Question about OKI C9300 Led Printer
The colours look muted and dull when printing from my oki c9300
Hello - when printing, the colours appear dull and muted compared to what they used to be... any ideas?
Whipe the 4 LED arrays which stick out from the top when you open it up - with a soft paper tissue -gently, or use proper led-cleaner
Posted on Jan 14, 2009
HOW DO YOU MAKE COPIES ON AN OKI C9300 PRINTER
This machine is just a printer, so you can't make copies.
Jul 20, 2010 | OKI C9300 Led Printer
My oki c5700 shows the message: " K drum life" how can i solve it.
A drum can print only a limited number of pages before failure - your drum has reached that number and must be replaced.
Jun 28, 2010 | OKI C9300 Led Printer
I have an Oki c9300, the paper travels as far as the fuser unit, then jams.
Remove the fuser and make sure the sensor below the fuser is still in place. If it and the paper is stuck inside the fuser then you have to buy a new fuser or a refurb one because you might have used up the life of the rollers that heat the toner onto the paper
Well hope this helps good luck. .
Nov 20, 2009 | OKI C9300 Led Printer
Colors are not printing the acutal color
It all depends on the meaning of 'not properly'.
Try creating a document with four different squares, or words, of these colours: yellow, magenta, cyan and black. If all of them print (albeit not with the correct shades) it is probably an ICM driver error. But my guess is that only one of those four colors will print badly, due to a defective color cartridge.
The OKI 5150 makes all perceivable colours using cyan, magenta, yellow and black toners, so if one of these malfunctions, the resulting colors will lack the required shade of, say, yellow, and will appear to be "wrong". The yellow colour itself, of course, would simply disappear (the "yellow" you use might actually be 95% yellow and 5% cyan; then the "yellow" square will be printed as a very light shade of cyan, while the other colors - say, 95% magenta and 5% yellow - will turn out almost exact).
Try with the color test and replace any failing cartridge; if all four (almost) pure colours do print incorrectly, it's unlikely to be a cartridge problem, and we'll have to dig deeper.
Sep 09, 2009 | OKI C5150n Led Printer
Where can I find a replacement Thermistor for an Oki C9300 fuser unit?
The fuser is sold as whole unit. Just find one and order it and replace it yourself, it is a user repalable item.
Jun 04, 2009 | OKI C9300 Led Printer
Xerox Phaser 7300
CHECK YOUR toner cartridge may it is leakaging of ink powder.also check your asebly clear the dust.some times roller also has problem but most of the problem of toner cartidge change it then try.
Sep 30, 2008 | OKI C9300 Led Printer
Oki C9300
What is the status of your fuser unit and on what paper settings are printing on? When last have you cleaned tour machine?
May 23, 2008 | OKI C9300 Led Printer
Cannot print double sided
tick box duplex option installed in driver, otherwise install correct driver with duplex option on server, and delete drivers on workstations.
Jan 04, 2008 | OKI C9300 Led Printer
OKI C9300 Led Printer Logo
186 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
