Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
Canon ixus 40
Good morning ,
my canon ixus 40 doesn't turn on after i replaced the screen cause it was broken.i put everything like it was but is not working any more.
thanks for your help!
  • alvaro_garzo Nov 17, 2008
    thank you!
  • alvaro_garzo Nov 18, 2008
    thank you!
  • 849 Answers
U might not join some connection, review the assembling procedure. otherwise consult a qualified technician for assistance.
Posted on Nov 18, 2008
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
replaced the batteries
check power button
the wire and the board!!
    Sergeant:
    Champion:
  • 435 Answers
Trying the camera with a new set of batteries.
If not LCD, atleast the unit should come on.
Posted on Nov 17, 2008
  • Canon Master
  • 19,396 Answers
Check the board soldering at the charger and battery contact, see if you can see or smell burned are on the board, some component may have shorted.
  • Ginko
    Ginko Nov 17, 2008
    Check the two ribbon cable connector that snap into the mainboard, you need to remove the front panel again to access the board
    Click here to see a picture, this is an Ixus sd300, there is not much difference.
    See also all the pictures for SD-300 at the bottom of this page.
  • Canon Master
  • 1,879 Answers
Eliminate the possibility of missing some connection, re-assembling the unit might help.
My Canon Digital Ixus 100 IS camera get ''Lens error,restart camera'' everytime I try to turn it on. The lens is also stuck outwards. This is after a friend of mine dropped it. I have tried...
Here are some troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Jul 04, 2011 | Canon PowerShot SD780 IS / IXUS 100 IS...
How much screen 4 lxus30 canon
Ebay.com is the best place to look for. If you buy the LCD itself it is usually expensive. For example, Try the following email. They replace the LCD: hu221221@gmail.com
But I would suggest you to buy a used camera (one sold for parts, with good LCd) through ebay.com and replace it yourself. You only need to buy a jewellers screwdriver set for $1 from Dollar store. Removing the case is easy (5-6 screws). Once the case is removed, LCD is immediately accessible.
You can buy any one of the cameras:
Canon IXUS 30 40 50 SD200 SD300 SD400
They all use the same LCD. So look in ebay.com for the above cameras. You may be able to get it for under $10-15. But before you do anything look at the following web sites to get an idea on how to do the job:
http://camerarepair.blogspot.com/2007/11/fixing-or-replacing-broken-lcd-screen.html
Jan 18, 2011 | Canon IXUS V2 Digital Camera
I have a Canon Ixus 40 and the screen does not work now can it be fixed for a reasonable cost.
Depends on whether or not the camera can take a picture OK.
If no picture, you may wish to replace the camera.
If it takes a good picture, the LCD ranges from $40 - $120 and labour to change it. Contact Canon for a good service center.
Mar 20, 2010 | Canon PowerShot SD110 / IXUS IIs Digital...
Hello, The screen is broken (ixus 700) is-it possible to change it? Thank you Scrly from France jchev21@hotmail.com
You may be able to fix it if you can find a replacement screen. I usually search ebay for a broken camera with other problems that I can cannibalize. Here's some examples on LCD replacement, including some of SD500:
Jul 04, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon Ixus 40 E18 Problem
try this link for E18 error in canon cameras for instructions
http://www.e18error.com/repair.html
pls rate me FIXYA for help
Apr 08, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Good morning, re: Canon Ixus 40 camera. Disassembeled the lense assembly. Lookibg for a step by step assembly instruction - how to insert and align correctly the lense concentric cylinders. Thanks Amos
From memory, you can unsolder the motor using solderwick. I would advise against unsoldering the photointerrupter however as it could be damaged easily. It wont completely detatch the circuit but will give you enough to dissassemble. Hope this helps.
Feb 28, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
Broken screen
I bought another camera on ebay - a Canon Ixus 400 for less than it would probably cost me to have repaired!
Regards
Jul 02, 2008 | Nikon COOLPIX Cameras
Canon Power Shot SD300 Broken Screen
pretty easy to replace the screen, i suggest buy SD300 from ebay that has lens problem, but it is known for sure that screen is working, you might find one for $20-30, also look for SD200 you might find it cheaper and it uses the same screen as your SD300
Aug 19, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Lcd screen does turn on
This is a defective CCD problem that is known to Canon. They will replace the defective part for FREE. Go here for more details: http://www.imaging-resource.com/badccds.html
Nov 10, 2006 | Canon PowerShot A75 Digital Camera
Nothing Display in Canon Ixus 750
Explain how broken Does the Screen display anything? If it does but is cracked then clear tape will fix it. If it is 'dead' then nothing will fix it and no repair I would think is possible. But to be sure check your local web site for repairers or even Canon - but possibly not in Bangla
Aug 11, 2006 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
23 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
