Question about Apple iPod classic MP3 Player
How do I remove --- Do not disconnect from the screen of my ipod
The screen of my ipod says -- do not disconnect. how canI make theipod operational again ?
  • 75 Answers
Press and hold "Menu" and "Select" buttons at the same time and hold them until it restarts (up to 8 seconds).
It can be tricky....if you accidentally touch the Scroll Wheel during the process, it won't work.  You might have to try more than once.
Posted on Nov 28, 2008
How to fix the backlight
hi
Things You'll NeedSmall flat-head screwdriverPhillips-head screwdriverReplacement screen
Tips & Warnings
This will void your warranty, so if your iPod is still under warranty, you might as well allow Apple to fix it.
Read more: How to Replace The iPod Display ' eHow.com http://www.ehow.com/how_5763780_replace-ipod-display.html#ixzz1gn0Sfes3
Replacing your iPod's screen is actually a lot easier than you would expect. The kind folks at Apple have made access to the inside of the iPod very easy, making for quick upgrades and fixes. While you have the iPod open, you can also upgrade the internal hard drive to a much larger capacity to hold more movies, music and photos. Replacement screens for the iPod are very easy to come by these days, so get a hold of one of those from an online retailer and replace it yourself, instead of getting charged by Apple to do something you can easily do at home.
Instruction
1 Replacing your iPod's screen is actually a lot easier than you would expect. The kind folks at Apple have made access to the inside of the iPod very easy, making for quick upgrades and fixes. While you have the iPod open, you can also upgrade the internal hard drive to a much larger capacity to hold more movies, music and photos. Replacement screens for the iPod are very easy to come by these days, so get a hold of one of those from an online retailer and replace it yourself, instead of getting charged by Apple to do something you can easily do at home.
2 Use your flat screwdriver and gently insert it into the small crack between the iPod case and the iPod backing. Once you have the tool slightly inside the crack, slide it around the entire iPod to pry the pieces apart. Be very careful not to pull them apart, as there are three ribbon connectors that need to be disconnected first.
3 Lift up the ribbon connector that connects to the hard drive, which is large and blue, and disconnect the hard drive. Release the ribbon that connects to the battery, the smaller blue object, and disconnect it. Release the final ribbon by lifting up its tab. Unhook the final ribbon to disconnect it.
4 Use your Phillips screwdriver to remove the six screws around the iPod front cover. Remove the frame of the iPod front cover. Unhook the screen's ribbon and pull out the iPod screen. Insert your new iPod screen and work backward to put everything back together. Don't forget to connect all of the ribbons
5 Turn on your iPod to test your new iPod screen.
Nov 25, 2011 | Apple iPod nano
Tip
How to Change Your iPod Background ...
With a bit of tweaking, the Apple iPodmag-glass_10x10.gif can be customized in a variety of ways, from the outer covering to the screen fonts. If you're tired of the background, you can use a program called iPod Wizard and some hacked firmware to change how your screen looks. The process isn't very difficult and it doesn't take long to complete. And once you've figured out how to do it, you can change the background to anything you want, whenever you want.
Instructions
Things You'll Need:
  • Computer with a Windows operating system
  • iPod
  • Data cable
  • iPod Wizard
  • iPod background firmware
  1. Step 1 Turn on the iPod and connect the data cable to the iPod and the computer. Start up iTunesmag-glass_10x10.gif. Choose your iPod and then click on the box in the "Options" section that says "Enable Disk Use" and click on "Apply." Disconnect the iPod from the computer when you're finished.
  2. Step 2 Download iPod Wizard, which can be found on the iPodWizard.net forum page, and install it on your computer.
  3. Step 3 Download iPod background firmware from Kankon.org and save it to your desktop or in another place that's easy to remember (you don't want to lose the firmware before you can use it to alter the background on the iPod).
  4. Step 4 Start up iPod Wizard and connect the iPod to the computer. IPod Wizard should indicate that it has located the iPod.
  5. Step 5 Click on the drop-down box beside "Edit Mode" and click on "Firmware File." Click on "Open Firmware" and navigate to the location where you saved the iPod background firmware. Click on "Open" when you've found the firmware.
  6. Step 6 Click on "Write," and then when it's done, click on "Write to iPod." Click on "OK" to make all confirmations and allow the firmware to be written to the iPod.
