur 300 l'imprimante ne répond pas pourtant tout est bien connecter
  • johnbowie Dec 31, 2008
    how would you re-install the driver?
  • Anonymous Mar 11, 2009
    this is not cool. really annoying
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to re-install the driver
Posted on Nov 17, 2008
Canon MP600 printer not printing correctly
The cleaning sponges are on a spingy pad, which can get stuck because of the old ink get a bit gunky. This can cause error 5101.
Try this...
Open the bonnet, use a torch, gently tug the ink carriage to the left of the rails.
Clear any paper jammed in the right of the ink carriage.
Lightly press the cleaning sponges down, (I used a long pen)
Restart the printer.
Jan 12, 2012 | Canon PIXMA MP600 all-In-One InkJet...
I keep getting the error code U150 on my canon mp600....the ink is full??? it says the ink tank cannot be recognized on the black 8 and the red light is NOT on?????
your problem is easy to solve.
Press and hold Resume button for at least 10 seconds, if that dose not work press and hold the OK button for at least 10 seconds. This procedure will bypass the ink level detector and will continue to print as before.
Jun 05, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Cannon Mp600. I have an error code 6A00
Try
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Jan 12, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP630 error code 6502
Error 6502 is the ink tank position sensor error. Basically means the printer can't see the inks. Try reseating them. If this fails you need to send it back.
Jun 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
U043
The U043 error code indicates that an ink tank is not installed. One or more ink tank icons on the LCD should also be lit up. The lit up icon indicates the applicable ink tank. Verify these tanks are indeed fully seated in the print head and that they are lit up red.
You can also press the OK button to clear this message and continue.
May 19, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Ink Monitoring System
I have this Canon MP600 using unchipped cartridges. Once you have changed the chip over onto the catridge and inseted it should stop flashing which indicates the cartridge is located. The printer will not tell you the level of ink until you run out. When changing the chip over from original cartridge onto unchipped ensure it is not damaged and fitting properly other wise the error sign will show.The printer should print without any problems, i know you can not disable the ink monitoring system. Hope this is some help Mr T
Apr 09, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon printer not printing and gives error code U052
you have a purge unit problem, cost more than the printer is worth unless it is under warranty,
Canon small printer technician
Mar 31, 2009 | Canon PIXMA MP600 all-In-One InkJet...
ERROR U130
The remaining ink level cannot be correctly detected. Replace the ink tank and close the Scanning Unit (Printer Cover). Printing with an ink tank that was once empty may damage the machine. If you want to continue printing in this condition, you need to release the function for detecting the remaining ink level. Press and hold the Stop/Reset button for at least 5 seconds, and then release it. * With this operation, releasing the function for detecting the remaining ink level is memorized. Please be advised that Canon shall not be liable for any machine malfunction or damage caused by refilled ink tanks. See “Replacing an Ink Tank” on page 46.
Apr 10, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
773 people viewed this question
old marine
old marine
