Will not print within one inch of the bottom of the page
    President:
  • 2,712 Answers
Check the margin properties in the page setup. Click File > Page Setup > Margins and reduce the width of the footer area..That should help.
If not, please post back and i will try to assist you further. If, however, this solution worked, I would greatly appreciate a Fixya rating.
Thanks,
ID
Posted on Nov 17, 2008
Black streaks at bottom of page after printing
Okay Grehner, I suggest you to perform a complete alignment and cleaning/maintenance-service for this printer.ASAP...this will help you out with this particular problem during printing.
Blessings.
Gladmar.
Mar 18, 2014 | Savin Office Equipment & Supplies
Lexmark printer won't print on bottom half inch of page
Make sure to set the correct paper size when printing. Letter - letter; legal - legal size.
Sep 21, 2012 | Lexmark Platinum Pro905 multifunction...
How to add custome page size to tallygenicom 6306 printer with windows xp i have to use width 15in height 12 please rplay soon
Ok, I think the problem you are having is when printing from a version of Windows, basically the problem is the 6306 can only print 13.6 Inch Wide, it looks like you are trying to define a paper size 15 inches wide.
As the paper size defined is wider than the capability of the printer, you do not see this paper size within Windows.
The solution to the problem may be much easier than you might imagine as it is very unlikely you actually want to print 15 inches wide, you more than likely want a paper width of less than 13 inches but are including the sprocket holes and margins at the side of the paper.
Simply define a paper size the width of the printable area of the paper, so long as this is less than 13.6 inches you will then be able to select this within Windows.
Sep 21, 2011 | TallyGenicom 6306 Matrix Printer
How do I change margin setrtings foe Lexmark P4350
If you are preparing to print a document that you have created in Microsoft Word, you may be concerned that all the text on the page will print exactly as you see it on your screen. This is not always the case. You can adjust your print margins to ensure that your text prints on each page exactly the way you would like it to appear.
Opening Your Document
Open your Microsoft Word document by double-clicking the Word icon on your desktop. If you do not see the icon on your desktop, then you can locate it where it is buried on your "Start" menu. Click "Start," followed by "All Programs." Then click "Microsoft Office," followed by "Microsoft Office Word." A new document will open on your screen. Click the "Office Button," followed by "Open." Scroll through the files listed, and double-click the one you would like to print. It will open on your screen.
Check Your Margins
By default, your page margins are set to 1-inch margins on the top, bottom, right and left of your page. You can check your margins or change them by clicking "Page Layout," followed by the "Margins" button.
Select New Margins
Select a different margin size, such as "Narrow," which indicate 1/2-inch margins, or "Wide," which indicate one-inch margins on the top and bottom and two-inch margins on the left and right. You also can select "Moderate," which indicate one-inch margins on the top and bottom and 3/4-inch margins on the left and right. Finally, you can select "Mirrored," which indicates one-inch margins for the top, bottom and outside. The inside margins are set at 1 1/4 inches.
Print Your Page
Print your page. Press "Control" plus the "P" button. The printer dialog menu will come up. Make sure that "All Pages in Range" is selected. Press "OK." If your printer cannot print your new margins, then a new menu will pop up telling you to adjust your margins.
I hope you find it very helpful. Best regards.
Aug 22, 2011 | Lexmark P4350 All-In-One InkJet Printer
I am getting ghost images on a HP P2015. Top third of page repeated twice more once at half page and again toward bottom of page. Even happens when printing test page by pressing the "Go" button...
Sounds like the fuser unit roller needs cleaned to do so let it cool down & then take some celophane clear tape about 7 inches long & roll it into the rollers by turning the gear to where the sticky side is against the grey "hot" roller.
This should fix the problem, also best practise to do this on any roller you can see within the printer.
Hope this helps!!!
Jul 11, 2011 | HP LaserJet P2015dn Printer
We are using 8 1/2 x 11 letter size paper. When we print, the top of page is cut off. How do we correct the alignment?
Have you checked the top margin setting of your print job. It should be less than 1/4 inch. If set higher it may cut off the top of the page, before it's sent to the printer. The printer will not print anything within 1/4 inch of the edge of the page, by design.
Feb 01, 2011 | HP LaserJet 6p Printer
Is there anything I can do to print closer to the top of the page? Even when I have my top margin set to zero it starts printing an inch from the top. I have it set to center on the page. In print...
if you print web pages, click File, then click Page Setup, from there, adjust the top margin. Do the same on the application you are using for the document or file you are working on.
Aug 29, 2010 | Office Equipment & Supplies
When printing a greeting card the copy appears too low on page so one fourth of an inch is cut off on the bottom of the page.
On Printer press Menu button.
Scroll down to tools an press ok.
Scroll down to Align Printer and press ok.
The Printer will calibrate automatically.
May 11, 2009 | HP Photosmart 8250 InkJet Printer
Printed 12 inches
check the page setup for header and footer margin sizes and top or bottom margin sizes .
May 13, 2017 | Tally LA650 Matrix Printer
Computers & Internet Logo
David Payne
David Payne
