Question about Intuit Computers & Internet
I want to download my Quicken business credit card transactions from Chase into my Quickbooks 2006 for Mac software but Quickbooks won't let me. What do I do?
  • 1 more comment
  • kennygronnin Nov 18, 2008
    Serious replies only. thank you.
    Online internet.
  • kennygronnin Nov 19, 2008
    Be advise my Qiuckbooks (Quickbooks Pro 2006- v8.03 r5) software is for a Mini Mac . Leopard platform.
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
what is a quickbook?
Posted on Nov 19, 2008
  • ronald suboc
    ronald suboc Nov 19, 2008
    try to download in windows os
    and then install it in your mac
  • ronald suboc
    you must registered first
    if you want the software
  • 1,879 Answers
"from Chase" you mean online (internet) or from another computer (include computer specifics).
"Quickbooks 2006 for Mac" what message did you get ?
Posted on Nov 17, 2008
  • monk3ybidzness
    monk3ybidzness Nov 18, 2008
    How about warning or error messages why Quicken won't let you perform such task.
  • monk3ybidzness
    monk3ybidzness Nov 19, 2008
    Additional detail to help pin down what's causing the issue is needed.
    If Quicken won't let you perform such task, it will spit out a message explaining why or giving hint why the function is not successful.
    Thanks
    Sergeant:
    Champion:
  • 435 Answers
Hi, Chase normally produces all statements in PDF format.
However, you can click "see all activity" to see all the transactions in the webpage.
Here, you can click "print" which is found on the top of the webpage (not the browser menu).
It will open up a new window which shows only the transactions. Cancel if it asks you to print. Now Copy the transactions alone to a text file and convert to  csv file using MS Excel. If you can import this file directly to Quickbook 2006, it should be good.
Else, there are some softwares which does the excel to quickbook imports.
Quickbook normally takes only Manual entry for each transaction. But this one should be faster than entering all the transactions manually
    Sergeant:
  • 237 Answers
Hi, I see you've gotten quite a bit of responses. Here is a simple solution, (I will direct you to a link, however, the link automatically detects your software, and thus guide you through the rest of the setup process, no fuss, no muss)
Here it is: http://support.quickbooks.intuit.com/support/productselection.aspx?status=init
Good luck and let me know how you did!
  • zabrina liang Nov 19, 2008
    (I'm not sure if my solution posted --it didn't show me a confirmation)so :
    I see you have tons of responses, here is a quick and simple solution (I will direct you to a link, but it automatically detects the software installed on your computer and will guide you from there, simple, no fuss, no muss)
    http://support.quickbooks.intuit.com/sup...
  • 36 Answers
HI
please restalled the software..
check it
  • 10,515 Answers
Hi buddy,
As quicken recently completed a system upgarde, u might need to modify certain info.......
Carefully follow the instructions and it wld solve ur issue
https://www.ezcardinfo.com/QuickenQuickbooksInstructions.html
********Ur alwyz wlcme-----------**********************
  • taran_2005
    taran_2005 Nov 19, 2008
    Uhmmm or let me paste all the procedure rather than link...Isnt that g8 :)
    Download Instructions
    INTUIT QUICKEN (WINDOWS/MAC) / QUICKBOOKS
    As we recently completed a system upgrade; you may need to modify certain information in your Quicken/QuickBooks software to ensure a smooth transition of your data.
    It is important that you perform the following instructions exactly as described and in the order presented.
    Quicken Windows 2007-2008
    Quicken Windows 2005-2006
    QuickBooks MAC 2006-2007
    QuickBooks Windows 2005–2007
    Instructions for Quicken Windows 2007-2008
    DEACTIVATE YOUR ACCOUNTS
    1. Choose Online menu g One Step Update.
    2. In the One Step Update Settings dialog, uncheck any boxes that are checked, and then click Update Now.
    3. If a software update is available, then you will be prompted to apply it now.
    4. Once the update is complete, restart Quicken.
    5. Quicken banking customers: right-click your first account from the list under Cash Flow Center.
    6. Select Edit account from the pop-up menu
    7. In the Account Details dialog, click the Online Services tab.
    8. Click Remove Connection or Remove from One Step Update in the One Step Update area. Confirm the remaining prompts.
    9. Click the General Information tab. In the Financial Institution field, type the name of your financial institution. EDIT any account information that is changing.
