Question about LG Washing Machines
Lg wm2496hsm - error message LE
After a few loads successfully wash I will get an ''LE'' error message that flashes on the display. What does this mean and how do I get rid of it?
  • 8 Answers
SOURCE: LG Washing machine - WM14225FD. Error LE showing
I tried what I'd seen written elsewhere - my LE error came after I turned the drum as I was unloading it, which caused the control panel to light up. This confused the brain.
I unplugged it for 10 minutes, then started a Rinse & Spin cycle with No Spin selected for the Spin Speed. After this completed, I was able to use the washer as normal.
Posted on Feb 28, 2009
SOURCE: LG Tromm washer WM2077CW reading code LE
LE means "Overload in Motor" Unplug the washer, remove clothes, wait 15 minutes for motor to cool down. try again. If problem persists you'll need a certified technician.
Posted on May 31, 2009
SOURCE: LG TROMM WM2496HSM MILDEW & MUST SMELL
I have had the same problem with mine. I have started taking the rubber seal off at least once a month to clean it with bleach and water. I would not recommend doing this unless you are handy with tools. You might try cleaning the seal with bleach and water while it remains on the machine. Careful to pull the inner sealing lip down to get to the "Slime" behind it. Good Luck
Posted on Aug 21, 2009
rdrsp
  • 85 Answers
SOURCE: LG model WM2277HW front load washing machine,
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
1) in my experience, sometimes this proves to be intermitent, and upon unplugging and waiting for 5 minutes does not seem to resurface again...
2)Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount.
this could prove to be very challenging to somebody who does not know what they are working with, i suggest if the problem is not intermitent, call a tech.. hope this helps.
Posted on Oct 26, 2009
CMV9
  • 594 Answers
SOURCE: LG Tromm wm1814cw LE flashing on digital display,
Here are few troubleshooting tips that i have found. If you acquire further assistance please let me know...
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
Posted on Apr 13, 2010
I have an LG front load washing machine model number wm2496hsm with the code ee coming up on display what's wrong with it and how do I fix it
EE - Stands for EEPROM ERROR
EEPROM is out of order. Displayed only when the START/PAUSE button is first pressed in the QC Test Mode.
The machine's program is stored in the EEPROM area of the microcontroller unit, when it is out of order the machine stops functioning.
Jun 01, 2015 | LG Washing Machines
Error code te for lg tromm front load washer wm2496hsm
The TE error code is a Thermistor error. Replace the thermistor and you should be good to go.
Feb 29, 2012 | LG WM-2032H Front Load Washer
My lg washer wm2496hsm displays a "te"error what is this
The water temp. thermistor is @ fault or the main computer.
Service will be needed.
Jan 20, 2010 | LG WM2496H Front Load
LE error message - how to finish the wash cycle?
error LE Overload in motor.unplug for 1 hour plug back in. motors going bad or over loaded with stuff.
If not, you need to call tech.
Thanks.
Jun 17, 2009 | Washing Machines
LG WM2277HW - ERROR CODE "LE"
Hello remrama,
Please use this link to access the service manual on your display code message ( page 18 ) elaborates on the cause of that message. You should be able to determine which of the few causes may be the culpret,... http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
Hope this helps you..
Regards,
Rick
Feb 22, 2009 | LG WM-2277HW Front Load Washer
LG WASHER WM1832CW HAS LE ERROR MESSAGE
Jan 15, 2009 | LG WM-2277HW Front Load Washer
Problem with LG washing machine Model number wm1480fhd. The machine drum reluctantly turns and in about a few minutes it displays error code LE (flashing).
LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
Aug 22, 2008 | LG Washing Machines
Washer
Greetings jannd,
The message "LE" can indicate that the thermal overload protection circuit in the motor has been tripped. The remedy for this can be to allow the washer to stand for 30 minutes to allow the motor to cool, then restart the cycle. If the LE error code still appears, unplug the washer and call for service. Keep in mind that this unit carries a 7 year warranty on the motor also.
I hope this helps!
Best regards,
Dorothy
Go Ahead. Use Us.
May 11, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Error message when trying to wash
Unplug the machine and spun the drum few times by hand, wait 10-15 min. and plug it back. Good luck!
Aug 06, 2007 | LG WM-2077C Front Load Washer
Washing Machines Logo
65 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
