Question about Sprint Hitachi P300 Cellular Phone
Hard Disk Drive not detected
I recently purchased a hitachi hdd model no: hdp725025gla380 s/ata. The problem is that my pc does not detect it, i have a 250 gb & a 80gb sata hard drives, which work fine but when i remove them and connect the 250gb hitachi on startup my pc does not detect the drive so i cannot install an operating system on it, do i need an installation disk?, is it something to do with the slave master port on back of unit? as this is different to my other drives, even though the sata power & motherboard connectors are identicle? please help
    Top Expert:
  • Sprint Master
  • 52,008 Answers
When installing a new hard drive, there is nothing for the bios to read to run the operating system
go to the bios , boot section and change the boot sequence to boot from cd first
then restart the computer and reinstall the operating system disc in that cd when the computer is up and running change the bios back to hdd as first boot selection
Posted on May 07, 2017
2 Suggested Answers
ybchuan
  • 201 Answers
SOURCE: Installing Hitachi P7K500 Sata Hard Drive
Windows XP does not come out to support SATA hard drive, because inside do not inclued the SATA driver, that why u cannot see the harddisk during the setup. What u can do is try to install the SATA supported OS like Windows Vista or Windows 7, or maybe can "forcely" put in the SATA driver in ur Windows XP setup CD.
YBC (/\)
Posted on Sep 10, 2009
My hard disk was being used in an HP machine now it cannot be detected by the machine or any other machine the harddisk is hitachi deskstar model HDP725025GLA380 help me
dear sir,
i think your hard disk is broken.. try to put your hard disk in a refrigerator for one night and then try to connect again to your machine, if you still get the same problem i think you need a new hard disk
May 17, 2011 | IBM HITACHI Deskstar P7K500...
I have a imminent failure and when I press F1 then I start installing Windows the system doesn't detect my HDD. I have a bad sectors and I know it. But I can't solve it. Can you tell me more information...
The motherboard is quering the 'S.M.A.R.T.' status of the disk-drive,
and the disk-drive is reporting that it is about to "fail".
So, your motherboard is showing that "Imminent failure -- press F1 to ignore this alert" message.
Take your computer to a qualified technician, to see if it is "too late" to recover any files from your disk-drive, and/or to install a new disk-drive, and to install Windows.
Nov 09, 2010 | Hitachi 60GB Travelstar 5K160 Ultra...
HDD Problem
The info is not clear as to if it is a desktop or laptop . However what u could try is reseating the hdd and also get into BIOS by tapping F2 and u would find a option to restore defaults, after restoring check if the hdd is getting detected . Also make sure that external peripheral like Ext hdd and other usb devices are disconnected. Update once u have tried this.
Apr 02, 2010 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
DIY solution for data recovery on a failing Hitachi HDD
Yes it is possible to data recover from this hard disk to using "active partetion recover v2.0 or above" software. This software should be registered and also bootable disk. It will be possible to data recover, if it will be detect in dos mode.
Procedure:
Insert the bootable disk into CD-Rom and choose boot from the cd rom and now check your disk is detected or not, if detected follow the instruction and your all data could be recover with your complete partions.
Good Luck
Dec 14, 2009 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Hard disk ST9120822AS ATA Device
If the computer cannot Bootup with an error message that hard drive nor detected or no boot device then you could have a faulty hard disk.
Go into the BIOS configuration and see if the BIOS detects the hard disk. If it is not detected then it is probably faulty.
Next reset the ATA data cable on the hard drive and at the motherboard. Bootup the computer again, also check the BIOS configuration again to see if it detects the hard drive.
If it still does not find the hard drive then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer does not detect it as an external hard drive then this proves the hard drive is faulty.
To get your computer working again, replace the hard drive and install Windows together with the device drivers and your programs.
Nov 06, 2009 | Dell InspironTM 1501 Notebook
Dell Latitude D600 with new Hitachi 30GB Drive Not Recognizing
XP install is not detecting any hard disk.
No jumpers are required for laptops, can only have one hard drive in a laptop.
Check the BIOS for the hard disk configuration, make sure that it is set on Auto (detect).
You may have a faulty hard disk, you can check it by booting up with a floppy DOS boot disk, run fdisk to see if it detects the hard disk, OR connect this hard drive to a USB hard disk adapter and connect it to a working computer's USB port and if it detects it as an external drive the it is OK.
Nov 30, 2008 | Dell Latitude D600 Notebook
Hitachi external hard drive recovery
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Aug 27, 2008 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
HDS728080PLAT20
the comp detecting the HDD is irrevelant, the fact it detects it means only it has detected the electronic part of the drive, if the actual mechanical part of the drive, and the platter are failing, then it will not work, i suggest taking it to someone who can test it.. you will know then
Dec 08, 2007 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Hardisk cant be detected
hard disk can't detected by bios.i also can't format my laptop because of it can't detect my hard disk
Sep 21, 2007 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Sprint Hitachi P300 Cellular Phone Logo
55 people viewed this question
Top Sprint Cell Phones Experts
TekkiDave
 steve
steve
celticsel
celticsel
Level 1 Expert
Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