    Click OK to close the Account Details dialog. Repeat steps 1 through 6 for each applicable account.
    REACTIVATE YOUR ACCOUNTS
    1. Open a Web browser and log in to your financial institution’s Web site and download your transactions into Quicken.
      Important: To avoid the possibility of creating duplicate records when downloading into Quicken, select a "from" date that does not include records previously downloaded.
    2. Click the Use an existing Quicken account radio button. In the corresponding drop-down list, select the Quicken account.
    Repeat steps 1 and 2 for each account that you will use for online banking or investing.
    AUTOMATING YOUR WEB CONNECT DOWNLOADSExpress Web Connect provides the option of activating the One Step Update feature, which automates the downloading of Web Connect data. To activate the One Step Update feature, take either of these actions:
    • If you see the Activate One Step Update prompt during the Web Connect download process, click Yes, and then click Activate.
    • From Quicken, choose Online menu g One Step Update. In the dialog that displays, choose Activate One Step Update link next to your financial institution’s name.
    Once activated, you can choose Online menu g One Step Update to perform downloads.
    Instructions for Quicken Windows 2005-2006
    2. Uncheck all boxes and click Update Now.
    4. Once the update is complete, you must restart Quicken.
    5. Quicken banking customers: right-click your first account in the Cash Flow.
    6. Select Edit account from the pop-up menu.
    8. Click Deactivate in the Transaction Download area. Confirm the remaining prompts.
    9. EDIT any account information that may be changing. Click OK to close the Account Details dialog.
    Repeat steps 1 through 5 for each account from which you download transactions.
    1. Log in to your Financial Institution's Web site. Download your transactions to Quicken. Important: To avoid the possibility of creating duplicate records when downloading into Quicken, select a "from" date that does not include records previously downloaded.
    2. Click the Use an existing Quicken account radio button. In the corresponding drop-down list, select the applicable Quicken account.
    Repeat steps 1 and 2 for each account that you will use for online banking or investing with your Financial Institution.
    Instructions for QuickBooks MAC 2006-2007
    DISABLE YOUR ACCOUNT
    1. Choose Lists menu g Chart of Accounts.
    2. Select the account to disable in the Chart of Accounts list, and choose Edit menu g Edit Accounts.
    3. EDIT any account information that is changing.
    4. Click the Online Settings button.
    5. Select Not enabled from the Download transactions drop-down list.
    6. Click Save.
    Repeat steps 2 through 6 for each account from which you download transactions.
    RE-ENABLE YOUR ACCOUNT
    1. Re-enabling your account is as easy as downloading from the Web site. Anytime after the conversion, log in to the Web site and download and save your Web Connect file (.QBO file extension) to your Mac.
      Important: To avoid the possibility of creating duplicate records when downloading into QuickBooks, select a "from" date that does not include records previously downloaded.
      In QuickBooks, choose Banking menu g Downloaded Transactions. Click OK if any informational prompts display.
    2. In the Downloaded Transactions dialog, click Import File to import the account information contained in the Web Connect file that you saved. Select the Web Connect file, and click Open.
    3. The Account Association dialog displays during setup only. Click Select an Account to choose to map the online account to an existing account register. Then click Continue.
    4. Click OK to any informational prompts.
      Repeat steps 1 through 4 for each account that you previously disabled.
    5. Verify that all transactions downloaded successfully into your account registers.
    Brigadier General:
  • 3,614 Answers
  1. From the Customers menu, choose Credit card processing activities, and then choose Automatic Credit Card Billing to access the Recurring Charges page.
  2. Print the Automatic Credit Card Billing Authorization Form.
  3. Click Set Up Recurring Charge on the Recurring Charges page and complete all fields.
  4. Click Next to review and save the information. Billing begins on the start date you specify and may be stopped at any time
  • Intuit Master
  • 19,396 Answers
First of all tell us what message you get , so that we can understand why Quickbook is blocking the installation.
Posted on Nov 18, 2008
    Sergeant:
    Champion:
  • 200 Answers
Hi
Restart the system and then try it..
thank you
  • Thafa Nov 18, 2008
    Hi
    First check it will support for mac os..
