Question about Ruud Heating & Cooling
Ruud heat pump UPKA 036JAS, Model # 4926 M3992 3932, at times the outside unit make a noise, like a surging sound
  • 34 Answers
Probably just the defrost cycle, or could be pressure equalization
Posted on Nov 17, 2008
How many tons does a Ruud heat pump have , Model UPKA -025JAZ?
depends on what air handler its paired with, likely 2 ton. possibly 2.5
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Mar 27, 2018 | Ruud Heating & Cooling
"I have a 13 year old 10 SEER Achiever RUUD UPKA-049JAZ heat pump when you turn the AC on the ouside unit makes surging sound about every 3 min after about 45 min the ac will kick on."
sounds like compressor is going bad .. first try a hard start kit.. have staved off replacing compressor many times.. may last a long time may last 1 day
also check charge
May 20, 2014 | Ruud Heating & Cooling
Model Number: UACC-036JAS The unit works fine. The problem is it doesn't shut down after the specified temperature has been reached. The furnace blower shuts down, but the ac unit keeps on running....
Hello, usually a stuck contactor coil will cause this on the outside unit. When the outdoor unit runs continously and the indoor blower does not run no heat is being absoebed by the evaporator coil and thus the line freezes. Replaceing the contactor will fix the problem.
Aug 30, 2011 | Ruud Heating & Cooling
I have a Ruud Model # UACC-036JAS. Any idea on
Hi, yes the number you are showing me 036 indicates its a 3 ton unit. For every ton of cooling, you will have 12,000 btu's of cooling. 36 divided by 12=3 ton unit. Its showing me also its a Ruud Handler 2.0 ton which would be a Model# UACC-024JAS? If your mobel number is the one you gave me, UACC-036JAS, this is a 3 ton unit, absolutely no questions. I hope I have been of help to you. I am a licensed air conditioning / Refrigeration /Heating Contractor. Let me know if I have been of help.
Sincerely,
Shastalaker7
PS If this is a split system with the indoor air handler and condenser outdoors, both coils must be the same tonnage for it to work for you properly. You can't have a 2 ton indoor evaporator coil with a 3 ton condensing unit.
Jun 28, 2010 | Ruud Handler Air Conditioner
Does ruud unit model # UPKA 061 JAZ have a reset button
Yes it is a little red button on the back lower part of the heat pump by the lineset. it will most commnly trip in heating mode if the filter is dirty. or in A/C mode if there is an issue with the outdoor fan motor or dirty coils.
Oct 14, 2009 | Ruud UBHC Air Conditioner
Which service port is low side
The large line connected to the condensing unit wouldn't try add freon unless you know what you are doing get a licensed tec. could tell you how but it will cost $. Tom
Jun 19, 2009 | Heating & Cooling
Is ruud heat pump model upka-042jaz a single or multiple stage pump?
I NEED THE MAKE AND MODEL OF THE T-STAT TO HELP YOU
DID HE CHANGE ANY WIRING?
Jan 15, 2008 | Ruud UAKA042 Air Conditioner
Outside unit does not come on in Summer
YOUR MODEL HAS A 3-5 MIN.TIME DELAY RELAY IN THE CONDENSER CONTROL PANEL OUT-SIDE. DO NOT ATTEMPT TO FIX-IT YOURSELF ... THERE I SAID IT. IT IS WIRED INTO THE 24VOLT CONTROL CIRCUIT. THEY DO GO BAD AND OFTEN. IT IS THERE FOR A GOOD REASON. IT GIVES THE COMPRESSOR TIME FOR THE PRESSURES TO EQUALIZE INTERNALLY TO PREVENT "HARD START CONDITIONS". RUUD HAS A GOOD WARRANTY ON ALL PARTS 5-6 YEARS I BELIEVE. IF IT IS THE TIMER IT IS INEXPENSIVE ANYWAY. GOOD LUCK
Mar 25, 2007 | Ruud UAKA042 Air Conditioner
Heating & Cooling Logo
398 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
