Object not present intel 945GNT sound drive?
I got ur reply..its very useful to me..but its not workin for me..wat i did was removed my XP and installed new one XP+SP2.but still am getting "Object not present" error.Also i Disabled audio in BIOS and installed sound drive tat time the driver is been installed but after reboot its reflected with the same error..whether i should hav to go for a new external soundrive..But when i remove my RAM board alarm with a beep sound..Is the prob in hardware or in software..pl tel me wat should i do now?
SOURCE: HD Audio Hardware Problem
just try to go in the bios and load default setting ,,,if issue persist then update the bios
Posted on Aug 14, 2007
I have a Deskop Board DG965RY. Sound device is problem the error is "device object not present" & "you are attempting to insall"
Posted on Jan 09, 2008
Drummernick
  • 440 Answers
SOURCE: New Encore ENM232-8VIA - No sound
go web site man try to get latest drivers ok make sure in bios onbord disabeld also ok
Posted on Feb 08, 2008
SOURCE: Problem with Windows XP recognizing Creative Sound Card
which driver saport w/xp i have ct 4780 sound card
Posted on Apr 21, 2008
SOURCE: audio probs
just installed xp professional 2600 on Compaq presario C740TU laptop and can't find an xp audio driver that will work
Posted on Jun 21, 2008
Not acses to the internet
wats ur internet type of connection. wats ur system specs. please give a brief details. then it may give idea wats the problem is.
If XP, check whether the network icon (2 monitos blinking icon near clock in task bar @ bottom right corner) is blinking or marked with RED. If yes then the network cable is unplugged. or the icon is not present there, go CONTROL PANEL, NETWORK CONNECTION, see for LOCAL AREA CONNECTION. that might be highlighted (else if its grey shaded, right click & select enable). If the icon is not present there, go to control panel, SYSTEM - HARDWARE tab - DEVICE MANAGER. on the lower edge you should see NETWORK ADAPTERS, expand it there the network cards should be there. If you cant find the drivers there, try to look it with YELLOW QUESTIONED marked devices. if this is present, then you should try to re install the driver.
hope all this may help you to solve the issue. else give a clear feedback.
Jan 21, 2013 | Computers & Internet
I Tried to ddownload Sigmatel HD Audio Driver Version 6.10.0.5274 the Response was:device object not present My CPU Processor: 2.8GHz Pentium D 820 Memory: 1GB DDR2 Storage: 250GB hard drive Optical D
Hmm.. interesting,
Checked the typical settings
- Volume control settings are normal (Sound on/not muted)
- Device Manager can detect a sound driver ~ if not, install it
- Driver File did not download correctly ~ try re-downloading the file
- If using audio jacks (usually known as the "green" cable), make sure that they are working properly
If this didn't solve the problem, reply to me thanx.
- donman92
May 31, 2009 | Gateway Computers & Internet
Multimedia audio controller sound driver for intel d845glva board
if ur OS is XP then all drivers for ur motherboard is here but if u hvae vista then Intel no more support this model for vista
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=947&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go!
pls rate me FIXYA for help !
Apr 04, 2009 | Intel Desktop Board D845GLVA...
When installing a new hard drive the system bios recognize the drive. However, when I start to install Windows XP, the program does not see the drive as being present. How can I get the computer started...
What type of hard drive is it. Sound like you put in a SATA hard drive. You need to load the drivers for that hard drive. During the Windows XP setup it gives you an option to load 3rd party drivers that what is sounds like you need to to.
Mar 05, 2009 | Dell Dimension 8400 PC Desktop
Installing WIN XP SP2 in aToshiba Satellite A205-S7459 Vista original
Problem : When Windows XP was made there was no concept of SATA drives now ur drive is SATA and ur installation disc does not contain drivers for ur Hard disk thats why it is unable to find ur hard disk as it doesnt recognize it u need sata raid drivers on ur windows inst cd
simple solution: get WINDOWS XP CD with SP3 it contains support for sata drives
Workable Solution:
this specific model of Toshiba was shipped with vista OS and drivers now u are downgrading it to XP it depends on the installation disc if it is new one like SP3 included then u would have never faced this issue in ur case u should get a RAID driver from www.intel.com and then include them in ur copy of windows XP cd to load them at the startup of installation , so u need them in the first place to carry out installation, u have to do some job here download RAID DRIVERS from www.intel.com select ur board and chipset either it is 945 or 965 gm and then download nlite a software used to integrate these drivers to ur inst disk , u can also include SP3 thru this software in ur current win xp cd
SATA DRIVER FROM:
http://downloadcenter.intel.com/license_agr.aspx?url=/17268/eng/iata87enu.exe&ProductID=2800&agr=Y&sType=&PrdMap=&DwnldId=17268&strOSs=45&OSFullName=Windows*%20XP%20Home%20Edition&lang=eng
http://www.nliteos.com/
just download sata drivers from intel and nlite from the link and install the software integrate these drivers and burn ur cd incl them and then install normally as u were installing them earlier now it will recognize ur drive simple for more info how to do check this out
http://www.zimbio.com/Laptop+Reviews/articles/10840/How+Integrate+Floppy+SATA+RAID+Driver+Windows
http://lifehacker.com/386526/slipstream-service-pack-3-into-your-windows-xp-installation-cd
after windows XP installation u will have one more task to find drivers for ur notebooks with XP support but it is the next step if ur some hardware like modem / sound/ doesnt work then i can help more
pls let me know if i can help u more
and rate me FIXYA if i have fixed ur problem
Mar 03, 2009 | Computers & Internet
Software problem
Cleaning your computer of cookies and temp files is easy and straightforward. Open the control panel and click on "Internet Options" icon. Click on the Browsing History and it will open up to a window that allows you to delete your browsing history, temp files and cookies.
debbills
Mar 02, 2008 | Microsoft Windows XP Home Edition
Sound
well you know what reset ur bios sometimes with intel this thing happens even with my self n some of my frends too their sounds not working coz its automatically being disabled dont know y i guess by bios updating or sumthing like that so go to bios n enable it or reset ur bios to orignal factory default settings if still the problems is the same then reply me i'll tell u how to do it!
peace!
Nov 18, 2007 | Intel D101GGC Motherboard
Computers & Internet Logo
55 people viewed this question
Alun Cox
David Payne
David Payne
