I have a nvidia graphics card GE force 6200 (in pci slot).recently i am having a strange problem. as soon as i switch on mycomputer , the display flickers and when i go to my computer the drivesappear as if it is smudged and display is very dull. First i thought itmay be because of my monitor .but when i removed my graphics card , thedisplay becomes normal. and also when i was using my graphics card andwhenever i put my system into standby mode , it would automaticallycome out of standby mode without moving the mouse. Is it somethingrelated to drivers.Do i need to install the latest NVIDIA drivers.
The refresh rate is 60 hz and no other option is available . There is acheck box(hide modes this computer cannot display) below that. If iselect that , then i can select 70 hz and so on upto 100hz. but when iselect anything greater than 70 hz . i get a blank screen and a hzsymbol is shown on the screen. Even if i select 70 hz , the screen isagain blurred and dull and flickers.How do i solve this problem ??
My configuration is as follows: Intel P4 2.66 ghz Intel D101GGC motherboard 512 Mb ram Samsung syncmaster 591s Monitor.
I looked up your Monitors specefications to try to confirm my theory. Which is that this is a resolution problem. Your Monitor is rated for a maximum resolution of 1024 x 768 at 68 Mhz so this is the max that your Video card can drive this at. However with a CRT Monitor running them at their MAX for extended periods of time can lead to the fuzzyness your talking about. Its likely that when you switched it to the On board or secondary videocard that it defaulted to the standard SVGA display levels of 800 x 600 resolution. Allowing the Video card to increase the refresh rate to 85Mhz.
Which coincidentally is what the Samsung recommends as the optimum setting for this monitor so I believe if you scale down to 800 X 600 @ 85Mhz I think this will clear up your problem. Though if your like me you like to maximize your screen real estate as much as possible.
There are alot of monitors in the market for around $100 USD that have "Native" resolutions of around 1280 X 1024 @ 75Mhz
can you update the graphics card in a gateway gt5482E? I attempted to install an Nvidea 9800GT, and...
(More)
can you update the graphics card in a gateway gt5482E? I attempted to install an Nvidea 9800GT, and then tried a NVidea GT240 but both did not work. The PC continues to read the original 6160 se card in spite of the drivers being un-installed. HELP! :-)
Code 43 when try to reload drivers. Will not work alongside NVIDA gforce 8200 graphics card. Any...
(More)
Code 43 when try to reload drivers. Will not work alongside NVIDA gforce 8200 graphics card. Any ideas???
I updated my Nividia GeForce X40 graphic card through the manufactur after windows said they didn't...
(More)
I updated my Nividia GeForce X40 graphic card through the manufactur after windows said they didn't have anything newer, 1 month later windows came and updated it and now my screen is jarbled and missing half of the color. I was able to do a system restore and fixed it but my roommate let windows update it again and now it won't let me do a system restore and won't let me manually change the settings for the color. It went from a 32 bit to a 4 bit. What can I do?
it wont boot up computer!!! when i put my post card i changes post codes first it stops c1 then...
(More)
it wont boot up computer!!! when i put my post card i changes post codes first it stops c1 then continues to 25 then resets to c1 and so on and on
