Question about HP Officejet Pro L7680 All-In-One Printer
PRINTING BUT NOT PRINTING ALL INFORMATION
WHEN WE PRINT SOME OF THE INFORMATION PRINTS OUT BUT NOT ALL OF IT! WHAT SHALL WE DO TO MAKE ALL INFORMATION PRINT OUT?
THE PRINTER IS HP OFFICEJET PRO L7680 ALL-IN-ONE.
  • 849 Answers
U need to install the proper printer drivers again.
Posted on Nov 17, 2008
Dell520 only prints header and footing
First you check it printer setting option and default setting choose and then you check it print preview and print it.
If not solved it, i share a informative link read it. Print Settings
Thanks,
HP Printer Help
Jun 25, 2014 | HP Officejet 5610 All-In-One InkJet...
How i can print in I pad2 with wireless printer
you can only print from an ipad using the airprint app if you have one of these printers read more about it here http://www.apple.com/ipad/features/airprint.html
    May 02, 2011 | Apple iPad 64 GB 3G Tablet PC
    Does the hp officejet all-in-one print wirelessly?
    the 6110 model does not print wirelessly.
    Thank you,
    Lee
    Jan 02, 2011 | HP OfficeJet 6110 All-In-One InkJet...
    My HP Officejet 6210 All-in-One printer goes offline whenever I don't use it for about 15-20 minutes, and when I put it back online, nothing happens. Looking at the printer from the control panel, I see...
    HP Printers have common behavior of going into sleep mode if not used for a while. If this happens every-time the printer goes to sleep mode and you find printing issue, try this simple step below
    Disconnect the power cable from back of printer
    While holding the # and 3 button, connect the power cord to printer.
    *Note this is partial reset and doing so you may loose fax logs and other fax related setting you have setup on printer.
    Click the link below to know how to resolve the print job stuck in queue issue.
    Link
    Oct 23, 2010 | HP OfficeJet 6210 All-In-One InkJet...
    Print cartridge prob [tri-color] refer to ... doc to troubleshoot
    HP Officejt J4680 - All in one Printer from HP, whcih will have Printing, Fax, Scanner and Copier facilities.
    Normal catridges recommened by HP are given below :
    01. HP 901 - Black which will print 200 Pages.
    02. HP 901 - Tri Colour which will print 200 Pages.
    03. HP 901 XL Black which is a bigger one that will print 900 pages regulary.
    This printer is most rugged one used by Home as well as in offices.
    The follwoing message regarding this Printer taken from HP Website which gives information about the printer quality.
    Enjoy the convenience of wireless connectivity with our Officejet J4680 All-in-One. You'll be able to print, copy, scan, and fax all from one device, plus print at speeds as fast as 28 pages per minute in black and 22 in color. And with our Officejet inks, you'll get high-quality printing at a lower cost per page than with a laser printer. Reliable and versatile
    • Print, copy, scan and fax with a single machine
    • Print fast, at up to 28 pages/minute black, 22 color##
    • Fax at speeds up to 33.6kpbs
    • Streamline big tasks with the 20-page automatic document feeder and 100-sheet paper tray
    • Preserve important documents for decades without fading1
    Solution:
    Please use the originai catridges for this printer and there will not be any issues.
    In spite of this, the problem continues, please call the local HP Authorized Printer vendor to solve this problem.
    If the Printer is under warranty, you will get a replacement printer with same or the higher configuration which is available in the market.
    Jul 21, 2009 | HP Officejet J4680 InkJet Printer
    Printing Quickbooks voucher checks with HP 6500 officejet printer
    i have nearly the same problem and I'm going to continue to search and write 6500 voucher printing problem
    May 18, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
    HP Officejet 5510 - Replacing Ink Cartridge
    this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
    1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
    2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
    3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
    4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
    5. Close the print-carriage access door.
    Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
    1. When the message displays, press OK . The HP Officejet will print an alignment page.
    2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
    3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
    Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
    Printer hp officejet 7310 all-in-one
    there is not your printer problem but printer print only html page contain
    Nov 11, 2007 | HP OfficeJet 7310 All-In-One InkJet...
    Printer on Macintosh
    Just go to here http://www.linux-foundation.org/en/OpenPrinting/MacOSX/hpijs get the driver, and it should all work.
    Mar 24, 2007 | HP OfficeJet 6110 All-In-One InkJet...
    HP Officejet Pro L7680 All-In-One Printer Logo
    95 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
