Question about Sprint Hitachi P300 Cellular Phone
Hitachi AXM898U I have just bought the above system and it does not tell you in the manual what format the USB SD card reads I have tried wma and mp3 but it will not work, it only reads.
H20MAN DOES NOT RECOGNIZE THE MP3 AND WMA FORMAT
Try to check the your instruction manual for the possible correct & compatible AUDIO & VIDEO formats.
Aug 03, 2009 | Snap Sights H20 Man MP3 Player
I am not getting the music for the sd card to play on the mp3
you have to make sure that the music is in the right format and you have to open the music in the music player menu. i have my songs in wma format and they work fine. also if your phone is not recognizing the sd card then perhaps its an sd card that is not supported by the lg shine. read your manual there is a specific type of card you can and cant use on that phone. the card i have is a sandisk 4gb microSDHC
Apr 28, 2009 | LG Shine KE970 Cellular Phone
Ha90
The WMA files are probably copyright protected, and this device was not set up to read them. I would try converting them all ot Mp3 format - you will probably have better luck. Here's the official Harley page that I found:
Here's the best bet - there are pdf instructions for upgrading the software and a few other functions, but no user's manual for it per se:
http://www.harley-davidson.com/cp/moar/en/overview.asp?locale=en_US&bmLocale=en_US&WebLogicSession=IxPr8hMLlpTeiAo8tqS42O5oe0q8OxNYxkSMGILPXoq8DHdmO3IE!-608879135!hdijunapppr08.ihd.hd!7005!8005&HDCWPSession=43nTLxPTw2cyWmlLHvR8BY0pqGFrtc8n5f6GQL4PvhTDBmHHhWQP!1924091048!-135590298
Jul 04, 2008 | Harley Davidson Road Tech HA90 MP3 Player
Error code 13 on my car stereo
I visited VR-3.com and found the following in the manual: Problem: MP3/WMA Files on the USB/SD flash memory do
not play.
Answer: Flash memory is formatted as NTSC.
Format the flash memory as FAT or FAT32.
The files have Digital Rights Management(DRM).
If the files you are attempting to play were
purchased online, they may have Digital Rights
Management, this unit is not DRM compatible.
You may want to call VR3 at (800) 445-1797 and inquire about that specific code just in case though the answer above was not given as "error 13" I just made an educated guess based on the problem given.
Jun 29, 2008 | Jensen 100W x 4 Amplifier KA5 Car Audio...
Nextar GPS
I'm about to purchase the same model. I'm reading the instructions I printed off Nextar's site and it does say the unit is designed with SD card slot and supports MP3 and WMA format files playback. You can insert ther SD card with MP3 or WMA files in the unit for music enjoyment.
Hope this helps
Feb 12, 2008 | Nextar X3B GPS Navigation System
How to get music on to the 3.0 megapixel Digital Video Camera DXG
refer to your users manual.
The DXG-305V has the ability to play MP3 files. Only song files in the MP3 file
format can be played in the MP3 function. Files on CDs are usually in the
Windows Media format (.wma) or wav format and cannot be played in their
native format; they must first be converted into MP3 files. This can be
accomplished with many types of software which are available at little or no
cost.
Once the songs are in the MP3 format, they can be transferred to the MP3 folder
in the camera’s onboard memory or onto the SD card. This can be
accomplished by one of two ways: 1.) Attach the USB cable to the camera,
select “Mass Storage” and then use your PC to find the removable hard drive
( the camera / SD card). Once located, drag and drop the MP3 files into the MP3
folder. NOTE: Two removable hard drives will be visible if the camera has an SD
card inserted. 2.) The other way is to place the SD card into a card reader,
locate the MP3 folder, and drag and drop the MP3 files into the MP3 folder. The
card can then be re-inserted into the camera.
Once the files are in the MP3 folder, they can be played by rotating the mode dial to the mp3 mode
Jan 23, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Zmate mp3 not recognised
Try a different cord, USB port, and bypass any splitters if used. Then try another USB support driver in Device manager.
Dec 28, 2007 | Dane-Elec TA-SD0512-D MP3 Player
Got a new SD Card + Card Reader but when I download my music on it...
You cannot just move WMA songs onto the card and play in the MP3 player. MP3 format may work this way, but for sure the player only seems to be able to recongize WMA files when syncd through Windows Media with the USB cord attached. Be sure the DESELECT 'copy folder hierecy' under the sync options/properties of the MP3 player drive or SD card drive.
When using XP Pro and Windows Media Player you can transfer WMA but you have to go into the PROPERTIES of the drive (mine was mp-556/G: drive) and DESELECT the option to transfer folder hierecy. The MP3 player is not able to reconginize the folder structure it usually creates.
This player only seems to be able to transfer MP3 format with Vista, using windows media player sync. I can syne MP3s formats, but not WMAs at all. Unless someone found otherwise
Dec 25, 2007 | iLO (2 GB) MP3 Player
Saving music on my micro sd..
why cant i get my micro sd to show on my phone
Oct 26, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Sprint Hitachi P300 Cellular Phone Logo
57 people viewed this question
Top Sprint Cell Phones Experts
Vernon Taylor
rgnestle
Level 1 Expert
Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
