Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
Ir 2200 color is cleared from the paper
The color is not fixed good on paper the color swept down of paper not all
  • 168 Answers
If the toner is not fused to the paperit is more than likely your upper fuser belt
Posted on Dec 08, 2008
Solution to erro e000007 on ir 2420 copier
What is remedy error code E000007-0000 for canon ... - Fixya
www.fixya.com/.../t14373194-remedy_error_code_e000007_0000_can...
Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
Imagerunner 2200 error E000007-0000 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Mar 15, 2007 - 4 posts - ‎4 authors canon ir 2200. hi, this machine do not have fixing roller. machine have fixing film assembly. this code is for damaged fixing film, on the end you ... Error Code Canon 3025 E000007-0000
Jan 30, 2013
Error Code The dreaded e000007-0001 error code!
Sep 5, 2011
Error Code Color ImageRUNNER 4060i has code ...
Jun 30, 2011
More results from www.copytechnet.com
Nov 05, 2015 | Office Equipment & Supplies
How do i clear error e000007-0000 on a canon ir 2200 photocopier
Fixing film assembly may need to be replaced if error cannot be cleared. Fixing error codes should be reset by a professional only. Fuser assembly must be examined before resetting the E000, E001, E003 and E007 codes. Enter the service mode this way: Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again. Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here your tech can reset the error codes. Then turn machine off & on again.
Sep 04, 2014 | Canon Cannon Ir 2022 Photocopier
521:DUPLEX JUGGER MOTOR PROBLEMS
I'm taking a wild guess..... Are you working on a Canon copier??? If so,what model are you working on? If it is a IR-2200 - 3300 series, or one that is basicly the same.. Ir-200 - 330... Odds are the jogger motor is getting stuck out of "HP". The jogger unit is on the right side of the copier right above the paper feed unit. It comes out with the paper feed unit. There is a small motor that may have a cracked gear. You may need to replace it. The copier will all way's check for home postion each time the copier is turned On.... So, you will have to fix it to get read of the problem... Good Luck
May 27, 2012 | Office Equipment & Supplies
Problem with printing on canon ir 2200
go to run prompt on client end and typ \\ip add of main pc where ur printer actually connected nd then u will get shared printer on display, u will get shared icon of ur network printer right click there nd connect it .... if it doesnt show any problem to connect it will work nicely ...........
Apr 16, 2010 | Canon (6981A002AA) for imagerunner 2200,...
I have a canon ir2200 that is saying paper jam on front left. I can find no paper jam anywhere and have checked to see that the dials on the paper trays are set correctly. Also I have turned copier on and...
I am Sunil choudhary resident in Junnardeo dist. Chhindwara, My machine canon ir 2200 b&w machine -Miner problem paper jam-some move paper & right side jam paper & jam indicator show
Jan 11, 2010 | Canon imageRUNNER 2200
Clear E000002-0000 on canon ir 2200
Press the usermode star and release and then no 2 and 8 togheter and relealese,press the usermode star again.The machine will go in to service mode.Select copier and then on the next screen select funcktion and then clear.press the error and select ok.Switch the machine off for a minute and on again.The machine should be ok.After the clear has been done and the error is still showing then the fixing unit is faulty.
Dec 12, 2009 | Canon imageRUNNER 2200
CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
Dec 02, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Canon IR 2200 error code E000002-0000
It's to do with the fixing unit (hot bit) left hand side. Make sure theres no paper **** any where near it. If so switch off then on.
If not it looks like there may be a fault with the fixing film or may just need the error resetting in service mode.
Mar 23, 2009 | Canon imageRUNNER 2200
Error message on Cannon IR 3300
that is a stack delivery error could be one of the motors or a board do you have the internal finisher or external
Jan 13, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Ir 2200 a3 paper at the end is
Try to flip the A3 paper (in your paper drower), it may be if it isnt used so often it can be moisty, so when it pass the fixing roller, he bacames undulate.
Or if A4 is ok, that means that sorter does not work OK, because the A3 is longer and it pass longer way and more rollers.
Nov 11, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Computers & Internet Logo
62 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
