I have a casablanca ceiling fan that worked fine until recently. When I turn the lights on they flecker. When I turn the fan on the fleckering stops. Lately, I noticed a grinding sound when the fan is running. How can I fix this problem?
The wall switch has the option of power on/off, revese fan direction, lights variable intensity setting & variable fan speed.
Grinding indicates failed bearings. This is causing excess load in the motor and that is causing the flickering. This is not a user repair and would like cost around $130.00 for labor and bearing assuming you find a shop willing to do it. Most fans have pressed bearings and are very cheap.
Posted on Sep 02, 2017
SOURCE: Ceiling Fan broken
clean and grease the fan check the black cap to see if it is not fauly if it is replace it.if that does not work the ammeture is faulty time to buy a new fan good luck
Posted on Apr 28, 2007
SOURCE: Casablance Ceiling Fan Trouble
itake it the light is still working if it is check the wireing from the pull switch to motor unless you have a neon live tester or volt meter thers nothing else you can check
Posted on Jul 25, 2008
SOURCE: Casablanca Intellitouch Fan was working fine..
Sounds like either the IT wall switch has malfunctioned, OR the IT board inside of the fan has shorted out. This is actually a fairly rare problem with the boards and you may get it covered under warranty. Try calling Casablanca. This fan is worth repairing rather than buying a new one.
Posted on Jun 10, 2010
SOURCE: Intell-Touch instructions for casablanca fan/light
Light Operation: With the light in the off position press and hold the light button (do not let go). The lights should start at a dim setting and gradually get brighter and brighter. When they get to a setting you desire let go of the light button. To reduce the brightness of the light you must first turn the light off, and then press the light button and hold it in as described above. If the light is off, and you press the light button quickly to turn it on, the light will go back to the previous setting. So if you last had the light on the high setting, it will go back to the high setting, if you had the light at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the light intensity at any time by pressing and holding the light button, but to decrease the light intensity, you must first turn the light off, and start over by pressing and holding in the light button.
Fan Operation: With the fan in the off position, press and hold the fan button (do not let go). The fan should start at a slower speed and get faster and faster. When the fan is at the speed you desire, let go of the fan button. To slow down the fan speed you must first turn the fan speeds off by pressing and releasing the fan button. If the fan speeds are off, and you press the fan button quickly to turn it on, the fan will go back to the previous setting. So if you last had the fan at the highest setting, it will go back to the high setting, if you had the fan at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the fan speed at any time by pressing and holding the fan button, but to decrease the fan speed you must first turn the fan off, and start over by pressing and holding in the fan button.
Posted on Aug 05, 2010
Dec 23, 2014 | Casablanca Fan Dryers
Jun 01, 2014 | Casablanca Fan 3245T Ceiling
Aug 08, 2011 | Casablanca Fan 3245T Ceiling
May 09, 2017 | Casablanca Fan W-52 Remote Control
Feb 08, 2011 | Casablanca Fan Trident COSMOPOLITAN...
Feb 15, 2010 | Casablanca Fan 3245T Ceiling
Mar 15, 2009 | Dryers
Nov 01, 2008 | Casablanca Fan 3245T Ceiling
Jul 16, 2008 | Casablanca Fan 3245T Ceiling
Apr 27, 2007 | Casablanca Fan Bel Air 3811T Ceiling
67 people viewed this question