    If its supported means reinstall the software and then try it....
    If its not supported to the os means download the software for mac os and then try it...
    check this link for quickbooks for mac os..
    http://quickbooks.intuit.com/product/acc...
    thank you
How to get a download for a repair manual for A Acer Aspire v5-572p-6446
There may be one available as a block diagramme for a fee on a web site somewhere but that is not common.
Most manufacturer trained computer engineers know how motherboards work alongside the firmware and chosen software so there is no call for them.
Jan 10, 2017 | Acer Computers & Internet
What is the difference between windows 7 editions: starter, home basics, home premium,ultimate, professional,interprice?what is the difference between service pack 1 & 2???pc
Since October 31, 2013, Windows 7 is no longer available in retail (except for the Professional edition preinstalled):[6]
Windows 7 Starter Windows 7 Starter is the edition of Windows 7 that contains the fewest features. It is only available in a 32-bit version and does not include the Windows Aero theme. The desktop wallpaper and visual styles (Windows 7 Basic) are not user-changeable. Microsoft originally intended to restrict users of this edition to running three simultaneous applications but this limitation was dropped.[7]This edition was available pre-installed on computers, especially netbooks, through system integrators or computer manufacturers using OEM licenses.[1][8][9] Windows 7 Home Basic Windows 7 Home Basic was available in "emerging markets", in 141 different countries.[10] Some Windows Aero options are excluded along with several new features.[1] Home Basic, along with other editions sold in emerging markets, include geographical activation restriction, which requires users to activate Windows within a certain region or country.[11] Windows 7 Home Premium This edition contains features aimed at the home market segment, such as Windows Media Center, Windows Aero and multi-touch support.[12] Windows 7 Professional This edition is targeted towards enthusiasts and small-business users.[1] It includes all the features of Windows 7 Home Premium, and adds the ability to participate in a Windows Server domain.[1] Additional features include support for up to 192 GB of Random-access memory (increased from 16 GB),[13] operating as a Remote Desktop server, location aware printing, backup to a network location, Encrypting File System, Presentation Mode, Software Restriction Policies (but not the extra management features of AppLocker) and Windows XP Mode.[1] Windows 7 Enterprise This edition targeted the enterprise segment of the market and was sold through volume licensing to companies which have a Software Assurance contract with Microsoft.[1] Additional features include support for Multilingual User Interface(MUI) packages, BitLocker Drive Encryption, and UNIX application support.[1] Not available through retail or OEMchannels, this edition is distributed through Microsoft Software Assurance (SA).[1] As a result it includes several SA-only benefits, including a license allowing the operating of diskless nodes (diskless PCs) and activation via VLK.[14] Windows 7 Ultimate Windows 7 Ultimate contains the same features as Windows 7 Enterprise, but unlike the Enterprise edition, it was available to home users on an individual license basis.[1] Windows 7 Home Premium and Windows 7 Professional users are able to upgrade to Windows 7 Ultimate for a fee using Windows Anytime Upgrade if they wish to do so.[1] Unlike Windows Vista Ultimate, the Windows 7 Ultimate edition does not include the Windows Ultimate Extras feature or any exclusive features as Microsoft had stated.[1] All editions will receive Mainstream Support (new features and bug fixes) until January 2015 and Extended Support (security updates) until January 2020.[15]
Dec 08, 2014 | Computers & Internet
Does a samsung stratospher need a sims card to ativate?
It depends on the carrier. After checking the specs though the phone comes back as a 4G LTE device so you will need a SIM card for ATT, Sprint, and Verizon. If you are on something like Straight Talk or MetroPCS, then they do not use SIMs
Jul 14, 2014 | Computers & Internet
How can i download falsh player on to 2011 imac desk top threw Linux ubentu browser ?
Ok, there are a number of issues with you spelling so I am going to assume you meant the Ubuntu OS. If that is the case the Flash Player install is done by the following:
If you are using the more modern versions of Ubuntu, simply install the Adobe Flash application from Ubuntu Software Centre.
If you are using a version that does not support the Software Centre, try:
Go to the Adobe website.
