Question about Panasonic PV-GS31 Mini DV Digital Camcorder
Help!! No playback!!
When I switch the dial to play back & watch what I've recorded all I get is a blue screen. The date disappears. I have no idea what happened!! The tape is still working, I can hear it when I fast forward and rewind, and I can hear it playing. But no picture or timestamp.
I even changed tapes thinking it was the tape- but no luck..
  • cg0617 Nov 18, 2008
    The strangest thing happened. I was fiddleing around with the cam while calling around trying to find a local service station (called Panasonic and they told me the closet one was in TN and I am in WI!!) and it started working again!! I have no idea why or what happened in the first place. But I am going to see what happens. For now, it's fine.. Thanks for the reply.
  • 4,402 Answers
First try a cleaning tape, if that doesnt work it most likely the tape path is out of alignment and you will have to send it in for repair.
Posted on Nov 17, 2008
Sony ccd trv 308 had a error c 31:23 and c 31:22 , beeps when trying to play and record. Found the pinch roller jam inside , took it out and fixed it with heat shrink tube, error gone , camara runs good ,...
Did you possibly hook it up right to your tv? Where was the blue screen. How do you know it recorded anything if your not sure if it works right. Is the tape moving? Sometimes it may appear to be moving and really it's not. Hear isn't a good thing with a tape recording device. I know this might sound trivial, but I would read the directions if ya got them and make sure your not skipping a step. If you record on some machines you have to switch from record back to play mode. Where is the blue screen.
May 20, 2014 | Video Cameras
Bunker hill 67139 dvr hard drive wrong year 2058
The issue may be is that you have a DVD in your dvr , that still shoes that date and time. Just a possibility, not sure,. try to see if you can take DVD out of dvr, and use a new one. I happened to me but, the case was a vcr,and I had a recorded video tape which while playing , was showing a blue screen, with "no data received" which actually it was when no data vcr was receiving from cable at the time it was recording . If the problem still is not solved then there is issue with some circuits, and processors. Also you may want to check if Bunker Hill has any customer support, to check with them.
May 18, 2014 | Televison & Video
Blue screen
In the playback mode, the screen is suppose to be blue, till you start the tape playing, but if you get the blue screen in the record mode, I have not idea how to help you. You should see what the camera lens see, when in record mode.
Apr 02, 2009 | Sharp Viewcam VL-Z5U Mini DV Digital...
Dvr4-alert full screen playback
That's because this is a quad. It compresses all 4 video feeds into 1 file. When you play it back, it decompresses the video and shows you each camera. Playback through this unit is the only way to see 1 camera at a time.
To be able to copy 1 camera shot to a DVD, this is what you need to do: You need to have a TV with Video in and Video out jacks.  Connect the Quad to the TV Video in jack and connect the TV Video out jack to your DVD Video in jack. Playback a single camera shot on the quad to the TV and hit record on your DVD. - The DVD will record whatever is shown on the TV.
Oct 26, 2008 | Home Security
Canon Optura 40 playback - only get blue screen - no image, no sound
Try a cleaning tape. Buy a good quality cleaning tape (Panasonic makes one) and remember: cleaning tapes are abrasive so don't overuse it! Overuse can result in the need to replace the rotating drum assy in the camcorder. I'll bet a cleaning tape takes care of your problem.
Oct 25, 2008 | Canon Optura 40 Mini DV Digital Camcorder
Help! My Voice recorder is stuck in Slow playback/record
To switch back to normal press the PLAY button during
"Every time the PLAY button is pressed, the playback speed will switch."
Mar 31, 2008 | Olympus DS-40 Digital Voice Recorder
JVC GR-DVL120 Playback
you should have the heads cleaning,
try to put a cleaning tape and run it for playback then try recording again
Nov 20, 2007 | JVC GR-DVL120 Mini DV Camcorder
Try to playback the tape and the screen is all blue
your heads motor ( drum ) cable may have have come loose or is dirty - since the cleaning tape made some difference the heads were dirty or almost worn out ( cleaner tape is abrasive ) so now there isn ' t enough signal ; if your date and time display worked only in play ? ( still works for camera record video ) your guides were out of alignment - and the cleaning tape took your guides even further out of alignment ( alignment here starts at $ 50 + shipping )
Jan 24, 2007 | Panasonic PV-GS2 Mini DV Digital Camcorder
Playing MPEG's
* The MPEG Playback function works in M. PLAY mode only. * You can play moving picture images on the Memory Card. * To hear sound during MPEG4 playback, you must hook up to a PC and listen to the PC's speaker. (You cannot hear it from the speaker on the camcorder or a TV) 1. Set the mode switch to MEMORY CARD position. 2. Set the power switch to PLAYER mode. 3. Press the MENU button and turn the MENU DIAL to highlight MEMORY. 4. Press the ENTER button to enter sub-menu. 5. Use the MENU DIAL to select MPEG4 from the sub-menu. (M. PLAY SELECT) 6. To exit the menu, push the MENU button. 7. Using the (FWD) and (REV) buttons, search for the moving picture that you want to playback. 8. Press the PLAY/STILL button. The moving pictures recorded on the MEMORY CARD begin playing back.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Panasonic PV-GS31 Mini DV Digital Camcorder Logo
142 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
