Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
Why isn´t my computer able to produce audio output?
I would like to know why i can not configure sound and audio devices.
  • Intel Master
  • 19,396 Answers
Usually that happens because the audio driver software is not installed , or it is malfunctioning.
You need to identify audio card details, or if the computer is a branded one just make and model, then you download drivers from computer manufactrure website and install them.
If your computer is a brand one (eg HP Dell Acer etc.) just submit a new quetion on Fixya using the following link, and providing details on make and model:
Posted on Nov 17, 2008
My Insignia TV isn't producing audio. It produces picture just fine but won't produce any audio at all and when the DVD player isn't connected to that TV it won't produce any audio either.
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Apr 07, 2017 | Insignia Televison & Video
My computer is a SyncMasterP2570HD i cant get any sound to come out but it is detecting sound how do i fix it
The Samsung SyncMaster P2570hd is a monitor with speakers; it isn't the computer itself. I'll assume that you are dealing with a computer connected to the monitor and not a set-top box. Make sure that Mute is not enabled on the computer. There should be an icon on the lower right hand side of a Windows desktop. If the mute is enabled, it will have a red circle with a diagonal line through it. Left click on the icon to remove the mute (change the volume or click on the mute icon). Test the monitor's speakers by connecting it to another device with known good audio output.
Next how are you connecting the monitor to the computer (VGA, DVI or HDMI)? If you are using VGA or DVI (including DVI to HDMI), you need to connect an audio patch cable (3.5 mm) between the speaker (green port on the back of a sound card) or headphone jack of the computer and the audio input jack of the monitor. The audio input jack is between the DVI and VGA ports. You can test the output of the speaker jack on the computer with regular computer speakers. Plug in the power cord (or USB cable) for powered speakers. If the free-standing speakers work, check the volume setting on the monitor with the +/- buttons to the right of the menu button. Do not press menu first, though. If that doesn't solve the problem, continue using the separate speakers. (Unless the monitor is still under warranty, it usually isn't worth taking apart a monitor to replace the speakers. You may be able find replacement parts online.)
If you are using an HDMI cable, check the output audio setting to see if the HDMI audio is available. For Windows, click on Start > Control Panel > Hardware and Sound (Windows 7). Then click on Manage Audio Devices under Sound. In the Playback tab, check what available audio devices you have. Make the HDMI the default device by right-clicking on it and selecting Make this the default device. (Other versions of Windows will a slightly different route to this panel.) You may need to restart the computer to get the audio signal on the HDMI cable after setting this. Note: not all video cards/computers support HDMI audio. If you don't see HDMI listed in the Playback devices, connect an audio patch cable as with a VGA or DVI cable, described above. Use stand-alone speakers if the monitor's speakers are bad.
I hope this helps.
(I have had the speakers fail in monitors; <$30 separate speakers are an adequate replacement for those built into a flat panel monitor.)
Jun 26, 2012 | Audio Players & Recorders
3rd USB Port doesn't work and "no audio output device is installed" in Vista 32-bit
The USB port is damaged, or missing the driver for that port, check device manager.
Mar 15, 2012 | Computers & Internet
Audio output device
Hi.
The audio output device in your computer is the audio adapter board (or circuit). This is the device that produces sounds and send them to the speakers.
If you get a message telling you that there is no Audio Output Device detected, or that the Audio Device is not working, that usually means that there is a problem with the audio driver.
In that case the problem is often fixed downloading and reinstalling the drivers for your audio device. If there is a problem with the audio output device, go to the computer manufacturer website (e.g. Dell, HP, Sony etc.) and download the audio drivers for your specific model. When download is complete install the drivers and restart the computer.
Regards.
Ginko
Jul 20, 2011 | Microsoft Windows Vista Home Premium with...
My laptop isn't giving off any sound. and it is saying no audio device installed how can i fix this
what is your laptop model? try going to there website and search for the audio drivers for you model and download them if you can give me the make and model i can find them for you
May 14, 2011 | Computers & Internet
It does seem to be getting a power sound from my computer. When I plug in the jack to my laptop it does not make any sound to the logitech speakers and the sound continues to play from my laptop speakers.
You need to change the default audio output device in the audio control panel and restart the application (e.g. Media Player) you use to produce the sound.
Feb 07, 2010 | Logitech X-240 Computer Speakers
All 4 rear speaker is not working. I have checked all wire, Output is not comming . I have connected through creative sound card.
you have a creative card that takes 7.1 ?? And you have changed you settings in "control panel/ sounds,speech and audio devices (thus making the necessary assignments for 7.1 and configuration requested) in the windows box opened (Sounds and Audio devices Properties) select the Audio tab and choose your card...apply the settings ....
Dec 20, 2009 | Creative Labs Inspire T7900 Computer...
Sonar LE: no playback b/c "NO MIDI OUTPUT" selected
You have to go in to the Sonar configuration and select what the default MIDI and WAV input and output devices are. That is usually handled by the ASIO driver. In your case you would select the USB mic for input, and for output you need to select your sound card. For midi you need to configure the midi controllers and the software synth or soft instrument you are using.
If you need any more detailed help I need to know what version of Sonar LE it is and what sound card. I am guessing it detected the mic and just needs the output device configured as I mentioned.
Dec 31, 2008 | Edirol UA-4FX External Sound System
Audio output device
Hello there kedarsonali first of all dealing with these things needs delicate decision making first I advice you to go to the device manager of your computer and scroll down to your sound device make sure that it is there if yes the best thing to do is to try and update it over the internet, "updating it will also fix whatever problem the device might be facing" if that doesnt work try re-installing the sound device off your sound card disc. If your problem isn`t solved or i have misinterpreted your problem write back to this post and explain it in a more clear way so i can help you overcome this problem. hope i helped you bye! or il be waiting to hear from you again!
Jul 02, 2008 | Microsoft Windows Vista Ultimate Edition
NO AUDIO OUTPUT DEVICE IS INSTALLED
windows key + R = open : devmgmt.msc
Sounds, video and game controlers > (right click) Realtek high definition audio > update driver sofware > browse my computer for driver software > let me pick from a list...> double click on Realtek high definition audio > YES to update driver warning > AND SWEET SOUND IS AUDIBLE :D
Dec 14, 2007 | Microsoft Windows Vista Ultimate Edition
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
65 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