  • Click on "Download the Latest Player," and choose ".deb for Ubuntu" from the drop down list.
  • Choose "Save File" from the pop up window.
  • Open a terminal window.
    The terminal window will be found under Applications -> Utilities.
  • Change to the directory where your downloaded file was saved.
    cd Download
  • Install the libcurl3 library: sudo apt-get install libcurl3
  • Install the Flash Player: sudo dpkg --install install_flash_player_<version>_linux.deb
    Replace <version> with the latest version number.
  • Restart Firefox.
  • Check that Flash Player was installed.
  • Jul 08, 2014 | Computers & Internet
    Registration nectar card
    See this... https://help.nectar.com/app/answers/detail/a_id/339/~/how-do-i-register-my-nectar-card%3F
    Jul 04, 2014 | Computers & Internet
    Why is my screen red
    You placed your problem with wrong category, I assumes. Is it a projection TV or a laptop? If it is a TV; check the site linked here for one color predominant screen faults. If it is a computer, re post your problem by computer category. http://electronicshelponline.blogspot.com/
    C:\preload\data9_04.inp cannot be recovered
    You can recover the file with 3rd party data recovery software.I have succeed to recover files from external hard drive with Tenroshare Data Recovery.It can recover data after deeply scanning your hard drive to look for lost files. By the way,you can download it and scan your hard drive for free to preview whether your file can be recovered. Get it from http://www.any-data-recovery.com/product/datarecoverystandard.htm
    Jul 31, 2011 | HP Media Center m1080n (PC099A#ABA) PC...
    How to install Anti virus on my desktop
    Following the steps to install antivirus on you pc.
    Compare antivirus software. Look at the features and benefits of each. Read reviews from authoritative editors from magazines such as "PC World," "Smart Computing" and "PC Magazine." Editors who write for these magazines typically test antivirus software as an unbiased outsider and write about both the good and bad sides of antivirus software. For example, the editors at "PC World" recommended Avira AntiVir, Avast Antivirus and Panda Cloud Antivirus in an August 2009 article. Visit the websites of each antivirus program to view screen shots and descriptions of how the program works. Make a final decision about which antivirus program you want to install.
    Navigate to the website of the antivirus program you've chosen. Go to the "Downloads" section of the site if you're obtaining a free antivirus software. Click on the "Purchase" section or "Buy" button if you have chosen licensed software; pay for and complete the transaction. Click the "Download" button or link for the antivirus program. Save the file to your computer desktop or to a computer directory or folder which you can easily remember.
    Find the antivirus program file you downloaded on your computer. Double-click the ".exe" file (which is an executable file that will install the antivirus program). Once you double-click the ".exe" file, the installation process will automatically begin. Click "Continue" or "Next" on each screen to complete the installation process. Enter your name and contact details if registration is required. Follow any other on-screen prompts to complete the antivirus program installation. Restart your computer if necessary.
    Feb 18, 2011 | Computers & Internet
    Freezes on the warm boot screen MC9000
    This can be for a number of reasons.
    First thing would be to try and cold boot the device:-
    Remove battery half way, hold power button and trigger, push battery in fully until click and then release power and trigger
    If that fails next thing would be to try and re-flash the operating system. This is done by using an SD card and loading the latest operating files onto it. The SD card slot is located under the keypad. A cross head screwdriver is required to remove the keypad. Search on symbol software download site for the latest. The download also has a readme with detailed instructions. Once the files are on perform a cold boot.
    Remove battery half way, hold power button and trigger, push battery in fully until click and then release power and trigger. Drop the terminal in a cradle so that it runs on external power.
    Hope this helps.
    If you need any more help then please do not hesitate to contact us:-
    http://www.biastechnology.com/
    or TEL 01202 620955
    Dec 09, 2009 | Symbol MC9000-G Portable Terminal
    Bluetooth
    my bluetooth device not working. if i try to start it laptop say NO BLUETOOTH DIVICE.so what can i do?
    Dec 12, 2007 | Acer Aspire 5100 Notebook
    Computers & Internet Logo
    335 people viewed this question
    Top Intuit Computers & Internet Experts
    Scott Fair
    Scott Fair
    Mark Taylor
    Mark Taylor
    Mike
    Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
