Question about Zanussi Dryers
Zanussi Tumble drier Not Getting very hot - Zanussi Dryers
  • Zanussi Master
  • 3,463 Answers
Probably element only working on low heat. check filter and outlet
Posted on Nov 17, 2008
My hotpoint tumble dryer plug is very hot and making my socket hot to is it a fault with my dryer as scared incase it causes a fire .It is 2 years old.
It is normal for a plug to get slightly hot, but it is more likely to be a problem with the plug or the socket if it is getting excessively hot, and less likely to be a problem with the drier.
Firstly inspect the plug pins, are they discoloured? If so have the plug replaced.(You can cut the moulded plug off and fit a quality plug)
Try a different socket if you can.
I assume the drier is working normally, but you should not put excessively wet loads in the drier as it will be on for too long. Make sure the clothes are as dry as possible that will reduce the time the drier is on.
regards
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 25, 2011 | Hotpoint Dryers
How easy is it to replace the rear bearing on a Zanussi TC7102W Tumble Drier, do I take the whole drier apart to do it? Thank you
you first remove the top cover,then the front cover then the drum belt and drum come out the front,and the bearing can then be accessed
Oct 14, 2010 | Dryers
Why does my tumble drier not get warm?
you could be looking at several problems
1 it could be the large filter underneath the tumble dryer this could be blocked with fluff causing it not to condense quick enough!
2 it could be the water collection pump? Can you her it running?
3 It could be that half the heater has failed causing it not to get hot enough to dry?
Try these hopefully it should steer you in the right direction!
Jul 20, 2010 | Zanussi ZWF1420W Front Load Washer
My zannussi TD4113W tumble drier has stopped tumbling .It still is heating up ok .Can I fix it ?
it sounds like the belt has broken or the motor has burned out try starting there
good luck
May 15, 2010 | Zanussi TC7114W Electric Dryer
Hotpoint tdc 30 not getting hot enough to dry
Remove and clean all filters, and make sure you have the correct heat setting selected
P[lease rate my solution.
Thnks.
Nov 15, 2009 | Hotpoint TDC32 Electric Dryer
The tumble inside stoped turning.
You have a broken belt on your drier. Take the back of your drier off and youll see the problem.
Good Luck
Dave
Aug 11, 2009 | Kenmore 77032 Dryer
Zanussi tumble dryer does not get very hot
Hi, I take it from the description taht you have given your T/dryer is a condenser? If this is the case you could be looking at several problems? 1 it could be the large filter underneath the tumble dryer this could be blocked with fluff causing it not to condense quick enough! 2 it could be the water collection pump? Can you her it running? 3 It could be that half the heater has failed causing it not to get hot enough to dry?
Feb 09, 2009 | Zanussi TD4112W Electric Dryer
Zanussi TDE4234W Tumble drier noise
Probably the gliders is worn.
Jan 31, 2008 | Dryers
Dryers Logo
96 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Marvin
Marvin
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
