Question about Sony Ericsson w580i Cellular Phone
I need 2 set screen password
I was using Nokia set in which i had screen password so that none can use my mobile even when i am not in my desk. But i didnt find such an option in sony handset. In this there is only two option for security. Sim lock as well as phone lock which works when I switch off the set.
  • kannanice Nov 26, 2008
    i also have same problem ...later i use nokia mobiles i put pass code for desktop but sony it not working
  • Anonymous Feb 25, 2009
    i just need to know how to put locks on everything when i dont know my other code
  • 903 Answers
I believe that the pin only works after the phone has been switched off and then you need to enter it when you switch your phone back on. There isn't any great security with this phone :(
Posted on Nov 17, 2008
Tip
SONY ERICSSON INTERNET SETTINGS LOOP MOBILE Compatible For All W Series, K...
1. Open Menu > Settings > Connectivity tab. > Internet Settings > Internet profiles > New profile.
2. Press Add.
3. Open Name and type Loopwap.
4. Open Connect using > New Account > GPRS data.
5. Fill your parameters as shown below:
Name: Loopwap APN: mizone User id: Mobile No. Password: mmsc 6. Press Save.
7. Highlight Loopwap and press Select and press Save.
8. Highlight Loopwap and press More, then open Settings.
9. Fill your parameters as shown below: Connect using: Loopwap Use proxy: Yes Proxy address: 010.000.000.010 Port number: 9401 Username: None Password: None 10. Press Save.
11. Highlight Loopwap and press More, then open Advanced > Change homepage.
12. Select Name and type Loopwap, press OK.
13. Select Address and type http://atcafe.loopmobile.in , press OK.
14. Press Save.
15. Return to Internet profiles.
16. Highlight loopwap and press Select.
17. To start WAP session return to Menu and open Internet services.
18. Press More > Go to and select Loopwap.
19. To finish WAP session press More > Exit WAP.
on Sep 02, 2009 | Nokia 9500 Communicator
I forge me memory card passwor can any1 help me out ? Nokia x3
There are two methods:
Method 1 : Recover memory card password, using Fexplorer.
FExplorer software
As I said, we need to download Fexplorer software for this mobile hack. After installation, Browse to c:\system folder in your mobile phone. Here you would find a file mmcstore. This file is actually used to store memory card passwords in a mobile phone. Rename this file to mmcstore.txt and open with notepad. Now you will see the memory card password as it is, exactly. Mobile manufactures are now aware of this trick, and nowadays they use better encryption methods to block access to passwords.
Method 2: Unlock or reset memory card password of Nokia phones:
The first hack to recover the password of memory cards will not work on Nokia Nseries and Nokia Eseries devices. Here we will use the remote lock feature for re-setting the password. For this, go to your phones settings >Security >Phone and SIM> and then allow Remote lock. The password of your remote lock will be the password of your memory card. So if you want to change the memory card password, just send an SMS containing your remote lock message.
Nov 13, 2010 | Nokia X3 Cell Phone
My nokia n72 is turning on and off by itself and moreover to make the problem worse i sometimes cannot recieve an incoming call. please help
You need to download Fexplorer software for this. After installation, Browse to c:\system folder in your mobile phone. Here you would find a file mmcstore. This file is actually used to store memory card passwords in a mobile phone. Rename this file to mmcstore.txt and open with notepad. Now you will see the memory card password as it is, exactly. Mobile manufactures are now aware of this trick, and nowadays they use better encryption methods to block access to passwords.moz-screenshot-1.png
Hope this helps !!!
Nov 08, 2010 | Nokia N72 Cellular Phone
How can i activate gprs settings on my n73 mobile?
If your settings still don't work you can choose to manually set up your phone
1. Go to Menu > Tools > Settings > Connection
2. Select Access Points > Options > New access point > Use default settings
3. Name the connection
4. Set Data bearer to Packet data
5. Fill in access point name (APN); http://www.nav4all.com/languages/enguk/gprs_listcountries.php?m=N73%20Music%20Edition to check your settings
6. Set Username (None)
7. Set Promt password to No
8. Set Password (blank)
9. Set Authentication to Normal
10. Set Homepage to whatever site you like
11. Back * 2
12. Select Packet data
13. Set Packet data conn. to When available
14. Leave Access point blank
15. Finished
After setting up your phone continue with step 2
Step 2: Install Nav4All on your mobile phone*
Switch on the Bluetooth GPS sensor so that it can be automatically coupled to the mobile phone right after installing Nav4All.
Installation is done in four steps:
Step 1:
Switch on the GPS sensor.
Step 2:
Go to
http://www.nav4all.com/n4anews/index.php?lan= using your phone's web browser and follow the instructions. Step 3:
After downloading, Nav4All must be started up. Follow the instruction choices:
a) The display language
b) The audio language
c) The GPS sensor
Step 4:
Nav4All can be now found under Applications.
Tip: consult the mobile phone manual on how to start up the Nav4All application.
This varies from one mobile phone to the other.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Oct 24, 2010 | Nokia Cell Phones
I forget my nokia 2690 password how i find my password
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
Sep 16, 2010 | Nokia 2600
My Mobile nokia 5130c-2 Keyguard Security Code error Plz Solution
everytime i switch on mobile nokia 5130c-2. it shows message contact service and shuts down. what i have to do?
Feb 02, 2010 | Nokia 5130 Cellular Phone
I have a t-mobile sim card, but my phone is htc touch pro. The phone works fine, the only problem is I can not send or recieve text messages. My question is does anyone have the MMS settings for the Unicel...
You need the T-Mobile settings if you are using a T-Mobile SIM. assuming you are in US as Unicel not over her in UK so the settings are:
T-Mobile GPRS settings (T-Mobile EDGE settings) T-Mobile GPRS/EDGE settings for terminals (e.g., phone handsets). Some items are possibly Nokia-specific. I have found the authentication type can be either Secure or Normal. These settings should be useful for T-MobileWeb users.
APN: wap.voicestream.com IP address: 216.155.165.050 Data bearer: GPRS Username: [none] Password: [none] Authentication type: Secure Connection security: Off
APN is the GPRS Access Point Name.
T-Mobile GPRS/EDGE modem settings T-Mobile GPRS/EDGE network settings when using a device as a GPRS "modem", that is, when "tethered" to another device. Examples include connection via Dial Up Networking (DUN) Bluetooth profile, or via Universal Serial Bus (USB). These settings should be useful for T-Mobile Internet users.
APN: internet2.voicestream.com Username: voicestream Password: [none] SMTP server: myemail.t-mobile.com
Oct 15, 2009 | HTC Touch P3450 Smartphone
How do you program the i9 phone from china
I just set my gprs and wap setting and it work
follow this link :
http://theody.net/t-mobile.html
Data bearer: GPRS
Username: [none]
Password: [none]
Password: [none]
SMTP server: myemail.t-mobile.com go to i9forum.co.uk for full support topics for this phone
Mar 29, 2009 | Dual Electronics CECT P168 Cellular Phone
My phone is locked and i can not remember my sec. code
Did you mean screen lock. which nokia model do u have. default nokia password is 12345. And if you talking about nokia unlocking then you can try this blog for nokia unlock codes. ther are many useful thing for mobile phones. various service codes are available for diffrent nokia phones. If this can not solve your problem then kindly explain which mobile you have and what type of unlocking you need screen unlocking of mobile unlocking.
Jan 15, 2009 | Cell Phones
Sony Ericsson w580i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
