Question about Maytag Atlantis MDG7400AW Gas Dryer
How do you get the front off
My dryer won't heat, how do I get the door off
Hi have you found out how to do this? I've taken my door off once to fix another issue and can post the instructions if needed.
Posted on Jan 14, 2009
Dryer won't heat up and light bulb turns on then off when door is opened.
Does the drum spin when you shut the door and start the dryer if so it wouldn't be a bad door switch. 1st. thing I would check would be the igniter with front kick panel off dryer it's located at the bottom right hand outer side of drum in the burner duct. here's how you check it with door shut start dryer and look for a orange glow from the igniter if no glow it's a bad igniter if it's not the igniter it could be a thermostat or a flame switch check these things if need more help I'll be glad to help.
Feb 25, 2013 | Dryers
Dryer won't start
First, with the door opened, push and release the door switch. Does the light go on and off?
Dec 07, 2012 | GE GTDL200EMWW 27" Front-Load Electric...
Admiral dryer super capacity dryer won't heat up and light doesn't stay on. It happened when we first brought it home years ago and the repair may said to reset some button but I don't kn
see this causes and fix it. God bless you
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 28, 2012 | Admiral Dryers
Admiral heavy duty super capacity dryer won't heat up.
see this causes , fix it. God bless you, use the common sense
Door Switch
Wiring
Maytag Neptune dryer was always drying on high heat, now won't turn on
Power From The House
Door Switch
Wiring
Sep 27, 2012 | Maytag Dryers
Kenmore 80 series dryer won't start.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. To determine if the door switch has failed, watch this part testing video.
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Aug 21, 2011 | Dryers
Electric dryer won,t heat/replaced heating element last year,dryer worksbut won't hea
Hi galepezz...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Jul 25, 2011 | Kenmore 62602 Electric Dryer
Hi galepezz...
Check your Wiring
Jul 25, 2011 | Kenmore Dryers
Maytag Atlantis MDG7400AW Gas Dryer Logo
49 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
