Question about Krups Coffee Makers & Espresso Machines
Water does not heat up.
The power light is on, but nothing happens.
  • 3 Answers
Heat element burned out
Posted on Nov 17, 2008
Why did my quiet partner II whirlpool dishwash just stop mid cycle?
see this possible causes:
Water-heating cycle
heat, wash, and rinse has the 3 cicle, principal problem is the heat cycle, when the water reach the level ( by heating water elements) test the heating elements , most ot the time fixing this .the problem is o.k
Timer
sincerely. God bless you
May 04, 2012 | Whirlpool Dishwashers
I have a whirlpool gold quiet partner III Black dishwasher. All of a sudden it stopped working. I push the accusense button and start the cycle for washing, it looks like everything is working normally, I...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry . Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Power turns on but nothing happens: nothing gets hot, water doesn't run through
The heating element has gone bad... the heating of the water is what makes it go through, so that is why it is not working at all...
heatman101
Aug 15, 2010 | Cuisinart Coffee Makers & Espresso...
Quit pumping water
all lights are flashing and nothing is happening, water is full and kcup is in?? i thought turning the power off and back on will reset but even that didn't work.
Pls help
Jul 07, 2010 | Keurig B70 Coffee Maker
No heat, no light, has flow and power?
I'm experiencing the samething it's been installed 3 years and christmas day nothing. Please help.
Feb 07, 2010 | Bosch & Tankless LP Hot Water Heater
Starbucks sirena lights won't turn on
Just had this happen. Finally I let water run through the steam wand (thought it had to heat up first). Water ran through (until blue light stopped blinking) and now the other lights are blinking...we will see if it works now.
Sep 05, 2009 | Saeco Starbucks Sirena Espresso Machine
Kitchenaid double-drawer dishwasher will not start
i just installed a used dishwasher. It filled up with water then stopped. The lights are still on as far as the cycles but nothing is happening. I did the factory diagnostic test and the service diagnostic test, not sure how long each test was supposed to take because after it seemed to go through each cycle by the lights on the front nothing else happened. I waited over 30minutes because I didn't know how long this was going to take. When all the lights on the front went out I tried to turn it on like to run a wash cycle and nothing is happening and the bottom is still full on water. HELP!!
Oct 24, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Coffee Makers & Espresso Machines Logo
111 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
