Question about Kenmore 20172 Top Load Washer
Washer repair While son was washing a unbalanced load of clothes a pin fell out into a plastic catch cup under the washer. We put the pin back in, but the washer will not spin right.
The pins are supposed to fall out thats why there are plastic catch cups. Its designed for shipping with the pins put back your washer will not work properly and may damage it if continue to use it with the pins.
Posted on Dec 02, 2006
Noticed plastic slivers in the drum and under the rubber boot.Is the from the drum being unbalanced
Could be that the 'spider' mount for the drum is broken and the drum is catching on the surrounding plastic outer drum.
Mar 15, 2016 | Kenmore Elite 45986 Front Load Washer
My frigidaire front load washer will not consistently spin the water out of the clothes.
The pump is electric. The rubber hose going down to it has a coin catching cup in it. If you remove the small hoses it will be a ***** to get them back on. Your mission will be to remove items from coin cup and put her back together WITHOUT disturbing the smaller hoses that come from tub.
Aug 04, 2012 | Washing Machines
Unbalance load
you have to many clothes in ur washer. if you wash a comforter it gets unbalanced. or rugs. they are the worst. under your washer theres a plastic cover over the motor in the center of that cover theres a silver screen it needs a 1/4 inch allen wrench. insert inside screw turn clock wise to ensure that your rotor< plastic cover> is tight.
Jun 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer says it has an unbalanced load while washing even if i run it with no clothes in the washer
you have a cracked motor housing. Lay machine on its back. remove centre motor bolt with allen wrench. pull off rotor. remove four bolts holding windings. unplug wires and speed sensor. inspect plastic housing with wires around it. you will see cracks in the plastic. there's your problem
Oct 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
The tub is spinning off balance. Yes the load is evenly distributed and the washer is level. We repaired the coupling and now hooked the washer back up it is spinning out of control banging against the...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If you look at the section on "Machine Base Parts" you'll see a number of springs and vibration pads.
It's possible that one or more of the springs or pads has come loose or broken.
In order to get to them you have to remove the cabinet.
Here is a description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=90fdc122f6335c7c64f46f2ea1b1c887
Also see the Whirlpool Service Manual for top load washers. It has a troubleshooting section that describes the reasons for excessive walking or vibration.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
The plastic cup and brass pin are simply shipping tub locks. The pins are designed to brake off and fall into the cups when the washer is installed. They are NOT a problem.
Mar 16, 2010 | Kenmore Washing Machines
I have a Kenmore top loading washer. While moving it into the house, it made a loud sound and a small copper pin fell out of the bottom. Does anyone know how to put this back in place?
That pin is a pin used to move the washer (secure the drum) and is not used when in normal operation. There are 4 total that should be removed. They are stored in little cups on the legs, and likely fell out of the cup.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 10, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I HAVE REPAIRED THE RUBBER DRIVE COUPLING ON MY WHIRLPOOL 3LBR6132EQ TOP LOADER. WHILST REPAIRING IT A FLANGED PIN OF 10MM DIAMETER FELL OUT. THE WASHING MACHINE SEEMS TO HAVE VERY BAD VIBRATION IN SPIN...
The pin fell out of a catch cup used for transporting the washer when new. It is not important unless you put it some place it does not belong.
If you laid the washer down to do the repair you probably got the base plate out of alignment. Open the lid,reach inside and grab the wash tub. Pick it up as much as you can and shift it around. It will usually reseat the plate.
Also block the front of the washer with your foot and raise the rear of the washer off the floor. The self leveling legs should drop down. Let the back of the washer loose and it will settle in on the leveling legs.
This washer should be left in the upright position to change the drive coupling.
Jan 04, 2010 | Whirlpool Washing Machines
Pins that center tub on my kenmore washer fell out into small cups that look as though they were made to catch them. the pins look like nails with holes drilled near the point. the holes i asume are for...
The pins may just be shipping pins that are designed to break and fall into white plastic holders when the washer is installed.
See the Sears parts site for your washer at:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=11092281100
to determine if these are the parts.
Sep 10, 2009 | Kenmore Washing Machines
Kenmore 110.20904990 top load washer
ignore those cups with the pins those pins were the travel lock devices and the cotters were attached to the yellow lanyard that whoever first put the unit into service pulled off of the back of the unit per instuctions. this pulled the cotters out of the pins which then fell into those cups. the cotters came out with the lanyard and are long gone. the not spinning is due to something in the clutch not working properly. the moving to one side is caused by one of the pads that the suspension plate rides on being missing. you can look at the diagram on sears website at the parts look up and see were the pads go and find out what the suspension plate is and such good luck!
Jul 27, 2008 | Kenmore 22422 Top Load Washer
Kenmore 20172 Top Load Washer Logo
139 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
