Question about GE Ovens
Squeeky noise while baking
Ge oven..a squeeky noise while baking..sounds almost like a mouse...squeek squeek..it is a new oven ..repair man said he has no idea what it is..
he never heard of it before..not a good enough answer..
  • GE Master
  • 3,463 Answers
If it is a fan oven then it could be a noisy fan bearing
Posted on Nov 17, 2008
Oven won't heat
major electrical problem. call a repair man asap!
May 19, 2013 | GE Profile JT912 Electric Single Oven
Bake pre heat isn't working broil and top burners
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 07, 2011 | GE Ovens
Our GE oven will not work. The stove and the broiler both work but the regular oven will not! Any ideas?
Oven not Working or
Oven not Heating
heatman101
Feb 19, 2011 | GE Ovens
Bake feature on oven won't work ignition light glows but flame won't spark. broiler works
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Dec 10, 2010 | GE 30 In Freestanding Gas Range ...
My GE gas wall oven lights, gets hot, then keeps turning itself off during baking.
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 24, 2010 | GE Ovens
Oven makes a noise when I turn it on.
If it is a fan assisted oven , then it sounds like a noisy oven fan.
It could be a worn or dry bearing in the fan motor. if you open the oven door , you should be able to tell if it is the fan by listening to it carefully.
The other possibility is if it has a cooling fan in the back or on the top of the oven, it could also be that causing the prob, these are about the only things that could be making a noise, as there are no other moving parts that could make a noise.
PLz rate my solution.
Thanks.
Jan 08, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
Baking with digital oven
First let me address the temp ... Buy a meat thermometer and test it against the temp set in the oven.  Though that isn't the most accurate, it should prove whether or not it is way way off.
Second.. convection baking takes considerably less time....
Third... elevation plays a key factor on baking but not so much on cooking meat.  Baking above 2500ft elevation takes 20% longer and above.
Mar 08, 2008 | GE Profile JTP18 Electric Single Oven
F2 error code
Similar problem. When baking over 400 degrees we get the F2 code that can only be reset by cycling the power at the breaker. Replaced the electonics to no avail. I'm thinking its the cooling fan located between the oven and microwave (upper unit) it never comes on which may cause a separate temp switch to generate the F2... but I'm not a pro. :)
Nov 18, 2006 | GE JGRP17 Gas Single Oven
Ovens Logo
191 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
