Question about Dell E173FP 17" LCD Flat Panel Monitor
White screen Screen displays solid white when monitor is turned on. No text or graphics of any sort are displayed.
  • Vidra Apr 01, 2008
    dell E151FPb works ok for a while, then turns all white.
First, always try it on multiple types of computers (different video cards), and multiple cables. Then, open it up and make sure the internal connections are solid. Finally, consider putting in a new inverter. This has been known to fix all-black and all-white monitor problems.
Posted on Oct 08, 2007
What do i do if my pc has lots of virus?
Posted on Mar 17, 2008
My 1545 turns on then the screen slowly goes white but when i mess around with the screen pushing it moving it up and down will come back briefly says Graphics display stopped working
Please test using an external monitor first,this will exclude motherboard issues if the external display is normal.Nearly all screens turning white that I have observed is a screen fault requiring replacement.
Sep 03, 2014 | Dell Inspiron Computers & Internet
My pc is showing a white screen when iys on
Is it an LCD monitor ?
When an LCD screen has turned completely white, there are three normal causes: the screen is defective, the video cable is not connected correctly, or the graphics card on the motherboard of the computer is faulty. You will need to troubleshoot these possibilities to determine which problem you have. If you are not experienced in working on computer equipment, you should not attempt to disassemble your LCD screen because you could easily damage it. Seek professional assistance unless you have experience working on computer hardware.
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See Below for the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/ Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance. Hope this helps.
Dec 30, 2012 | Compaq Computers & Internet
I just bought new lcd display for my Toshiba Satellite R10 Tablet. The inverter is fine, checked the cables and reconnected. But the screen alternately flashes solid white, red, green and blue on the...
you need to download the proper drivers for the Graphics Card Right click your desktop go to settings go advanced Go to the intel(R) tab and hit Graphics Properties thin pick' either Dual Display Clone or Extended Desktop and Click Apply.
Wierdly the Monitor 2 will Still he greyed out in the settings Tab but the monitor will display Good luck
I'm currently trying to figure out it I Can Rotate the tablet Monitor and keep the other monitor Un-rotated Any ideas?
Oct 19, 2010 | Toshiba Satellite R10-S802TD Tablet PC
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
Screen goes blank (white), sometimes screen display will get big
You can update graphics driver, if that does not fix the issue check the display on external monitor. If the external monitor works fine you can isolate checking the display in BIOS Setup scree (Restart your computer and keep tapping F10 to getinto BIOS). If the same issue in BIOS, you may have to change display of the unit.
Jun 26, 2009 | HP Pavilion TX1320US Tablet PC
White 1 inch vertical band on display
just a thought.. Either your Graphics card or your Video Card has gone bad.. unfortunately DELL has a tendency of putting the graphics ON-BOARD and IF the onboard grqaphics card is bad, you'll need to get into the BIOS and turn the onboard graphics off then purchase an after market Graphics driver.. IMPORTANT: make certain that the graphic cars is compatable with the DELL PC OR purchase a less Proprietary system
May 04, 2009 | Dell Dimension 9100 PC Desktop
Mw22u monitor has white screen.
Manufacturer out of business. Local repair shops want more $ to fix than the cost of a new one.
Solution --- Trash old and replace with new display.
Mar 25, 2009 | X2Gen MW22U Monitor
Dell monitor is flickering
If you have another computer, try hooking to it and see if it flickers on it too.
If you hit Ctl-Alt-Delete and choose Task Manager, does the box flicker there?.
Adjust the monitor ratio in the Display Settings/Display/ Display Adapter Properties, Monitor Tab, see drop down (increase screen refresh ratio to higher number).
Nov 10, 2017 | Dell E207WFP LCD Monitor
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Dell E173FP 17" LCD Flat Panel Monitor Logo
319 people viewed this question
Clive
Clive
Alun Cox
