Question about Kenmore 43042 Front Load Washer
Kenore front loader model #481027 water starts to fill then stops
The water starts to fill then 2-3 minutes later stops filling then then starts to fill then stops& doesn't fill up or shut off and doesn't do anything else; no other functions are working (ie. spin, drain)....this was just purchased/installed approx. 6 wks ago & is stackable...pls. advise thanks....
  • 370 Answers
You may have a faulty door switch.
Posted on Nov 17, 2008
Fisher paykel front loader stops almost immediately
Hi, is your water valves on, if so check the water inlet on the washer for continuity. If no continuity than replace it.
Sep 26, 2012 | Washing Machines
Electrolux front loader wouldn't stop filling.
change water valve sounds like its stuck open ... if not only other thing it could be is your main pcb control board ££££££
Dec 30, 2009 | Electrolux EW1000i Front Load Washer
Machine won't fill with water
Check that the inlet screens on the water supply are not clogged.
Make sure the water is for certain turned on (assuring nothing has changed).
If those are not found to be the problem, then it could be the fill valve(s) or the timer control.
Reply back what you find, and I can help you further.
Jan 29, 2009 | GE Energy Star WCVH6260F Front Load Washer
Kenore 80 top loading washer leaks
If is leaking at the front of your washer its gonna be the pump
May 04, 2008 | Kenmore 24032\24036 Top Load Washer
Bosch WFX Excel
You have to replace the water inlet valve, the valve where water enters your machine.
Jan 22, 2008 | Bosch Exxcel WFX 2467 Front Load Washer
Washer filled with water & then stopped & will not work in any cycle.
could be a bad pressure switch did it fill all the way is it a top loader or front loader any noise or nothing
Dec 31, 2007 | Kenmore 24622 Top Load Washer
E10 error with NEW front loader fridgidaire
Are you sure that water fills the tub ? Close the hot water tap and check if cold water fills in, then close the cold water tap and open the hot water one and check whether hot water fills in. Let me knw with your test results.
Aug 12, 2007 | Frigidaire ATF6000ES Front Load Washer
Kenmore 43042 Front Load Washer Logo
251 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