  7. Step 7 Disconnect the iPod and reset it. The resetting may take awhile, but when the iPod finally starts up, your screen will be different.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
on Dec 07, 2009 | Audio Players & Recorders
Ipad backlight repair
hi
Tips & Warnings
Instruction
I lost my lock code for my ipod 30GB
If you have access to the primarycomputer you use with your iPod, and your media saved on your hard drive.Follow PC/Mac instructions (Not technical)below to sync your iPod, and then restore its firmware which will removethe lock code.
If you use an Apple Laptop and are comfortable using Terminal you can skipbelow to Mac (Technical) instructions. This solution is somewhat technical and requires you to deletesystem files which can be risky, but it doesn't require restoring your iPod.Not recommended unless you know what you are doing.
Warning: Restoring your iPod will delete all the data and restore theiPod you factory settings. Only do this if you have your media saved on yourPC, or this is a last resort to get the functionality of your iPod back.
If you can't unlock iPod you canrestore your iPod to factory settings using iTunes. Please note that thiswill erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. b> PC/Macinstructions (Not technical) b> Warning: Restoring your iPod will delete all the data and restore theiPod you factory settings. Only do this if you have your media saved on yourPC, or this is a last resort to get the functionality of your iPod back. If you can't unlock iPod you canrestore your iPod to factory settings using iTunes. Please note that thiswill erase all data on your iPod. Afterwards, you can add your music and data back to your iPod.
1. Connect your iPod to your computer 2. OpeniTunes
3. Synchronize
4. Unplug your iPod
5. Plug your iPod back in
6. Click restore in iTunes.
7. After process is complete use iTunes to transfer your music and video backon to your iPod. Mac (Technical) instructions:
1. Plug inyour ipod to your dock/cable?
2. Open up the terminal?
3. type: cd /Volumes/NameOfYouriPod?
4. type: rm iPod_Control/iPodPrefs
5. type: rm -rf iPod_Control/Devices
6. Hold the menu button and centre button so it restarts while its connected toyour mac then remove the cable/dock while its restarting.
Mar 04, 2011 | Apple iPod MA446LL/A MP3 Player
Hi i charged my ipod touch, but after a while it showed only black and white stripes on the display. it did not respond for any operation. please help
There can be reset on theipod check for a tiny hole on the side, press it down and see if this works. If not get help to check out after opening.
Sep 28, 2010 | Televison & Video
Hunged-up iPod
this is what i just did with my daugthers ipod, that did not charge nor read hers either, turn on ipod if not still on (kill the battery totally)....later on tonight or when its dead...power up the pc / laptop, bring up itunes then connect the ipod to pc (two things should happen 1 - do not disconnect shoud pop on ipod screen and 2 - the ipod icon should pop on itunes) when updating itunes make sure ipod is not connected.
Apr 09, 2009 | Apple iPod MA446LL/A MP3 Player
Hi. I plugged in my iPod nano 4th generation to charge it. It opened iTunes as it usually does and I could see my iPod in my device list. I left it to charge as normal. I came back a while later and my...
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Mar 22, 2009 | Apple iPod nano
Charging ipod 4gb
Yes, the iPod will show that it is charging on its screen. Disconnecting without ejecting can cause data loss of whatever is stored on the iPod
Ejecting is when you remove the iPod from the desktop by dragging its icon to the trash or clicking on the down arrow next to the iPods name from within iTunes.
If you use the library computer, usually a Windows based OS, you'll need to click on the iPod icon from the task tray on the lower right of the screen. You can right click to select the remove option
Dec 21, 2007 | Apple iPod nano
Ipod nano 1st gen sync/charge problem
Try these options i got them from apple when my ipod dident work trying a new port and reinstalling itunes worked for me 1)Reset your iPod. 2)Retry with a different USB or FireWire port. 3)Restart your computer and make sure you have the latest software updates installed. 4)Remove iTunes software and then reinstall iTunes software from latest versions on the web. last resort 5)Restore your iPod. See ?Updating and Restoring iPod Software? in the user's guide.
Aug 24, 2007 | Apple iPod nano
OK to Disconnect
Fixed it myself! Reset by holding down Menu and centre button until soft reset complete. All working fine now.
Feb 21, 2006 | Apple iPod nano
Apple iPod classic MP3 Player Logo
41 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
