Question about Bosch 300 Watts MFQ2100 Hand Mixer
My ksm9opsob kitchen aid 300 watt mixer.. this unit has very little use, nothing happens when i turn it on at all.. what is the best thing to look at so i can order parts ? thanks so much xxx Steve Gauthier Austin Texas
0 characters
1 Points
Kitchen aid stand mixer ultra pro 300 will not turn on
Sorry but we really need more info. what happened last time you used the mixer? have you pwerformed any work on the machine? have you checked the wall outlet you plug the machine into ( Iknow but check anyway)
Jan 05, 2013 | KitchenAid Food Mixers
Kitchen Aid flat beater leaves carbon on my hands and food
Are you using the white coated beaters or the burnished beaters. If they are the white coated beaters then the finish has come off and the zinc/underneath is rubbing off. Are you using the aluminum looking beaters in heavy acidic applications? if the mixer is new go to kitchaid customer support they will re-place. if your mixer is out of warranty then you need to replace it. about 15.00 t0 24.00 USD. if the problem persists then you may be leaking metal shavings from the planetary head, (I don't think it is happening but it is a possibility) if it is ground metal shavings you have a serious problem. I can't say anymore without knowing more. What application are you getting this result. is it all the time. is it after the mixer sits along time. need more info.
Aug 27, 2012 | KitchenAid Food Mixers
I stay in msia and recently i bought a PRO450 kitchen aid mixer from us. Msia's voltage is 250V while the mixer is 300 watt. I used adapter and the mixer does work but the engine is making noises. Is...
The voltage in US is 110-120 volts and the amperage is 60 amps. In your country the voltage is 250 volts which appears to be high as the general voltage in Asian countries 220 volts and the current is 50 amps You have to use a transformer/adopter which can reduce the voltage from 250 to 220 Or it is a universal adopter where this aspect is covered up. In that case you have to check the amperage. 300 watt is the power consumed and has nothing to do with low/high voltage.
Oct 07, 2011 | Food Mixers
Hello. I have a Kitchen Aid mixer made by Hobart between 1975 and 1978. It is a stand mixer with a 5-quart bowl that lifts and locks into place. While it was kneading a bread dough, the motor...
Hello Suzann,
I understand that you are having a problem with your Kitchen Aid 5 Quart mixer. It sounds like you have stripped the gears or the worm gear out. Although, it may not be an expensive parts repair it is not an easy task to complete if you are not mechanical enclined. There are many different little gears in these units.
My suggestion would be to take it a local appliance repair shop that works on mixers. If you can tell me the city that you live in I would be more than happy to give you the location of one or two repair shops. As the unit is so old you want to invest in a new unit and keep that one as a reminder of how long Kitchen Aid has been around.
Thank you for choosing
Justin Burnett
Mar 16, 2011 | KitchenAid KITCHEN AID 5 Quart Artisan...
What is the difference between the Kitchen Aid "KSM150PSMC" and the KSM150 ?? thanks
The KSM150 is the line of mixers with similar features. It is in the Artisan series, tilt head, 325 watts. All mixers in the KSM150 line have the same features.
The one that you asked about, the KSM150PSMC is done in metallic chrome.
Best regards, --W/D--
Feb 01, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Which is the better mixer of these old models: K5A K5-A or K45 SS and what is the difference? KITCHENAID HOBART K5A K5-A 300 WATT MIXER and the KitchenAid Hobart Vintage K45 250 WATT. Thank you
Hello ajlina,
All of these are great home use units, all the attachments are interchangeable between these. The difference between these mixers is the K5 is a 5 quart mixer and the K45 is a 4.5 quart mixer. As I own both of them they are great in the kitchen and have the same durability.
Have any more questions please post to this thread and I will be happy to assist. Thank you for using FixYa.
Dec 09, 2010 | KitchenAid K45SS Classic Stand Mixer
Kitchen aid 300 watt counter mixer model ksm90
no there is no adjustment . worn hinge on the base , no parts made , not that i have ever seen ...... sorry i wish i had better news
Jan 05, 2009 | Hobart A200 Stand Mixer
Can the Kitchen aid accessories fit the Wolfgang puck stand mixer
If you happen to have a friendly toolmaker with a small metal lathe it should not be too difficult to modify KITCHEN AID accessories that fit on to the front powwer outlet. However Puck Stand Mixer accessories are occasionaly offered on the Web. Meat grinders are very common and original Puck pasta maker have also been seen. Get searchin'!
Dec 01, 2008 | Wolfgang Puck Stand Mixer
Kitcchen Aid mixer making a grinding noise
common problem. Worm gear & bracket #PS734273 about $36.
Oct 21, 2007 | KitchenAid K45SS Classic Stand Mixer
Bosch 300 Watts MFQ2100 Hand Mixer Logo
49 people viewed this question
Top Bosch Food Mixers Experts
Paul Bade
Are you a Bosch Food Mixer Expert? Answer questions, earn points and help others
