Question about Kenwood Car Audio & Video
Installation in a boat. How to maintain the memory?
I am fitting the unit (Kenwood KDC-W3041) in a boat. I do not want it permenantly connected to the ship's battery for safety reasons so wish to supply an alternative source for the memory. Is this possible? What is the minimum voltage required for this?
    Brigadier General:
  • 6,966 Answers
A possible method would be to hardwire a rechargeable 12V battery to the yellow wire and ground. The rechargeable does not necessarily have to be high capacity, Actually, a series of 10 AA 1.2volts penlight battery would do the job. Alternately, a small motorcycle battery would probably be better. Wiring wise, pls reference below diagram.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 17, 2008
KDC-w3041 says PROTECTION when i turn it on
Sometimes if the power is removed it requires a code to be input, to remove the protection, you will have to contact Kenwood, and ask for the code to clear it. This is an anti theft feature. Often the car dealers have these, or try an auto-electrician.. BTW your English is good.
Mar 19, 2010 | Car Audio & Video
Kenwood KDC-W3041 protect
check all the connections between the unit and the speakers check the speakers also and if the problem remains replace the power amp ic.
Mar 09, 2010 | Kenwood Car Audio & Video
When I plug my iPod into my car stereo, it's a Kenwood KDC-W3041, sound only comes out of the speakers in one door, but when I play a CD, sound comes from speakers in both doors. What's wrong?
If your using the aux plug in the front make sure the plug is fully inserted into the ipod and the stereo. then make sure all audio settings are set correctly. If you are using any other type of connection for your ipod ensure the connection is not loose.
Dec 10, 2009 | Car Audio & Video
I was given a Kenwood KDC-1011S. All wires labled
Yellow is for constant 12v. (Power directly from battery) so it maintains preset stations and clock memory. Red is for Key "on" 12v Power (turns on when ignition key is on) Black is for Chasis Ground. What type of vehicle is it going in? I can get you the corresponding vehicle color as well. Post a comment with make/model & year vehicle. Hope this helps.
Aug 16, 2009 | Kenwood KDC-1011S
Kenwood kdc-w3041 protect mode
Hello ia737,
The "protect" display is probably being caused by a shorted or grounded (touching vehicle chassis or other ground) speaker wire. Check the speaker wires for bare spots, etc and insulate or replace as necessary.
You do not need to remove the fuses to force a "cold reset" of the W-3041. You can simply press the "reset" button on the front of the unit. It's the little recessed button at the lower left of the volume control. Use the straightened end of a paper clip or ballpoint pen to momentarily hold the button in.
Hope this helps.
Jul 23, 2009 | Kenwood Car Audio & Video
Is remote necessary to reset code on kenwood kdc 319
my CD player is Kenwood KDC-W3041 displayed protect and i can't turn it on. what can i do for that?
Mar 29, 2009 | Kenwood KDC-319 CD Player
2 problems, what are the red and yellow wires on a Kenwood kdc-mp2028? and can you install a used kenwood without the remote?
You can use the head unit with no remote - that's just an accessory. As for the wires, the red is switched power (this gets wired in so that it only has power when the key is on - when the key is off, it turns off the radio). The yellow is constant 12v power (to maintain power to the head unit so that memory settings, treble/bass settings, and the clock are maintained when the vehicle is shut off).
Sep 24, 2008 | Kenwood Car Audio & Video
Kenwood KDC-W3041 does not save changed settings
hi,
It seems as if there's no permanent live to the memory.
If your swap over the black and yellow cables [link black to yellow, and yellow to black], this should solve the problem.
Hope that helps.
Jun 22, 2008 | Kenwood Car Audio & Video
No Sound - boat stereo
Assuming that the four speakers are connected to the amplifier, then the amp is the most likely problem component. Does the amplifier show a power light when the system is turned on? Note that there is probably another fuse in the amplifier power wire, near the battery.
Mar 16, 2007 | iLO XM-MP3-CD Car Stereo
Car Audio & Video Logo
103 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
