Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
Hot water dribbles thru shower head when turned to hot
The Moen 3175 when turned for hot water...water dribbles thru shower head....when turned for cold water..no problem.......both showers...both are moen shower valves...very little water in the house have the same problem
  • 2 more comments
  • weewillie_56 Nov 19, 2008
    due to lack of use, calcium deposits build up on the stem..also the flat rubber partial sleeves on the side of the stem can move andblock the flow of water......pull out the valve stem with a moen extractor.....check the sleeves...clean the deposits...apply a very light coat of plumbing grease...re-insert......put everything back correctly...works like a charm................
  • Anonymous Nov 26, 2008
    i turn the water to cold and nothing comes out but a few dribbles, hot water is fine.
  • Anonymous Mar 17, 2014
    How to make water come out once you take the hand held from the main shower head.
  • Anonymous Mar 30, 2014
    using the Grohe Avensys Classic BIV
    Problem Solver:
  • 5 Answers
Replacing the cartridge should solve the problem, the balancing spool is stuck, replacing it will solve the problem. The valve should look like this http://www.moen.ca/shared/pdf/3170pt.pdf . I have unstuck the spools in the past, soaking it in white vinegar will help to remove build up.
Posted on Dec 04, 2008
All hooked up dobble cked but water only trickles so ample supply
Make sure the hot water is turned back on. Pressure balancing valves won't work if both cold and hot water is not on. Pull shower head off and test to see how it flows out of the shower arm. If good, clear out shower head. Whenever water is turned off for a time, and then turned back on, restricting shower heads and aerators usually get clogged. In the future, always open up a tub spout before turning water back on. This releases the air and other debris most effectively before testing other fixtures in the house.
Apr 23, 2011 | Moen 3175 Legend One Handle Shower Faucet...
Turning on hot or cold water I get a loud screeching noise and very low pressure. If I keep turning the handle, I can get rid of the noise, but still low pressure.
It sound like you have sediment blocking your valve, faucet airiator or shower head (depending on what you're using). FYI: if it turns out to be defective all Moen faucets and showers have a life time warantee.
Jun 12, 2010 | Moen 3175 Legend One Handle Shower Faucet...
When I turn my MOEN Shower faucet to the HOT position hardley any water comes out.and it is just luke warm.
check your cartridge,and i believe your mod # 3175 has a balancing spool #1423, i think if i remember it is to the right of the cartridge,a large screw driver will get it out.
Feb 27, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Just installed a Moen shower fixture, & the knob for the shower head doesn't send water to the shower head-- I don't get it!
I just installed one this weekend. Make sure that the cartridge has the embossed "HC" at the top (for Hot on left, Cold on right) when you slide it back in. Also, before putting the handle on turn the cartridge shaft so that the completely flat part is toward the top and the side with the small notch at the end is toward the bottom.
Jul 26, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Only hot water/ little pressure
You must of turned off your water to the house or maybe it was turn off in the street recently because it sounds as if you have debris in you strainer remove the head and rise of removing any dirt rise out both front and back of shower head while head is off run shower to make sure you are getting full pressure out of the pipe that the head is connected to
Jul 11, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Our shower has not been used for a while. Now when we turn it on
Do you have good flow if you remove the shower head, y/n if not how old is house,galvinized plumbing?? or copper plumbing. Sounds like you have a clogged valve and if so this link will be good.
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Apr 02, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Not alot of hot water?
1st Check the temperature restricting coller behind the cover under the handle. It is used to restrict the flow of hot water to stop you from being scaulded.
2nd Those set screws will control the flow. Check to ensure both sides are open the same amount of turns. If the water pressure is good turn in the cold side.
Jan 08, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Not enough hot water
The screws remove the handle. After the handle is removed their are little plastic like gears to limit th ehot watr. Relocate the gear ring for more hot water.
Jan 06, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
1,079 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
