Question about Kogi L7CH Monitor
Monitor showing dots all over
My monitor when turned on shows dots all over and is so blurred now that i cant even read whats on the screen.It started all of a sudden couple of days ago and has progressed.
  • 45 Answers
Dear user,
It could be the following 4 errors:
1, Vga cable damaged.
2, Video card memory failure.
3, Lcd Panel starterd to damage.
4, The connection between the computer and the monitor is not stable, the plug is not tighten on a side it could be any sideo on the vga cable meaning you have not screwed into the monitor it can lease and fall down from the monitor.
Please check thease.
Posted on Mar 20, 2009
How to turn my 1080 hp monitor on connected to my computer
Look for the power button/switch on the monitor
Oct 13, 2017 | HP Computers & Internet
Acer monitor screen showing partial screen only. rest of screen showing black & white dots.
Hello there.
Try the monitor with ANOTHER computer,
This will prove whether it is the Monitor at fault or not.
Sep 25, 2014 | Computers & Internet
Montor is blured with horz lines
The monitor or lcd screen is probably going bad or the video card inside the computer is bad. To isolate the problem try connecting an external monitor to the laptop. Borrow a Monitor from a neighbor, friend, relative or co-worker and connect it to the laptop. If the Borrowed monitor displays ok without the blur and lines, then your lcd screen is bad and the video card inside the computer is good. If the Borrowed monitor displays the same way as your lcd screen with the blur and lines, then your video card inside the computer is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 31, 2012 | Computers & Internet
What does it mean by dead cells?
I assume this is related to your LCD monitor.
I think you mean dead pixels. The LCD monitor has tiny pixel elements, one for each red, blue, green color and each one of these colored pixels are turnes on by a transistor. When a transistor fails then the colored pixel it controls does not light up. This is a dead pixel and it shows up as a tiny black dot.
If the screen displays a blue screen, a dead blue pixel will appear as a tiny black dot in the blue screen.
You normally would not notice a few dead pixels unless they are grouped together.
Sep 20, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
Blurred image in Samsung Syncmaster732nw monitor
For best pictures, you need to set your PC video resolution to the native resolution of this monitor, which is 1280x1024 @60Hz. Try that first before opening up the monitor to look for bad components.
Post back, see what usually goes wrong with SAMSUNG monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 29, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
My monitor show me bright for 4 sec only
morinj_04, "Switch-mode-power-supply" going into partial shutdown mode. Read more of my BLACK screen and BLACK and BLANK screen responses in my profile. You will get the hint as to what to do!!!
12fixlouie
Jan 30, 2010 | ViewSonic VX715 17" LCD Monitor
Monitor turns on but screen is white
your vidio cable popt out read this it shows you how to take it apart to fix it
http://www.ccl-la.com/LCDrepair2.htm
Jan 23, 2010 | Dell E173FP 17" LCD Monitor
The l226wtq goes black
Try shining a flashlight on the screen, or without the flashlight, try to see if you can distinguish anything on the screen at all, if you do, the backlight is dead, or the monitor has an internal most likely unfixable problem.
May 01, 2009 | Computers & Internet
Problem with Dell 2100FP LCD monitor
Dell support , would recommend you to buy a new monitor because , they donot do any repairs on the LCD monitors., except for exchanging them, if they are in warranty. You can try the following people , they do repairs on dell flat panels
http://www.lcdrepair.us/
Thanks
proton
Aug 02, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Bright,thin line, in the middle of the screen, then...
1. I turn on the monitor, I hear a 'cracklin' sound
Reply: In a CRT Monitor there is a component called EHT which generates High voltage which is connected to the anode of the CRT, If there is any leakage due to moisture can cause this crackiling sound, You need to clean this high tension wire or replace the EHT ( CAUTION : BE AWARE OF HIGH VOLTAGES )
2. The screen only shows a bright, thin line.
Reply: The vertical Drive section of the monitor is faulty.
Dec 21, 2007 | Hitachi SuperScan Elite 802 21" CRT...
Kogi L7CH Monitor Logo
351 people viewed this question
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Computer Links
jay kaye
jay kaye
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
